Projects Side project 56 Dodge truck
Discussion in 'Traditional Hot Rods' started by wheeldog57, Dec 13, 2020.
  1. Guy Patterson
    Guy Patterson
    Just like I found in my 36 coupe. Makes you wonder what else is under the seat huh
  2. gene-koning
    gene-koning
    Not really seeing anything I wouldn't expect to find on any 65 year old farm truck. Its purpose was to move stuff around on the farm, and maybe make a trip or two into town a year. Beauty and precision maintenance were not as important as function. It had to function, and that owner used whatever he had to make it work. I suspect the Chevy or GMC truck died and the Dodge flathead 6 died, so the Chevy motor got installed into the Dodge using what ever was needed to get the job done, probably as cheaply as possible.
    When the floorboard needed patching, at least he put in some effort to stick something fairly solid in there, most just covered the hole with a rug or floor mat. Gene
  3. Third DodgeBrother
    Third DodgeBrother
    The sales literature bragged on the "waterproof" intake and ignition. Turns out there wasn't really any choice, as those hoods leaked big time. Thus, open carb throat is an open invitation to bent rods
    Jrs50 likes this.
  4. wheeldog57
    wheeldog57
    The owner bought a new carburetor, the throttle plate needed tweaks and a hole to match original. Also, the new carb has an extra vacuum port 20211216_180009.jpg 20211216_180544.jpg
  5. IIRC, they also come from the factory with spark plug boots/hoodies to prevent pools of water in the plug pockets.
  6. wheeldog57
    wheeldog57
    I knew this was coming. . . . It needs floor supports and pans 20211217_155056.jpg 20211217_155122.jpg 20211217_164123.jpg 20211217_164134.jpg 20211217_164204.jpg 20211217_164827.jpg
    Oh yeah, toe boards too!
  7. wheeldog57
    wheeldog57
    I think I'll try to make a transmission tunnel, pretty sure I can do better than this one^^^
  8. wheeldog57
    wheeldog57
    Fabbed up the first of many sub floor pieces.
    Hoping to zip this side together tomorrow, I need to jack up the body a little because it has settled
    vtx1800, Okie Pete and Nailhead A-V8 like this.
  9. birdman1
    birdman1
    Henry Ford was a farm boy
  10. birdman1
    birdman1
    At least it doesn't have the slush o matic dodge transmission
  11. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I second the idea of doing the drilling out and converting to studs... Did that when I first built mine... But I also separate the drum from the idler hub to make my own disc brake conversion...
    Making good headway man... Sorry I had forgotten about the LH thread on the left side...
    wheeldog57 likes this.
  12. 57 Fargo
    57 Fargo
    I drilled mine out for studs so I could run aftermarket wheels. I kept the drums though.
  13. wheeldog57
    wheeldog57
  14. wheeldog57
    wheeldog57
    Fabbed up a piece for the toe board, bent it to meet the floor support. I had to jack up the body about an inch to get it back to normal. Tomorrow hopefully I can weld this up and get the floor jack out.
  15. rockable
    rockable
    Subscribed. Finish this cool project.
  16. wheeldog57
    wheeldog57
    Hard part done on this side. Toe board had a lot of shape to it. I need to finish the welding and grinding but I can live with this. 20211221_181934.jpg 20211221_182404.jpg
    tr_rodder, vtx1800, Okie Pete and 2 others like this.
  17. wheeldog57
    wheeldog57
    Finally got some hours to slam the floor supports and pan in, lots of mig wire and seam sealer 20220625_141055.jpg 20220625_141100.jpg
  18. wheeldog57
    wheeldog57
    Fabbed and welded in drivers side floor supports, tomorrow weld in the floor pan.
    Then I can put the seat back in and bleed the brakes 20220625_160147.jpg 20220625_163238.jpg
  19. dart4forte
    dart4forte
    from Mesa, AZ
    Like those old Pilot Houses
    wheeldog57, RustyDogg and caseywheels like this.
  20. wheeldog57
    wheeldog57
    Finally got driver's side floor supports and pan in. Last week I got welders flash and that messed me up for Sunday and part of Monday. New welding hood delivered on Wednesday, I must say the new welding helmets with instant on technology and HUGE window are a game changer!!!
    Instantly I am a better welder!! Just don't tell the prima Donna real welders, they'll still **** on me!! 20220703_122536.jpg 20220703_122608.jpg 20220703_122948.jpg
    tr_rodder and Okie Pete like this.
  21. wheeldog57
    wheeldog57
  22. dart4forte
    dart4forte
    from Mesa, AZ
    Not bad. As long as you get good penetration especially the structural parts you are good. Plug welds look ok. Slap some seam sealer down and call it good
  23. wheeldog57
    wheeldog57
    Bled the brakes the other day with the help of Mike I. Went around the truck 4 times, how's the pedal now? "Worse" WTF! I really don't want to put another master cylinder in this. A friend has a power bleeder, gonna hafta try that first.
  24. dart4forte
    dart4forte
    from Mesa, AZ
    I need to do some TLC on mine. I think they need to be bled again
  25. wheeldog57
    wheeldog57
    I wired the electric fuel pump, disconnected the line at the carb, put some fuel in annnnndddd nothing. Byp***ed the mechanical fuel pump and it pumped out, got some scale and silt out of the line. The plugs got wire wheeled/gapped, the points were verified @ .019, it lit right off. I still can't figure out how to upload a video to here from YouTube so an old picture will have to do 20211113_103316.jpg
  26. Los_Control
    Los_Control
    from TX
    Just curious how you added fuel .... did you put it in the original tank?
    One big issue most noobies get caught on with these old flathead Dodges.
    The standard is to think #1 plug goes at 7:00 0'clock position on the distributor.
    While the oil pump is geared, the distributor runs off the oil pump .... If the oil pump was removed in the past 70 years & not installed correctly ..... The #1 plug wire can be any position on the distributor cap.
    Just things you think you follow the book on, people behind you may not have .... My #1 is at 6:00 instead of 7:00. .... You need to pull up #1 tdc & check the rotor.
    Fuel is another story.
  27. caprockfabshop
    caprockfabshop
    This truck has a Chevrolet OHV inline 6.
  28. wheeldog57
    wheeldog57
    A few more items off the checklist. . . And a setback. Fabbed up a shock support, drilled and installed new hardware. Brake line bracket attached, see how I planned for that? I got lucky. 20221120_103753.jpg 20221120_110350.jpg
    I then needed to address the u-joint situation 20221120_112125.jpg 20221120_123524.jpg 20221120_123543.jpg
    3 of 4 sides of u-joint were mint. The 4th wouldn't budge, even with the air chisel, so the whole deal went for a ride to a pal's shop for a new set up.
    Okie Pete and TA DAD like this.
  29. 1952henry
    1952henry
    Quite the project. Nice work! I would save on all that patina that falls off frame and old cab floors. Someone may want to buy it to sprinkle on their barnfind.
    Maicobreako and wheeldog57 like this.
  30. wheeldog57
    wheeldog57
    Got the driveshaft back and installed with u bolts from a spare banjo rear. Started hammering out a floor hump. More to bend and fit but it already fits better than the old one!! 20221127_150245.jpg 20221123_142840.jpg
    osage orange and Papas32 like this.
