Technical Who drop axles ?
Discussion in 'Traditional Hot Rods' started by 3w Hank, Sep 18, 2022.
  1. 3w Hank
    3w Hank
    Who is the ’guy’ in USA that drop front axles nice and correct ? ( any state )
  2. guthriesmith
    guthriesmith
    Sid Drapal at Nostalgia Sid’s in Oklahoma does great. www.droppedaxles.com. He also ships them all over the world including Sweden.
    Jibs, 1stGrumpy, Okie Pete and 2 others like this.
  3. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Joe’s Speed Shop since 1957 580-268-3704 in Oklahoma. I have been to his place—-he is always at the LoneStar Roundup in Austin,Texas—-super nice guy been dropping axles forever. Tell him Flathead John from Texas referred u to him. Sometimes he has axles already dropped and uses your core(undropped) on an exchange basis,but he has the final say. 1AE18F82-AD87-44B1-A52D-0BA2DE5F828E.jpeg
    southerncad and okiewelder like this.
  4. Budget36
    Budget36
    For cost, might be less expensive to pay the core charge and have it sent to you.
    Atwater Mike likes this.
  5. krylon32
    krylon32
    from Nebraska
    Anson Axles On Instagram. Lots of pictures. He's the best.
  6. 3w Hank
    3w Hank
    Ok, I had a std axle ( sold it as I like a heavy and I did not like the curve ) and that was mark ’ANSO’, so I thougt it was older done.
    Mailed Joes speed shop to.
    I might found a std core here at HAMB.
    look at the chromed heavy, thats the way I like it.
    coupe33 and Lil'Alb like this.
  7. alchemy
    alchemy
    LSGUN, LongT, wheeldog57 and 3 others like this.
  8. panhead_pete
    panhead_pete
    Call Joes, they generally have them in stock or can drop your own. They also do drilled. Great people! And you need to call, if I can do it from Japan you can do it too :)
  9. big duece
    big duece
    from kansas
  10. 55chevr
    55chevr
    I got an "A" axle from Okie Joe - bought it out right - very pleased with it
  11. SS327
    SS327
    I dropped an axle once. It broke all my toes! :oops:
    Tat2Neil likes this.
  12. Tat2Neil
    Tat2Neil
    from Mesa AZ
    Another vote for Mr Kohler, @KohlerKustom on instagram. He did my 4 inch drop axle, his work is top notch
    Hollywood-East likes this.
  13. No need for you to buy a dropped axle overseas in the U.S. Just send a good core to Johan Törnqvist in Nyköping. He drops '28-31, '32 (heavy) and '33-36 axles perfectly just like the above mentioned U.S. hot rodders. The camber and caster angles will also be correct.
  14. Here are some dropped axles Johan did last year. He usually drops a batch of axles sent to him by fellow hot rodders in Sweden once a year. J Tornqvist.jpg
  15. -Brent-
    -Brent-
  16. chickenridgerods
    chickenridgerods
    from DSM, IA
    The primer brown one you’ve attached to your post is one done by @ansonaxles when he individually stamped the letters.
  17. Dangerousdan
    Dangerousdan
    from Arizona
    More drop was always my favorite Nerve had a problem. My $ 0.02
    big duece likes this.
  18. ct1932ford
    ct1932ford
    Good guy and does nice work!
    Hollywood-East and big duece like this.
  19. Mo rust
    Mo rust
    I've got several heavy axles that I've had dropped 5 to 5 1/2 inches by Okie Joe. He does nice work and is a good guy to know.
    dmar836 likes this.
  20. krylon32
    krylon32
    from Nebraska
    Mo rust: I'm curious, could you post some pictures of the heavy axles Okie Joe dropped 5 to 5 1/2 inches over stock. Never seen that done before. I would think with that much drop the ends would become rather thin? Thanks
  21. X38
    X38
    Mor-Drop? Are they still going?
  22. Dangerousdan
    Dangerousdan
    from Arizona
    You know trey were in the Oakland Ca. area when I used there services. Can't say for sure if there still in business.
  23. krylon32
    krylon32
    from Nebraska
    I think Mor Drop may be gone?
  24. V4F
    V4F
    from middle ca.
    okie joes in oklahoma . had 2 of his , always right on
  25. MeanGene427
    MeanGene427
    from Napa
    There's a guy in Santa Rosa who does it, and usually has a pretty good supply of cores
  26. Liberty Garage
    Liberty Garage
    Do you have a name for the Santa Rosa axle dropper
  27. MeanGene427
    MeanGene427
    from Napa
    Send me a PM and I'll get you hooked up
  28. Budget36
    Budget36
    Was he in the Sacramento area before?
  29. gimpyshotrods
    gimpyshotrods
    Mor-Drop is long gone.
    Marty died on March 14, 2012.
    The business did not carry on.
    saltracer219 likes this.
  30. Mo rust
    Mo rust
    I spoke to Okie Joe the other day and he recently picked up four 32 heavy axle cores if you don't have one. I also talked to him about narrowing them too which he also does. The stock axles are something like 50 or 51 inches wide and dropping then makes them a little bit narrower but if you're running fenders and like to set your car low in front, you need it narrowed to 46" or so. Joe cuts them down and then welds them back from both sides. It's a pretty extensive process and I think he charges $150 extra for that and he's done several of those over the years. From now on I'm going to have him narrow them too just in case I ever want to add fenders.
    gimpyshotrods and -Brent- like this.
