Projects Hotrod31A build thread
Discussion in 'Traditional Hot Rods' started by Hotrod31A, Jun 26, 2022.
  1. Hotrod31A
    Hotrod31A
    More than likely, but I don’t really want to. I priced a few shops locally and they are outrageous for cost and lead time, so probably will have to.
  2. Bandit Billy
    Bandit Billy
    I had to make the same call for the same reasons recently. I'll be watching.
    31chevymike, Hotrod31A and Hotrodmyk like this.
  3. norms30a
    norms30a
    A guy needs to reverse think it. When I get all the rust fixed, all the welding done, all the engine stuff, etc etc. I figure I'm on the home stretch. I'll clean and paint the frame then the suspension so my rolling ch***is is done done. When I start the Sheetmetal I always do the body first, prime block forever, paint block again buff, Then I set it on the nice ch***is and boom, it's a car again, and looks awesome. This gets me excited to keep on.
  4. Hotrod31A
    Hotrod31A
    Small progress today, filling the extra holes on the new firewall, and reattaching the dimpled supports.
    Finally dialed in the pulse function on the tig and switched to the finger trigger. Much less ***bersome. Believe the settings are perfect for the ****welds on 18 gauge, can stay on the seam without fear of blowing it out now. Guess it could be my grinding skills are just getting better too, pics are after a thin layer of epoxy prime to prevent rust, no filler yet.
    48A05B28-7464-4CB8-88DB-D8A1B9A0E14C.jpeg 68A5252A-4193-4A0A-8DA6-CECE277BA9CE.jpeg EDDC5D36-2B03-4FA5-B048-9B7C10B4FEDE.jpeg 09A07D47-11AB-4B59-81C6-42155992647D.jpeg F6700443-0F89-4CE6-A20A-6C4415353A6E.jpeg C24649EC-2BB9-44ED-A2FA-D1275C76AED6.jpeg
  5. A Boner
    A Boner
    74A36788-D8B1-4F54-8B45-62EEBE5453A4.png This SBC looks great…KISS (and inexpensive) is good plan!
    31chevymike, Vic Walter, Tim and 6 others like this.
  6. Welds look awesome and your fab work looks great. Did all the welding on our project with a flux core mig. Let's just say the process was, weld a little, clean a little, weld a little ... Next car I'm getting a tig machine as a local suplier seems to offer good deals on the Esab. Shop envy too. Give 'er ****.
    Hotrod31A likes this.
  7. Hotrod31A
    Hotrod31A
    Been there too Brother, flux core is tough to get a clean weld.
    Can’t recommend the pulse feature and a pedal enough. Makes all the difference with thin gauge.
  8. Hotrod31A
    Hotrod31A
    P***enger cowl patch in and ready to move on to doors and hinges.
    3 days of labor , two burns and one cut , strained patience to get here. 97B14DFF-B906-4C71-AEB0-36B63B2CF250.jpeg 556DC2E5-42FC-417D-8333-1A0B25097B5A.jpeg C48776EF-CA35-4722-8AF7-DB5ABD95FC0B.jpeg 835C0E0E-C2AE-4064-BF57-93D17354F1EA.jpeg 813847C8-0C24-4D7E-B345-AED28775F3A0.jpeg 8C4F6754-C603-4014-99CD-94A551C62055.jpeg
  9. WhyW8
    WhyW8
    from Sun City
    looks great -- the labor sure paid off
    31chevymike and Hotrod31A like this.
  10. Looking good!! Another item checked off your list. I'm enjoying following along. Thanks for the updates.
    Brian
  11. Hotrod31A
    Hotrod31A
    Thanks for the support gents!
    Maybe before I finish, I’ll run across a patch panel that I don’t need to spend a day on modifications to the panel itself to get it to fit. Both the cowl patches were 1/16 too long and had to be cut and welded to fit before I got started with the welding on the body. Thankful for the parts but damn, lol.
    31chevymike and brEad like this.
  12. Hotrod31A
    Hotrod31A
    Today’s update. Starting on the jambs and couldn’t get past the ****py A pillar chop so had an o **** moment and cut it out. English wheel skill had to get there quickly .
    All tacked in and almost ready for final weld and grinding.
    Stay tuned… E4949D93-1D47-4AB3-B77B-C2B031286858.jpeg AC582158-BD7F-47B2-A3B5-6BDEA999ECD2.jpeg DFD9EF5A-8209-4F6D-95AB-43D2EF75412A.jpeg BC12984F-5D79-4E8E-98F5-9100FB2152B9.jpeg BE7B4CD9-5483-455D-827A-19CCD191E2F8.jpeg 9CA82911-9638-48A1-BA6C-7E3C73A928FD.jpeg 72EC0212-72D3-42AB-A063-AE227693906C.jpeg
  13. Hitchhiker
    Hitchhiker
    Great save man!
  14. Hotrod31A
    Hotrod31A
    Inner lip added , welded , metal finished , bondo ready and moving on.. 9D68AA64-3F7C-4BB6-BE81-12A12FF3D295.jpeg 1F03CF74-7E8F-47FE-94E5-EAAF95DACEE2.jpeg EEECF903-A166-4148-AE21-1FB6D6DA6F6D.jpeg 4565FB93-6D1B-4E30-88E5-AFF66A8F2528.jpeg
  15. brEad
    brEad
    More better!
  16. warbird1
    warbird1
    Just found this; great work! I'm in the process of un-channeling a '31 roadster and can understand what you've gone through on the sub-frame. I am amazed at the ****py work that was done on mine... panels bolted together, then welded on both sides of the seam, outside then brazed, then covered with lead and/or bondo. They also discovered that with a stick welder you can reach way down in a tight spot and weld it up, meaning you have to cut the panel up to get to the weld.
    Following!
  17. Hotrod31A
    Hotrod31A
    Sounds all too familiar Brother!
    warbird1 likes this.
  18. I really enjoy watching and reading about guys doing great work and saving hotrods...your's is a fine example!
  19. Hotrod31A
    Hotrod31A
    Been away from my shop. Little work done on the ole Onion.. cut out some janky and hand fabbed some patch panels. I’m getting a little better at this deal, only 3 tries .
    Door hinges and alignment obviously need work, just checking the body lines in the pic. Believe at this point their filler worthy so on to more door jamb fun! D2E90C77-2947-459C-9B2F-89368AC58904.jpeg B2781D96-D187-418C-B07E-6A0AC6EC640A.jpeg 0A2D2F61-B4EE-466B-9961-7E181C64380E.jpeg D924FE84-81F8-431C-8CD5-54027911966E.jpeg 9FDCD51B-4AF1-4586-8103-AAFF562756ED.jpeg 592E87AD-6383-473B-B0C4-6FD39377C030.jpeg
    31chevymike, AHotRod, Tim and 6 others like this.
  20. brEad
    brEad
  21. Hotrod31A
    Hotrod31A
    Making some headway on the door jambs and ran out of weld gas. ****py chop lines , rotted door lock pocket, and butchered B pillar sheetmetal fabbed and replaced. More correct straighter lines and looking like a Model A a little more each time. 3A7FB848-E428-4C5E-8527-13C88D42811B.jpeg 03CC64E9-A115-4917-AE16-A5AA7BA87F29.jpeg 14E303F4-3046-4819-AE60-5FEF46C205D3.jpeg B1E4A422-671F-462F-8898-6C14F7DE89B3.jpeg A62136A3-E767-411F-9CAF-505E490208B2.jpeg 6E0BCC12-DCA3-41CD-80B1-40A34B10A5D9.jpeg 546DC85E-45ED-4C7E-86D4-D5DD115349C2.jpeg 88913FEE-007C-4550-8C4F-78AA03D31630.jpeg 8ECC1F5D-FC9C-47F1-A25B-2050508B9898.jpeg
  22. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Your **** looks clean, and very well done! great job!:)
  23. arkiehotrods
    arkiehotrods
    I love this thread, not only for the fantastic workmanship but also for your taking the time to do***ent it for us with excellent photos and descriptions of what you're doing. Thanks!
  24. Hotrod31A
    Hotrod31A
    Thanks Gentlemen!
    31chevymike and AHotRod like this.
  25. caprockfabshop
    caprockfabshop
    Thanks for do***enting! I'm about to embark on similar repairs to mine. Enjoying the build!
    ~Peter
    31chevymike, AHotRod and Hotrod31A like this.
  26. Hitchhiker
    Hitchhiker
    I'm curious what is your method for smoothing welds?
    Also looks great! Hopefully that frame is coming soon!
  27. Hotrod31A
    Hotrod31A
    2 inch 80 grit roloc with die grinder directly on top of weld bead until flat or almost touching panel metal when sanding, finish with 2 inch 80 grit DA.
    If I can get behind the panel, I’ll use a hammer/******* and toe dolly on the low spots and follow up with a shrinking disc if needed.
  28. Hotrod31A
    Hotrod31A
    Quick before and after metal finish. The old sheetmetal sunk pretty hard at the top during welding. Still need to do dolly work to complete before bondo. Moving on to next… 7DDD0D96-923C-4DEE-B49D-1F86EAE754F3.png 54F6F220-7965-4299-8A3E-7CFE5F2BBE46.png 9E97FB4C-20D3-4CF3-96EE-05475AE41DFD.jpeg
  29. Hotrod31A
    Hotrod31A
    Finished the inner Driver’s A pillar. These have bothered me for a while and didn’t like the original trim, so I fabbed a piece that will be structurally stronger and cleans up the chop and pillar lines.
    Drivers door is next up, full rebuild planned. Stay tuned. 5538DD05-B6A9-45F3-B3B2-EA3A4B76D6EB.jpeg DF7F03E2-1B8E-4094-A238-BE76839E9F18.jpeg 73415ECC-EEA2-4D77-95AF-DE4857CEEA52.jpeg 84C1C7CE-B357-4AAC-BA0E-23ADB5600246.jpeg
  30. Tim
    Tim
    from KCMO
    Dang man great work. Probably wasn’t that nice when it was brand new!
