History Anyone recognize this 60’s, Orange, Channeled ‘34 5 Window from New England?
Discussion in 'Traditional Hot Rods' started by Shaun1162, May 5, 2021.
  1. Ryan
    Ryan
    ADMINISTRATOR
    This is how you get a survivor back on the road.
    deadbeat, rust, Shaun1162 and 4 others like this.
  2. TFoch
    TFoch
    Just found this thread. I'm from southern NH and can't wait to see it back on the road!
    Shaun1162 likes this.
  3. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    I'm enjoying your build. Just found this thread yesterday. Something I need to do some day. I posted a pic of some diamond design that I bought @ Home Depot for the rocker kick panel. I thought that you might get some ideas for your build. They also have some plaster wire mesh that I used on my 95 V off topic car. Covered the fresh air intake in the front valance & backside of the fenders.
    Shaun1162 and Thor1 like this.
  4. BURN OUT BOB
    BURN OUT BOB
    from western AZ
  5. Shaun1162
    Shaun1162
    More progress!
    I believe this is the first time the car has driven since the late 60’s!
    352673EB-B7B1-4B07-90A4-C61E052590E0.jpeg 4A929B06-78E3-4B57-8B68-2872972DBA6D.jpeg 251EE352-2A5A-4E0F-BEBB-7007BB57C502.jpeg 686CF812-B029-4D03-88D3-1BB6BAB0E299.jpeg DA98042E-B78A-440F-8ECB-43E2552684DD.jpeg 42531D34-6610-4AA0-9745-06FCEA98553E.jpeg 2485FC81-C3A5-4668-8866-35B51C88759E.jpeg
    Torkwrench, MikeRose, Tim and 24 others like this.
  6. AHotRod
    AHotRod
    Man .... I love what you're doing with this Coupe ... it has so much history and character.
    I'm sending you a "Pat-On-the-back" :) Stay on track!
    Glenn
    Shaun1162, NoSurf and Stogy like this.
  7. SS327
    SS327
    So cool!
    Shaun1162 and Stogy like this.
  8. vtwhead
    vtwhead
    Well done man! Just beautiful.
  9. wheeldog57
    wheeldog57
    Great job Shaun, can't wait to see it at the jalopy hillclimb next month. Wait. . . . You ARE bringing it to the hillclimb, right?!?!?!?!
  10. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Damn check your brakes. Looks like you went right thru the block wall. Ha ha just kiddin ya. Car is lookin great.:cool::);)
    deadbeat, Shaun1162 and vtwhead like this.
  11. rust
    rust
    I had a viewing today, even heard it run! It’s killer
    deadbeat, WC145, Shaun1162 and 5 others like this.
  12. Shaun1162
    Shaun1162
    Wow, thank you for your support Ryan! I must be doing something right if the boss man approves!
    Thanks! Yes, hopefully you’ll see it out! I hope to make some of the hot rod shows next summer!
    That is a cool idea! Thank you for showing the pic, I have thought about a kick panel there. I’m thinking of adding carpet at some point, but haven’t gotten that far yet!
    Thank you Glenn! It certainly does have character, and I’m sure it’ll turn some heads! Not everyone is in to the wild 60’s stuff, but I love it!
    Yes I hope so! I’m not too sure if I’ll take it up the hill… This thing was more built for the streets of Connecticut than the side of a mountain!
    Haha yes you’ve caught me! I was working on a foam pattern for a radiator… I’ve given up trying to chop or modify 80+ year old radiators, and have decided to order a custom core instead. At least I’ll be starting with something good then!
    Thanks Jon! You missed rides later on
    deadbeat, WC145, SS327 and 3 others like this.
  13. Shaun1162
    Shaun1162
    Look ma, no more blocks under the grille!
    A little under a year and half after acquiring this coupe, I finally got to drive it down the road.
    I decided the other day that I’d waited long enough to drive it, so I told myself I’d get it going for the last local Cars and Coffee event at the WFK Ice House museum in New London, NH.
    I ended up working all night Friday, no sleep, but damn it I did make it!
    Overall it goes down the road pretty well, but I’m fighting clutch slipping, and it’s a little difficult to get into 2nd gear. I think the clutch may have gotten grease on it from the throwout bearing somehow? Hoping I don’t have to pull engine and replace the clutch disc!
    107F1BEE-9274-4CF5-BBEC-F47A01E92C43.jpeg 0B2BC8AA-4C73-457F-AB25-81DFC4AE7856.jpeg 721CF496-C20C-4D95-AC7A-BB1F2475774F.jpeg 765C1E04-FAC5-49D0-A592-21CF5AD5D487.jpeg C85FE349-D409-4FD4-AA85-A06D4E9259CD.jpeg 5DA029E0-B0DA-493F-B19D-3E218920FF3C.jpeg
  14. Nice to see it out! You taking it to Epping at the end of the month to show it off?
  15. dumprat
    dumprat
    from b.c.
    Nice!
    Try hosing the clutch out with a couple of cans of brake clean?
    Shaun1162 and SS327 like this.
  16. dearjose
    dearjose
    Car looks killer. And that grill is perfect. Great job updating and preserving. It's a fine line and you did great.
  17. So good dude!
  18. SS327
    SS327
    Car looks great! Clutch not so much. You can try hosing it off with brake clean but I think replacement may be in order.
  19. guitarguy
    guitarguy
    Lots of reasons for clutch slippage. If you just reached in the clutch housing itself and wiped your fingers on the inside, not really a valid test IMO. My clutch housing gets loaded with stuff and will make your fingers black for days, and the clutch itself is dry. It could just be worn quite a bit and a weak pressure plate too. Some oily residue can be off the rear main and just get whipped around in there, but not necessarily make it to the clutch surface itself.
    Either way, great job on getting it back on the road. I would personally be putting a new clutch for piece of mind in it over the winter.....and checking that the rear main isn't leaking.
    Thor1 and Shaun1162 like this.
  20. Shaun1162
    Shaun1162
    Been doing a bunch of trouble shooting, and @rust came over and checked it out. After trying about everything in the book, it seems the pressure plate just isn’t up to the task. It was a used Flathead one I had kicking around, so I’m not entirely sure of the history. The new pressure plate I bought from Mac’s didn’t fit worth a ****. The bolt holes were 3/8 instead of the standard 5/16, and the release fingers were much higher and messed up everything when ***embling.
    I’ve ordered a new Ram street/strip pressure plate. I guess a stock Flathead pressure plate designed for 110 HP and skinny tires isn’t quite up to 350+ HP in a 2,000 pound car, with 13” wide tires… and Posi
    alanp561, WC145, rust and 8 others like this.
  21. Shaun1162
    Shaun1162
    So I managed to fix the clutch slipping issue. New Ram street/strip pressure plate took care of that. I found two stray springs when taking out the trans. I believe they were wedged into the pressure plate, leaving it partly engaged when it was ***embled and making everything seem kosher. The problem occurred when the springs fell out, the pressure plate was able to disengage fully and ran into the throwout bearing.
    6436AD2F-1B3C-485D-8287-C762694B0DBD.jpeg 29E3B5DA-4474-4A32-977B-CCF51EDF0AA6.jpeg A2AA14DA-A8FD-481D-8304-FA4445A95F29.jpeg
    I missed out cruising this thing around at Pinetree Jamboree, but my back-up goal was the Jalopy Hillclimb held in Campton NH. After some late night fiddling until 3AM, I got things squared away to where I felt comfortable driving a reasonable distance. The hard work paid off, and the car performed quite well all day, no real hiccups! I missed a turn on the way back and ended up going the LONG way home, but I added over 150 miles to the odometer! The event was great, and I can’t thank Alan and Mark Johnston for putting on this event!
    A95D9C0A-E109-4EE0-AE81-18EB0FC92659.jpeg 93579DB5-28A2-40BE-89D4-AB26E7268058.jpeg FA262BFE-C960-410B-9764-307274BE5738.jpeg 4D89A15F-D468-4ADD-BDB9-EBDA9ECDE230.jpeg B855D0F1-9A15-4FB4-98C8-F99202128077.jpeg AF1EAE12-8450-4B90-8E85-AAA6C255D945.jpeg 06DF9012-BE06-4741-A1ED-B084269415D7.jpeg F243370C-BFE4-4BBA-8628-2F63F5904065.jpeg
    Torkwrench, WC145, 49ratfink and 14 others like this.
  22. AHotRod
    AHotRod
    So glad to see you made the Hill Climb, the "view" of the hills in your pictures are beautiful, as well as all of those real hot Rods.
    Shaun1162 and NoSurf like this.
  23. Shaun1162
    Shaun1162
    Yes it was quite the event! I wish I had a good video to show the road going up to the top… it was no joke! I only made two runs up, the second one a rock had come loose in the road and almost took out my grille! Probably 50 cars in total, and all of them were pretty cool.
    AHotRod and NoSurf like this.
  24. bowie
    bowie
    Glad to see you got your juice clutch back in action. Looks like you have a cl***ic “Roy” key fob on her..that ought to be good for at least a extra 5 horsepower! LOL He has been a buddy of mine for a whole lot of years; hope he is doing well!
    Thor1 likes this.
  25. AHotRod
    AHotRod
    @Shaun1162 .... if you come accross and video of the event from others, please share it with us, I'd love to see the hill and area.
    Glenn
  26. NoSurf
    NoSurf
    If you do a search on Instagram for #jalopyhillclimb2022 you will see lots of pics and videos.
    rust and AHotRod like this.
  27. Shaun1162
    Shaun1162
    Another 100 miles cruise today, up to Dorchester NH to take a little (132 pound) load of s**** copper to the junkie and then on to visit the legend himself Howard Towne. Headed up the road from his place and snapped a couple pics…. And then opened it up a little on the way home!
    45A42EFC-806C-4FDB-9354-C5DCA24F5B5F.jpeg 3DC6FA3F-1CA7-458B-9B99-5F755111907C.jpeg D79EC596-E420-4519-AC0C-F9FC48F9FC58.jpeg ADE6037E-8700-44B6-B2EC-D3808EF4ABA3.jpeg 3C6D8C3F-6069-4A24-A020-FAE1FD0F41FA.jpeg 2DAF0309-9320-46A2-8355-AFC2C7A21EF5.jpeg
  28. Howard's yard is always full. Your coupe looks great.
  29. 49ratfink
    49ratfink
    just read the whole thread start to finish. what a great build and well do***ented. threads like this is what the HAMB is all about.
    Thor1 likes this.
  30. AHotRod
    AHotRod
    Glad to see your having a great time in the Coupe, and thank you for the story and pictures too.
    Glenn
