Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Congratulations on the drums score!! And as a bonus you celebrated with some In N Out!! Life is good!!
    Hotrod1959, Six Ball, Outback and 2 others like this.
  2. Jeff34
    Jeff34
    IMG_0008.JPG Glad the drums worked out for you, Joey! Dave is a character, and has a TON of Ford knowledge. I remember the day he and his wife came to inspect the '30 Ford dump truck I sold to him. I had no idea they were Ford judges. They were crawling under the truck looking for numbers. They were excited that the detents on the timing and throttle levers were still there. They tried to get it running to drive it home, but eventually had to put it on a trailer.
  3. A Boner
    A Boner
    Did Posies suggest how many leaves would work the best for your roadster?
    J.Ukrop likes this.
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! With a mini road trip, rusty parts in the p***enger seat and an In-N-Out burger in hand, I was really living the hot rodder's dream.
    That's incredible. It was so fun learning about minute differences between different A's from him. Nice truck, by the way!
    They recommended this particular spring for a flathead application. If I were going with a Hemi or something heavier, they mentioned a different line of transverse spring (1001 Heavy).
    winduptoy, dwollam, Tim and 1 other person like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I spent this afternoon smoothing out a few parts on the headlight bar and painting the spring in the driveway. I'd like to finish both of those tasks tomorrow.
    I can feel the project gaining momentum. Over the past few days, I've gotten a whole lot of good stuff in the mail. I'd post photos of it all now, but it's too dark out.
    So, I'll close with this snapshot from earlier today. We now have shocks, and I couldn't be more excited!
  6. 51504bat
    51504bat
    Another version of a higher headlight bar posted this morning on the Friday Art Show. headlight bar.jpeg
  7. Tim
    Tim
    from KCMO
    That’s the roadster from the cover of pat ganahal lost hot rods ( one or two I can’t recall with out going to look)
    J.Ukrop and Six Ball like this.
  8. flatout51
    flatout51
    Was that called "The Unknown Roadster"? Or something like that.
  9. Tim
    Tim
    from KCMO
  10. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Joey,
    This is your lucky day !
    Call me today.
    Sent you a text as well.
    Cob
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Me: I just need to swap the front spring and install the front shock mounts and the ch***is will be finished!
    Later that day:
    Looks like the front p***enger frame rail is bent. Not ideal. Full update happening soon.
  12. Six Ball
    Six Ball
    from Nevada
    Version 3?
    Woogeroo and J.Ukrop like this.
  13. trad27
    trad27
    Yikes, hope all is well and nothing a little porta powering can’t fix.
    J.Ukrop likes this.
  14. Tim
    Tim
    from KCMO
    No hill for a stepper ;)
    J.Ukrop likes this.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hopefully it'll just be Version 2.0!
    One has recently been added to the ****nal, so hopefully that'll do the trick.
    Thanks, Tim! We will figure it out.
    Tim and winduptoy like this.
  16. Tim
    Tim
    from KCMO
    Nothing that hasn’t been done a trillion times. You’ll have it fixed before your bike ride to lunch ;)
    J.Ukrop likes this.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 32.X: The Right Way
    Things have been moving along smoothly on this project. Every time I go to the shop, we're able to check an item or two off our big cardboard list. Last Saturday, I showed up with a very clear plan of atttack. It went something like this.
    1) Dis***emble front end and swap in new front spring
    2) Fill one more hole in the frame where the driver's side shock mount will go
    3) Mock up final shock mount position
    4) Install all four shocks
    Bonus: bolt-on headers with new stainless hardware?
    That would then close the door on ch***is fabrication, other than the steering box and pedals. Sounds simple enough, right?
    Before we dive in, here's one of the day's visitors. David did a great deal of work on this survivor Model A. IMG_7846.jpg
    The throttle linkage is a signature di Falco piece.
    The chrome trans is a work of art.
  18. Tim
    Tim
    from KCMO
    Lots to look at there!
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Pardon the interruption: it's been quite the afternoon.
    To kick things off, I removed the front suspension. We then swapped springs and realized that, although it went on easier, it did not make a difference. We measured, measured and then checked again. It was at that point that we realized that the p***enger side frame rail was bent. My heart sank. How could that be? We checked everything when it was a bare frame. What could have changed?
    There was no other choice: we had to tear it down to straighten the frame.
    Much to my surprise, I had the whole thing torn down in less than 30 minutes. To quote my old boss Steve ****an, "Experience is what you get when you don't get what you want." I will say that throughout the course of this build, I've gotten pretty proficient at taking this thing apart.
    Right around this point, David's longtime friend Jerry came by the shop to say hello. Without asking what we were doing, he asked if we needed any heavy duty four-inch I-beams. "You know what?" David said. "Those would be perfect. Let's go get them."
    With that, we took a field trip to Jerry's house. Jerry is lifelong hot rodder and an extremely skilled machinist. He's lived here since 1972, and his garage is perfect. Everything in there has a story. My favorite was the floor jack that he traded a 1940 Ford coupe for. "I still have the jack!" he said, pointing to it. "Seriously?" I asked. "Really. That's it right there!"
    IMG_7859.jpg This is his Deuce pickup, which still wears its two-tone paint from the late-'60s.
    After our visit had wound down, David and I returned to the shop with a truck bed full of heavy metal.
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    For the rest of the afternoon, we focused on building a frame table. We made sure everything was square, and we made a centerline out of string. Next time I'm at the shop, we'll use every trick in the book to whip it back into shape.
    It's hard to pinpoint what it was about this frame issue that took the wind out of my sails. In retrospect, it was because I felt like we were getting so close, and Saturday was going to be a relaxing day of simply bolting things together. But this isn't a kit car. It's not a mail-order car. It's a traditional hot rod built out of dozens of 1920s-1950s parts that were never meant to go together. It's not supposed to be easy.
    As I was tearing down the ch***is, David volunteered to get lunch.
    "How are you doing, Joey?" he asked.
    "Okay, I guess," I replied.
    "This is one of those times that all we have is our positive at***ude," he said. With that he slipped into his yellow roadster, fired up the flathead and drove out into the world.
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Intermission: The Road to the Roc
    I'll be interrupting the build progress this week, because I'm on the road to the Gathering at the Roc. Last night, I took the redeye from San Francisco to Detroit. Earlier today, Dave Gray and Colton Leigeb picked me up from my brother's house in Lansing. IMG_7912.jpg
    From there, we got rolling. It's going to be a hell of a trip, and I couldn't be more excited. If all goes to plan, we'll be in Oklahoma by Thursday. If you're going, please let me know so we can meet up! In the meantime, stay tuned to Ridetech's Instagram (and mine too) for all sorts of updates. 4M5A3950.jpg
    And yes, I am taking plenty of notes for my car's future road trips.
  22. Hitchhiker
    Hitchhiker
    Joey.
    I know exactly how you feel. I think most of us do. It's probably just my poor planning, or complete lack of formal training, but it seems like every huge build I've done has these types of moments. On my 67 GTO it was when the clutch with 300 miles on it started slipping. My black truck was when the Winfield banger wouldn't run. If I've learned anything, it's unexplained things happen.
    Because of this I've learned not to expect "easy days"... ya'll know what I'm talking about. You were about to be finished with a major milestone. You thought that day was gonna be easy, and when it's all said and done, you got your *** kicked and the thing is in a million pieces. And you're back to square one. We've all been there.
    I know how much it ****s, but this is a moment of greatness unfolding. This is when you separate the hot rodders that do from the hot rodders that don't. The difference between a pile of someday parts and a running hot rod is overcoming these obstacles one by one. You're gonna overcome this obstacle. And one day, sooner rather than later, it's just gonna be a bump in the road of the story of your car.
  23. Six Ball
    Six Ball
    from Nevada
    My roadster frame had a bent horn. Leroy & Bruce clamped it to the ch***is table applied a bit of heat & a little pressure and it remembered how straight it used to be. No big deal. It's just metal. It's soul purpose is to be shaped, re-shaped, or melted down and made into a new shape.
  24. Well Joey, lemme tell ya about the week I’VE had...
    Weekend before last I returned from a 2 week drive-about of the Eastern Canadian Maritimes. (OT car). Returning to East Central Brrmont, I found I’d brought Covid home with me. ****! Settling in for a 5day isolation and some super meds, I was bummin till the Postman dropped TRJ 85 in my box! Things were looking up as I dove in, reading every word front to back as usual...till I got to page 14, and there’s your smiling face talking about your First Roadster Build!
    I knew you’d been searching for quite awhile, and decided I better check your build thread here. So, 88 pages later (which got me joyfully thru most of last week!) I feel I know you and your Machine pretty well. You relived a lot of the ups n downs of the past 10 years with me and my BNGR.
    Now that I’m caught up, I realize I’ll hafta wait a day or 3 for new updates. But that’s ok. I can get back to #85! I know Roadster 1.0 is water under the bridge, and you are immersed in 2.0, but a few questions came to mind early on in your thread:
    1) I’m curious why you never swapped a higher compression head while you were hopping up? (Or did you and I missed it?)
    2) Did you ever put shocks on it? (same note as above...remember, I’m feverish!)
    and 3) Is your body as wonky as your “as painted” paint job makes it appear? Hard to tell if it’s all wrinkled, or just an illusion. (I realize body condition was a low priority for pre-war Hoodlum Racers looking for a cheap enclosure, and I’m all for that..don’t look closely at mine!)
    In summary, I can’t tell you how enjoyable you’ve made my plague experience! Thank you!
    And I gotta say, your H.A.M.B. friend’s painting of 1.0 on the street with the foliage is crackers!
    Now I’m goin out to the barn and paint BNGR’s firewall Almond!
    Best of Luck Joey!
    Art
    winduptoy, 41 GMC K-18, Tim and 4 others like this.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you, Matt. That really means a lot to me. After being away from it a week, I'm really looking forward to jumping back in. Those hose clamps are going to look so good on there!
    41 GMC K-18, Tim and Hitchhiker like this.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That's what we're going to do! We shape metal all the time on these machines; this should be no different. Thanks for the encouragement!
  27. Hitchhiker
    Hitchhiker
    You're about the only person on the face of the planet I'd sell these too. I know they're going on a the right car. We'll probably be the only 2 cars on the face of the planet with a matching set of these! Haha
    I'll ping you on other channels.
    Outback, 41 GMC K-18 and Tim like this.
  28. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    I have said it before and I will say it again.
    " Everything old, is new again "
    " Perfection, cannot be rushed "
    Just keep kicking *** dude and persevere!
    All of your efforts are worth it, to have a " KICK *** " ride!
    Stogy and J.Ukrop like this.
  29. sloppy jalopies
    sloppy jalopies
    had a '33 frame no front crossmember, bent in 1/2", buddy makes the beer brewing vats,
    had me heat the inside of the rail red hot in a vertical 1/2" wide strip, then in a triangle from the vert rail out to the inner frame edge,
    it pulled the wrong way when HOT but pulled it in perfectly when COLD,
    it only can pull as the metal cools /contracts, ask a metal guy about baking the carbon from the steel...
    it works well... go j u go !
    Stogy, J.Ukrop, tomkelly88 and 4 others like this.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hi Art,
    Thank you for the message. First and foremost, I hope you are feeling better. There's nothing worse than being out of commission. Also, thank you for reading my TRJ piece and this whole thread. We've covered a lot of ground, in the past two years, that's for sure.
    To address your questions:
    1) I considered a high-compression head on numerous occasions, but I ended up never pulling the trigger because of the condition of the babbitt. The engine is an older rebuild, and I didn't feel it was necessary to tear it down when it seemed to be doing just fine. I knew that this version wasn't forever, so my number one goal has always been reliability. I need to keep this thing on the road!
    2) I never ended up running shocks. The main factor there was cost. Friction shocks were out of my budget, and I don't have the facilities to weld on tube shock brackets here at my home garage. For how I use the car, it seems to be fine without them?
    3) The body on the car is actually really nice. The "wonkiest" part is near the tack strip on the p***enger side where there's a homemade patch panel. Other than the filled bullet holes in the doors, brazed door handle holes and the usual rust in the wheelwells and lower cowl, it's a presentable body. The subrails are just about perfect.
    Best of luck with the health and the firewall. Post some pictures when you're done!
