Projects roadster pickup
Discussion in 'Traditional Hot Rods' started by cowkicker, Sep 26, 2022.
  1. cowkicker
    cowkicker
    from Ky
    Working on a flathead powered 31 roadster pickup and need some wheel and tire opinions. I am wanting to run 10.00 -15 cheaters on the rear. For appearance purposes will 10" wheels be too wide? Would 10.00s look better on an 8 or 9" wheel. Wanting to run 5.60s on 4 1/2" wheels up front. Thanks
  2. fastcar1953
    fastcar1953
  3. caprockfabshop
    caprockfabshop
    Here's a 5.60-15 on a 15x5 Wheel Vintiques wheel. If you can find a 4.5" wheel that would perhaps look even better.
    ~Peter
    AHotRod likes this.
  4. cowkicker
    cowkicker
    from Ky
    planning on 4.5 fronts, what size rears you running?
  5. DDDenny
    With or without fenders, also, there are a lot of backspacing options on wheels.
  6. cowkicker
    cowkicker
    from Ky
    Without fenders, was doing some double check measuring last night imagining how10.00-15s might look. Do you think 10.00s might be too wide for a small 31 pickup.. Do you think maybe 8.20s on a 7" wheel might be a better fit to get the right look. Please give me your thoughts and comments, I want to get this right the first time!
    sloppy jalopies likes this.
  7. Rand Man
    Rand Man
    Yea, I think the 10’s are too wide for this build. Your 8.20 on 7 would work better for the early look.
  8. sloppy jalopies
    sloppy jalopies
    10" too wide for me... 8.00-15"... i don't see many 8.20-15s out there...
  9. Atwater Mike
    Atwater Mike
    Most of my old reversed rims were 7", had a great look with the old 8.20 X 15 tires. The taper of the rim, the bulbous sidewalls...
    Of course, these went on 'light in the ***' roadsters, coupes, and early sedans, so the tires weren't 'overloaded' on marginally 'narrow' rims.
    As 8" wheels would have been "proper", there weren't any tapered outer rims to fit to the Ford centers, lending dignity to the 'Baldy' caps.
    '50 Merc centers were also used, for the Merc 'ash can' caps. (Tom Ivo's T roadster)
    LOVE those tapered, painted reversed steelies!
  10. caprockfabshop
    caprockfabshop
    My rears are 810-15 on 15x6 Steelies. That's what looks best on a 800-810. If you go 820-850 I'd say a 7"-7.5" rim. I can't say for certain what would look best on a 10.00-15. Is that a cheater slick? Or one of the Firestone Grooved Dirt Track tires? Check the specs on the tires you want, typically they'll recommend a rim width. You also need to consider what offset you'll need. Have a rear axle picked out yet?
    ~Peter
  11. caprockfabshop
    caprockfabshop
  12. swade41
    swade41
    from Buffalo,NY
    Here's a 10 inch cheater on 10 inch rims, looks pretty good to me
  13. I like the look better on an 8" wheel but you can get a better patch on a 10" wheel.
    That said a 7" cheater is about all you will ever need with your flatty,
  14. Marty Strode
    Marty Strode
    10" slicks are too wide for a flathead, simply don't go together.
    Dean Lowe, A Boner, Hotrodmyk and 6 others like this.
  15. cowkicker
    cowkicker
    from Ky
    Thanks for posting that pic, I love that look, but after seeing that and what everyone else says, I am sure that they wouldn't look right on my RPU.
    swade41 likes this.
  16. cowkicker
    cowkicker
    from Ky
    Okay, let's talk 8" cheaters. How about 8.20s on an 8" halibrand sprints with shiny axle block off plates for the rear. We can discuss front after we get rear figured out. Thanks for all your replies!
  17. bchctybob
    bchctybob
    Here’s 10” Radirs on 8 1/2” Halibrands. Marty’s right, a tire that big looks odd on a flathead or banger powered car. Run a hood?
  18. swade41
    swade41
    from Buffalo,NY
    I was telling my buddy with the car I pictured, he just happened to drive it to work today, that I thought it was to much tire for an exposed flathead, but a great opportunity to snap a photo of what that combo looked like.
  19. swade41
    swade41
    from Buffalo,NY
    This is an 8.20 - 15 cheater on a 6 wide I think rim, the rim came off a late 80's - mid 90's dodge van
    Lil'Alb likes this.
  20. cowkicker
    cowkicker
    from Ky
    Not running a hood,. have a set of 8" Halibrand sprints and shiny axle block off plates on hand. Think that would be a decent looking combow ith 8.20s?
  21. DDDenny
    Many may not agree but if mine (not) I'd leave the shiny axle center covers off.......just me.
    bchctybob likes this.
  22. caprockfabshop
    caprockfabshop
    22 posts in and we can't accurately provide advice or opinions until you share some pics of either your build or your inspiration or goal. What era of drag racing you going for? Is this a street car? Is it going to be a 50's barebones dragster? Is it going to be a 60's surf roadster pickup with slicks for posing?
    ~Peter
  23. swade41
    swade41
    from Buffalo,NY
  24. dln1949
    dln1949
    For me the issue of having a 4.5 wheel on the front rather than 5.5 is the amount of brake equipment that shows up, and if you space the center farther out (+) you'll be tripping over the hubcap.
