I've searched for early Ford 4 banger threads, but they all seem to be on high end discussion. I have in mind, starting with a stock Model A ch***is and building from there. I have found one that doesn't include the engine and trans. I can find a stock Model A engine. Should I look a little harder an go for a later B motor? What is the difference? How do you indentify a "B" engine. I have heard that there is technicly no Model "C" engine, but the "C" crank is counter weighted or somehow better. How do I know what to look for? Please, some help for a banger novice.
Lots of high-end stuff here, but plenty of basics ****tered throughout as well... http://www.jalopyjournal.com/forum/showthread.php?t=161498
http://1149.ca/banger/Fundamentals.pdf http://1149.ca/banger/resurrecting.pdf http://1149.ca/banger/TheHal.pdf
OK, I've bought a Model B diamond block. Guess this is a good starting point. Problem is, it's a bare block, not even main caps. Anybody have any spare B caps? I need a lot of little parts. I know the B crank is different. Will a Model A oil pan bolt right on?
Contact FAST Ford A Speed Technology. and links in other replies http://www.hotforhotfours.com/index.html Jim Brierley FAST pres. has written articles on A/B, B/A can be confusing. can answer your pan interchange question. He Em me a couple of his articles... I'm still confused but not as badly. Ha
I'll contact Jim. I'm looking for a complete Model A engine (somewhere near Arkansas) to rob parts from. Couldn't I have Model A main caps machined for the larger crank size?
I thought (after reading the stuff posted by Enbloc / 4ever4) that if you were looking to run the bigger mains that the billet caps were the way to fly??
You're right, I should search for billet caps. The price of machining and lack of strength of something else defeats the purpose.
The "A" pan would work but will require some modification, the pan will have to be dimpled to clear the larger "B" rods and it will require a larger radius for the cork gasket on the rear main cap. I make my own main caps out of mild steel some makers use alloy steel. Google Taylor Engines in Whittier CA they have the heavy main caps
Well I've solved this question by buying a complete late B engine and trans. Can't wait to get it and tear into it.
Remember that the Model A transmission supports the wishbone mount and the brake/clutch mounts. You will have to build replacements if you use the B transmission. Charlie Stephens
Don, That is a thread from 2008, very few people will actually see your ad. Either put it in the cl***ifieds or tell bangerphiles on the current month Banger meet. https://www.jalopyjournal.com/forum...er-meet-thread-happy-all-hallows-eve.1275764/
