Hot Rods Rusty has a new project- father son build , 26 T roadster!
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Jul 26, 2021.
  1. Very impressive
    Greenblade and Stogy like this.
  2. Stogy
    Stogy
    Saaamooth indeedy...that sure helps keep things moving along...look really good @rusty rocket
    Greenblade likes this.
  3. Wayne67vert
    Wayne67vert
    I like your floor stands. I made myself a set a couple of years ago.
    Stogy likes this.
  4. rusty rocket
    rusty rocket
    Keeping with the wishbone mounts looks I made a steering box stiffener for the outside of the frame. 2BFA552A-39EB-4115-8D92-8F10CC3BE2BD.jpeg 5A203D2E-79E3-4755-8DF1-00760F5375B9.jpeg
  5. hotrodA
    hotrodA
    Great build! That instrument panel is beautiful. Please keep the updates coming.
    Stogy and Greenblade like this.
  6. chessterd5
    chessterd5
    from u.s.a.
    This is going to be nice.
    I love the look of the firewall!
    Stogy, Greenblade and vtwhead like this.
  7. rusty rocket
    rusty rocket
    I made the decision for final tail light placement, I had made a bracket to hang the 39 Chevy taillights but really didn’t dig the look. I ended up cutting into the sub rail and raising them up so they are not floating in midair. B1B1746B-5EB1-4367-93E1-A9F50B69E375.jpeg F1CE8215-96A5-4283-A131-C3287E9F6367.jpeg 253BD02A-6524-46E2-AD34-51EE8BEC2723.jpeg It didn’t happen easy, sort of an ass kickings. I tacked my bracket and the awesome welder that I am stuck my wire to the bracket so I pulled it off with the taillight hanging solid( at least I thought) I turned around to grab my dikes to snip the wire and then I hear glass breaking. Shit happens it was a repo taillight thank goodness. If it would have been a nos part I would have cussed. BCEBBD5A-4BA6-4218-ABBF-CD83A96E4AD3.jpeg
  8. Blake 27
    Blake 27
    That does look better, but I still like the brackets you built. 59D1EDA1-D79C-460D-895A-B8BF323FA238.jpeg
  9. Stogy
    Stogy
    Rusty looking at that tailight did you consider taking the lens and assembly minus the bucket and center it right in the panel you notched...it seems just right for it...one other option is you could run it similarly in the crushed panel above that lower sub panel...it looks all right notched in as you have it now and I know you've been racking the brain working to that then this Stogy guy comes along...:D...I will say your move tweaked my thought process...
    Them poor old cars sure took a beating...
  10. Stogy
    Stogy
    I used to have one of those...if I can find it its yours...
  11. rusty rocket
    rusty rocket
    Yeah I took the lenses off and put them on the sub rail but to me it looks cheesy and I took the easy way out to mount them. The whole reason I picked these lights was because of the bullet shape. As far as putting them in the panel below the deck lid, everyone does that and I don’t want this car to be just another T roadster.
    chryslerfan55, Greenblade and Stogy like this.
  12. Stogy
    Stogy
    The partial bucket peaking out looks good in your notched install...and it compliments the Headlight shape...
  13. Greenblade
    Greenblade
    That looks good. Shame about the lens breaking
    Stogy likes this.
  14. rusty rocket
    rusty rocket
    I mounted the tach today after work. 6B29528E-527C-4610-A77B-AF65363E0703.jpeg 4686E024-74F0-4000-AEAB-0A215E0A1E53.jpeg 425EBF8D-CB8B-43DE-8FA9-2ABE3EACC291.jpeg
  15. phat rat
    phat rat
    That tach location looks right on the money
  16. Tim
    Tim
    from KCMO
    That’ll work!
    Stogy, osage orange and Greenblade like this.
  17. Greenblade
    Greenblade
    That looks real good!
    Stogy and osage orange like this.
  18. rusty rocket
    rusty rocket
    I went to our local end of summer swap meet Sunday and was given this 15” steering wheel
    (anyone recognize what it came out of?) I used it as a donor ring for my banjo wheel. A 17” wheel in a T is to big so the 15 is going to be much better. DE17132B-31E3-4699-844E-48AB2291F2CB.jpeg 9EDD8783-0C53-4EEE-B250-DEC81AC4BD92.jpeg
    chryslerfan55, Stogy, Spooky and 5 others like this.
  19. Greenblade
    Greenblade
    Stopped by and snapped a few pics for the hamb 20220911_124638.jpg 20220911_124648.jpg 20220911_124654.jpg 20220911_124733.jpg 20220911_124753.jpg 20220911_124758.jpg 20220911_124807.jpg 20220911_124816.jpg 20220911_125232.jpg 20220911_125437.jpg does anyone know what this steering wheel is from?
  20. 51504bat
    51504bat
    What, no studs for the snow tires?:cool:
  21. rusty rocket
    rusty rocket
    3-1/2 hours to drill, tap, adjust and grind to fit the windshield frame. Bought the after market frame from speedway and it didn’t want to fit for shit, the frame was wider than the posts so I used a die grinder to open up the tapered pockets where the frame attaches. The sides of the frame didn’t match the taper of the posts so I took out the inner skin that holds the rubber and ground the posts to match the frame. It actually looks better to me slimming up the posts. I haven’t taken material from the back side of the posts yet but you can see I had to take about 3/8” off the bottom. 8B71741B-9A16-4F20-906A-6EF86AEE592A.jpeg 4648AEDC-C7FB-4050-8A16-F7BD1206826D.jpeg DEF450CB-1F98-49BC-BA92-11C7128D88A1.jpeg
  22. rusty rocket
    rusty rocket
    Started rebuilding the wheel. I added two pieces of music wire to the area I had to open up to get the spokes on the new ring. I epoxied the wire into the ring hoping that the extra wire will help hold the epoxy that I will use to build up the ring. I also wrapped tape around the spokes to create a dam for the epoxy to butt up to. 871B1789-F5D4-4E9F-8AFC-C7B2D968A17A.jpeg 20F037FD-FB3F-4B42-A10E-5ADC09B3A902.jpeg
  23. Greenblade
    Greenblade
    Any updates on the wheel? I'm curious to see how your tape dam held up with the epoxy.
  24. rusty rocket
    rusty rocket
    Nope, no progress the last few days
    Stogy likes this.
  25. rusty rocket
    rusty rocket
    We got the motor yesterday. One step closer. CE86E893-B7FD-4E93-8862-6604BC175EB5.jpeg 944FFAC5-C59E-4D5C-9340-B8D530F4EB29.jpeg AC67360C-8C59-4C4B-9E62-92F35F5CDA98.jpeg
  26. oliver westlund
    oliver westlund
    Wowzers thats purdy
  27. Greenblade
    Greenblade
    I'll include the pictures I took of it as well. I love how it turned out. I haven't seen the engine in person since September 2021 when the heads were off 20221023_152526.jpg 20221023_152536.jpg 20221023_152550.jpg 20221023_152600.jpg
  28. Tim
    Tim
    from KCMO
    Looking good!
  29. rusty rocket
    rusty rocket
    I received some photos and info on the motor from a person that grew up in my pops home town. He was friends with the son of one of the original owners. This is the car that the motor was in and set an ahra record. 5DEE38ED-B324-4E3C-A200-BDFAB2308C8E.jpeg 824192E6-391C-4CDF-9882-18B7193F7D0F.jpeg 8F57C404-F552-411C-8E39-4E432ECA11C6.jpeg 62330149-7052-4984-9F30-1903BACFF229.jpeg
  30. tombstone
    tombstone
    from sk.canada
    Wow.... excellent history ‼️
    Stogy, Greenblade and Algoma56 like this.
