Technical Rear brake flex hose rotates
Discussion in 'The Hokey Ass Message Board' started by Crotty 32, Sep 27, 2022.
  1. sunbeam
    sunbeam
    Not running a vent will make it hard on the seals to keep the oil in and I would make the hose lay flatter high points in brake systems make it harder to bleed air out of the system.
    pprather likes this.
  2. Crotty 32
    Crotty 32
    I will definitely be running a vent on the axle; just not one of those vent bolts for the hose to mount to.
    I’ll keep that in mind when finding the best position for the hose - high spots are not desirable.
  3. Budget36
    Budget36
    Not sure of final, but sounded real impressive;)
  4. Eddie
    Eddie
    from Georgia
    I'd go elsewhere and buy the correct parts with the hex design. Those parts look like something that China has p***ed off on us.
    Eddie
    Driver50x and texasred like this.
  5. This may not be possible for the OP to do, but.....
    The longest life of a hose will be achieved by making sure the hose flexes in its length, NOT at the crimped ends. Picture a "U" shape, with the ends firmly attached and the ends moving up and down relative to each other. This places all flexural movement in the body of the hose. Flexing near the ends will stress the braiding in that localized area and lead to early failure.
    Atwater Mike likes this.
  6. Atwater Mike
    Atwater Mike
    "Stressed simply" = 'simply stressed'.
  7. blue 49
    blue 49
    from Iowa
    These hoses are there to flex, not twist. If you limit the twist at the bracket the way you have it, the hose will have to twist and won't last long. You need to configure the bracket so the hose only needs to flex.
    Gary
  8. sunbeam
    sunbeam
    If you put a 90 turn in the line so the hose was parallel to the housing there would be little or no twisting.
  9. Crotty 32
    Crotty 32
    So I’ve mocked up another. No hose rotation, but now the hose is pretty high (bleeding issues ahead??) and I wonder if it will hit the underside of the body - that can’t desirable, either. Also, is this too close to the shock? Seems like plenty of space to me. And the hard line from the hose is just a practice piece. Real deal will be longer. 352CADD7-B0E9-4D5E-AB51-3E681BF4433A.jpeg 84A33278-0192-42E4-A965-05DD25560ED2.jpeg
  10. Kerrynzl
    Kerrynzl
    Go to a local yard sale and find an old ring spanner [wrench] the same size.
    Cut off the handle and grind it smoove and weld it on.
    I did similar with a "chinesium" deep socket , I cut into 4 sections and welded them onto tabs. [for a hydraulic braked trailer]
  11. seb fontana
    seb fontana
    from ct
    ^^^^^^x2. I have had to put a twist in my front brake lines to keep them from hitting things when the wheels are turned. 49 yrs and at least 49,000 miles and and holding up fine. Twelve point frame brackets.
  12. sunbeam
    sunbeam
    I was thinking the 90 would point across the vehicle not up.
  13. X-cpe
    X-cpe
    If the exhaust is going over the rear axle, I would mock that up before finalizing the brake hose location.
    Happydaze likes this.
  14. Marty Strode
    Marty Strode
    RICH B and X-cpe like this.
  15. nobby
    nobby
    1968 Mustang rear Flexi line rock auto, it's a bit shorter and nearly oem
  16. SDS
    SDS
    I'm running into the same placement issue (not the rotational problem)
    The guys at Pete & Jakes say to use Wagner F106330.
  17. '29 Gizmo
    '29 Gizmo
    from UK
    I dont like that style of fixing. Its designed for quick ***embly by the factory. Use aeroquip stainless hoses or use a bulk head connector on the frame.
    Another option is to make a p-clip style clamp to locate that end.
  18. Bandit Billy
    Bandit Billy
    My set up on my PU is pretty much as the OP showed us in the his first post. I welded the tab on the frame rail and used a hose I had made up over at Oil Filter Service in Portland with a ford style tee and a vented bolt.
    I drilled and tapped the axle for the vent since the original vent hole was inconveniently positioned between the u bolts (as you can kinda see below). I sealed it with a hex plug and RTV.
    The new vent location made running the hard lines easier as there are a few obstacles with my sway bar mounted above the axle and the parallel leafs. In the pic the vent is covered with a vacuum cap to protect it from debris as this was early on in the build. I need to remember to remove that damn thing! :cool:
    I used a spacer below the tee so the line could p*** above those u bolts.
    One thing left unmentioned thus far is once the SS hard lines are all attached and secured there is no movement on that fitting or the line on the frame.
  19. Blue One
    Blue One
    from Alberta
    I like my solution to the problem much better than any of the responses so far.
    I have never been a fan of brake lines mounted to the rear end.
    So when I built my RPU I didn’t want any brake lines mounted on my new Quick change.
    I mounted and ran my brake lines to both sides of the frame ending the hard lines on each side just above the brake, that way I could use a rubber hose on each side dropping into the brake.
    Clean and effective and easy to bleed.
    8095E461-3B59-4FCB-BC27-B7513FA49EE6.jpeg 884EC7F3-79DE-4CF4-91A0-0909198E9377.jpeg 25ACF019-B600-4B67-AA5C-975843EF3533.jpeg
    alanp561 and Bandit Billy like this.
