Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Sky Six, tr_rodder, blowby and 6 others like this.
  2. gene-koning
    gene-koning
    Off and on, all summer I've been messing around trying to get the aftermarket cruise control to work on my coupe.
    Way back in May I had a day to get it installed. That was when I discovered the "kit" didn't have everything needed to install it, had to order stuff. Took about a month to get the stuff I needed, and find time to mess with it. Got it all together, it didn't work.
    It took a couple weeks before I had the chance to look at it again, discovered a new switch in the kit was defective. Took two weeks for the defective switch to make it where it had to go, and get the replacement back to me, but it took another week or more before I had time to mess with it again. Still didn't work!
    When I had time again, I called the tech line, did what he suggested. Still didn't work. Called the tech line again, defective unit. Then it was the turn around time to get the new unit, and it it installed. After a quick 30 mile test, it appeared to be functioning.
    Today we finally had a chance to do about a 100 mile ride and test out the cruise. Its the best its been, but I did have to rest it a couple times. It will just be cruising along great, then just quits working. If I shut it off and reset it, it works great until it just shuts off again. I'm probably done dealing with it this year. I suspect the problem is with the installer, or the installation.
    On the good side, it was a very nice day for a ride. We started out at a local park and walked the dog, then took the dog home, and my wife and I went and got ice cream. Then with the temps in the high 60s, blue sky, fluffy white clouds, and a very light breeze, we started on the 100 mile cruise. Did I mention it was a great day to go for a ride?
    TA DAD and j hansen like this.
  3. j hansen
    j hansen
    TA DAD likes this.
  4. blowby
    blowby
    from Nicasio Ca
    Got a new steering wheel, free! A friend won it in at a dinner party raffle, accepted with a 'Gee, thanks for nothing' look. I walked over and asked to see it, he said "Take it, it yours". It's an old Superior 500, little rusty on the back side but perfect on the front.
  5. topher5150
    topher5150
    Got the fender cleaned up some primer, and some dents filled.
  6. 65type1
    65type1
    Gave it a bed and and some fenders
    13C7FA51-AAFE-406A-AA22-FAA8836D3778.jpeg 175B97E5-293B-44A6-B80F-3C130082CDBF.jpeg D3B1324E-5171-4CC2-A1FA-F62DB5717A3A.jpeg
    RICH B, rod1, Rehpotsirhcj and 17 others like this.
  7. gene-koning
    gene-koning
  8. j hansen
    j hansen
  9. mgtstumpy
    mgtstumpy
    Collected the new front seat for the 46Olds the other month and now I have the back seat back, all OEM from Hampton Coach (LeBaron Bonney). Rear trim, door cards etc to come once all the patterns have been made. 309539419_2048623728664578_5724288068071415774_n.jpg
    RICH B, charleyw, 40two and 6 others like this.
  10. James Mattes
    James Mattes
    Adjusted Rocker arms. Painted Rocker covers. Moved on to flushing cooling system. New water pump, thermostat, and all new hoses. Cooling.jpg Rockers.jpg ACH]
  11. topher5150
    topher5150
    I'm getting all geeked up. I just bought a steering double u-joint the sales guy says it's good to 80*. So I'm really hoping that solves a few issues.
    High test 63 likes this.
  12. 57 Fargo
    57 Fargo
    Started freshening up some 318 heads for the barracuda project until I ran into this….
    I’ll throw another head in the hot tank today and see what it looks like. The crack extends past the seat otherwise I would just replace the seat. Oh well.
    TA DAD likes this.
  13. vtwhead
    vtwhead
    And what ujoint was that one? I had bought one a while back and it introduced a lot of slop in the steering.
  14. swade41
    swade41
    from Buffalo,NY
    Sorting out gaskets, ordering studs, washers and acorn fasteners for the permanently mounted valve covers, all the other covers were just temporary, seeing which I liked.
    Then I gave it a sponge bath, first cleaning it's had in several years, the old roller job Rustoleum is still holding up well after 10 yrs
    20221001_170131.jpg 20221003_170310.jpg 20221003_164724.jpg 20221003_170348.jpg 20221001_170832.jpg
    TA DAD, rod1, blowby and 11 others like this.
  15. swade41
    swade41
    from Buffalo,NY
    Parts came in
    Gloved up to do battle with the never-seez
    And got those 427 M/T's on the engine for good, rolled it over a few times to make sure the rockers cleared my trimmed downed drippers, all seems good to go.
    hammer-time, rod1, blowby and 8 others like this.
  16. Pontmerc
    Pontmerc
    from Finland
    I was moving my toys in winter storage positions.black merc started without jumper alttough been sitting alla summer and last winter.
    Well, decided to give it a quick powerwash.then realise it should have inspected 2018.
    Call to local isnpection place, yes we have time...
    So, no checkin lights or joints brakes, why, it was all good last time....drove there and now have 4 year permit.its a historical wehicle registered.
    Get back and give it a good bath.now have to change fresh tires and give it some road time. 16650563972657033475729314857308.jpg
    TA DAD, swade41, j hansen and 2 others like this.
  17. WB69
    WB69
    from Kansas
    A little weather striping replacement.
  18. junkyardjeff
    junkyardjeff
    Finished ***embling the engine after a cam swap,can not believe it took me so long and just need to mix coolant and fire up.
  19. Pontmerc
    Pontmerc
    from Finland
    Et voila' New shoes.now its a little bit hot rod. 16650619452815097821445914273364.jpg
    Chavezk21, TA DAD, Papas32 and 5 others like this.
  20. CME1
    CME1
    I rebuilt the starter switch in my 1942 Ford. Now I don't have to use my hot wire to start the car each time I want to drive it! :rolleyes:
    RICH B, osage orange and j hansen like this.
  21. fastcar1953
    fastcar1953
  22. swade41
    swade41
    from Buffalo,NY
    I separated wires in preparation for the install in the 41, to replace the one I melted down
    Then I got my McGard (made in the U.S.A.) conical nuts in, so I put the Bart skinny slots on the Henry J
    impala4speed, TA DAD, LAROKE and 3 others like this.
  23. Black_Sheep
    Black_Sheep
  24. gimpyshotrods
    gimpyshotrods
    I re-patterned a pair of aluminum slot wheels, that I will use for the duration of the build, and road testing.
  25. Cooon
    Cooon
    In my F100, I can’t seem to get the brakes quite right. It’s all new MC, shoes and drums all round and they bleed up well, but the pedal is only about 2” from the floor so when you brake it ends up on the floor before much happens.
    I think I have them adjusted properly, shoes are just skimming the drums, any thoughts on this?
    TA DAD and 26 T Ford RPU like this.
  26. ROADSTER1927
    ROADSTER1927
    Adjust your brake shoes closer to the drums.
  27. fordf1trucknut
    fordf1trucknut
    I installed an old wrecker boom in my model a pickup...
  28. RICH B
    RICH B
    See if this helps. Tighten the adjusters up as tight as you can get it; then back them down so the shoes lightly rub.
    X-cpe and Cooon like this.
  29. Slopok
    Slopok
    Let me guess, Hoffman group??? :rolleyes:
  30. RICH B
    RICH B
    Been a while that I got anything done on the car other than fender work. But; today I found a hidden out of the way place to hide a non-traditional electric thing and made some brackets to hold it there. Also managed to convince the repop glove box to fit the hole in the dash. My rear bumper guards came back and as soon as I find a little thicker gasket material they will be taillights. Now if my rear fenders would get out of the paint guy's jail house, I would have a lot to put together IMG20221019151109.jpg IMG20221019151120.jpg IMG20221019104805.jpg
