Projects Good combo for a low cab?
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Dec 24, 2016.
  1. nunattax
    nunattax
    what ive learned from driving my 38.leg room is tight thin out the seat back.i used 3/4 ply with 2"foam.next time i use aluminun 2mm sheet and gain 1/2 inch extra legroom.5 10 200lbs.cowl vent good but wind out screen gives great ventilation.column shortened helps a little bit too.grab the 1/2" where you can they all add up.plenty of sound and heat insulation helps a lot.enjoy it
    tb33anda3rd likes this.
  2. KJSR
    KJSR
    from Utah
    I'm pretty sure the bare metal low cab was built in Utah by @zippeay. It was sold a while back.
    Another bad *** low cab truck is
    This was built by @STEELJUNKY also in Utah. I'm not sure if he still has it.....I haven't seen him in a while.
  3. mitch 36
    mitch 36
    I have to agree with the fellas about room in the cab. Chopped and channelled is only going to be comfortable for REAL LITTLE GUYS, honest. My 36 has a seat from a small OT Chevy truck, it's very comfortable due to the way I set up the seat and the pedals/ column. If the cab was any smaller, it would ****, be aware of this or you'll not enjoy driving the truck. As for the frame and suspension, you're on your own, my opinions don't matter much . Mitch
    nunattax likes this.
  4. iwanaflattie
    iwanaflattie
    Sorry about the late response.
    Im going with the 35 frame with 1950 front axle,juice brakes,55 rear axle,6 lugs and parallel leaf springs all around..
    A 270 gmc with an ellis dual intake and homemade split exhaust manifold,I came accross a 69 muncie 4 speed today so.ill pick it up after work...
    Hope to find some time to work lt...projects keep ac***ulating
    received_407465300542181.jpeg received_459771698528492.jpeg received_261723265306866.jpeg received_120015736685083.jpeg received_127213909271705.jpeg
  5. iwanaflattie
    iwanaflattie
    Found a frame and started mock up...
    I'm going to spot weld the axles so I can bolt wheels and tires to move around the yard..
    This frame is pretty stout.. 3/16" thick..
    Toms Dogs, F-ONE, Okie Pete and 2 others like this.
  6. RMR&C
    RMR&C
    from NW Montana
    Dude, how many projects are you working on at once? Wish I had your drive....
    Rock on!
  7. iwanaflattie
    iwanaflattie
    I have the gmc coe going pretty daily now and this 37 and the diamond t van an hour here or there..
    Toms Dogs, Okie Pete and rod1 like this.
  8. nunattax
    nunattax
    what i should have said was seat back from 2mm aluminumwith a 90 degree edge bent allround with dimpled holes all over to add rigidity.3/4 tube at back top and bottom with threaded inserts to hang the back from..could hinge at the bottom to access behind seat for storage .c
  9. nunattax
    nunattax
    that looks nice but what size guy will fit into it.or see out of it you will need legs and neck shortened,smaller steering wheel and run an auto
  10. iwanaflattie
    iwanaflattie
    I'm a little guy I think I can make it work.
    I drove to Bakersfield yesterday and bought a 270 from a hamber..
    Then today started to mock suspension.
    I'm torn between using the 35' frame clip or modifying the big truck frame.
    I also found parts that I cleaned a couple years ago.
    20220925_080749.jpg 20220925_080756.jpg received_422982739961685.jpeg received_1476819952744618.jpeg received_489322356164493.jpeg received_413798264237360.jpeg received_2249761005191376.jpeg received_638696767699865.jpeg received_1523867851408290.jpeg received_524218022844960.jpeg received_636902884806058.jpeg received_8074085239299413.jpeg received_5880803881979836.jpeg
  11. iwanaflattie
    iwanaflattie
    The big truck frame is wider and the front and rear leave spring mounts are different.
    I had to stop and take a break from the sun.
    Okie Pete likes this.
  12. iwanaflattie
    iwanaflattie
    This is how a dezert rat gets it done.
    Toms Dogs, F-ONE, Okie Pete and 4 others like this.
  13. Bandit Billy
    Bandit Billy
    Vegas, you can feel the heat and the sweat. Cool project, I'll tag along.
  14. iwanaflattie
    iwanaflattie
    It wasn't that hot today but I felt the heat today...it was 91° but felt hotter...maybe it was the 10 hour trip I made yesterday.
  15. RMR&C
    RMR&C
    from NW Montana
    Seth, if it were me I'd use the '35 front frame half and finish it out with sections of rail from the other frame or even rect tube. Will the frame have a kick up behind the cab?
  16. iwanaflattie
    iwanaflattie
    Tubing is getting real expensive here so I might have to use the frame I have,cut the crossmember and pinch the frame 6" and weld the 35' horns or like you said...graft the 35 to the frame...im going with the underslung frame so no kick up...maybe a c notch on the rear.
    RMR&C likes this.
  17. iwanaflattie
    iwanaflattie
    Progress stalled because I found **** to do on the gmc coe,I did pull the coe outta the garage,made a table for the fat ******* 54 hydramatic trans.
    The trans was sitting on 4 wheels and tires I bought last year. Few miles on them and stored inside...tires are like new.
    They have the 6 lug pattern I want...
    Maybe next week I'll bbq and call some friends over to help me move the frame to the garage so I can work on it.
    Toms Dogs, tb33anda3rd and Okie Pete like this.
  18. Okie Pete
    Okie Pete
    Check out the Barbecue Stovebolt special. It’s frame was modified so it could be low and run parallel leaf springs
  19. iwanaflattie
    iwanaflattie
    Thanks It's super cool
  20. Okie Pete
    Okie Pete
    You got a 270 GMC six to power Your pickup. KOOL
    Check out Buffalo engineering for split exhaust manifolds
    Roseville Rod and Customs for cast aluminum intakes
  21. iwanaflattie
    iwanaflattie
    I made these a couple years ago,I think I'm gonna make another set,
    I also have an Ellis Dual manifold with matching carbs. 20180321_201515.jpg I think I'm gonna have to steal them from my TV stand.
    Just Gary, tb33anda3rd, RMR&C and 3 others like this.
  22. iwanaflattie
    iwanaflattie
    You can see the dual manifold here
    tb33anda3rd, RMR&C, F-ONE and 2 others like this.
  23. Okie Pete
    Okie Pete
    Very nice decor
  24. iwanaflattie
    iwanaflattie
    20221009_140658.jpg 20221016_102221.jpg 20221016_102235.jpg 20221016_102247.jpg 20221016_110756.jpg 20221016_114631.jpg 20221016_114655.jpg 20221016_142848.jpg 20221016_145028.jpg 20221016_155937.jpg 20221009_140704.jpg Sooooooo...
    This weekend felt like working on this pile o ****.
    Last week I moved **** around,fuked my shoulder blade and wrist while doing it,didn't realized til Tuesday...
    But I've been managing with pain killers and alcohol(not at the same time)
    I kicked the Diamond T out or the garage and moved the 37 gmc in...by my self and some ratchet straps...I hate my gravel backyard.
    This weekend I pinched the big truck frame,modified the front horn and started to bolt some suspension parts.i also reversed the leave springs...
    please let me know if something looks funky,,,it's been a few years since I messed with this front end. 20221009_140704.jpg
    20221009_140658.jpg 20221016_102221.jpg 20221016_102235.jpg 20221016_102247.jpg 20221016_110756.jpg 20221016_114631.jpg View attachment 5544836
    tb33anda3rd and RMR&C like this.
  25. 51504bat
    51504bat
    Don't know exactly what you did to your shoulder blade but you should get it checked out if you haven't already done so. I tore my rotator cuff but I have full range of motion after the surgery. Not so the case for my BIL and another friend. My advice is error on the side of caution. JMO
  26. iwanaflattie
    iwanaflattie
    I'm thinking of getting it checked out...hopefully just a sprain
  27. iwanaflattie
    iwanaflattie
    Not really working on this thing but everytime I trío on something that belongs to this project I pick it up,take it to the garage and mock it/bolt it to this dam truck.
    I.e. I had **** sitting on top of the front horns and spindles were bare.
    I was tripping on the tires and had to roll the truck out to clean the garage..started to bolt rotors and drums etc and for sure I'm missing bolts and a bearing etc...finally had a roller but now I just looked at my set up and the scrubline is really low..bout 2" below rim of wheel.
    So either flip frame or have someone heat and raise the ibeam instead of dropping it...
    I really like the look of the under slung frame
    Will have to take a pic later..
    Bandit Billy likes this.
  28. iwanaflattie
    iwanaflattie
    I have a 1957 Chevy 3 speed with OD...I'm wondering if I should keep it for this project or sell it...I have someone interested in it but Im still not sure if I want to use the 3 speed,or the 4 speed sawinag,4 speed Muncie or the OD??
    Ideas??
  29. Up to you.
    If you were closer, I’d try to swap ya out of the OD
  30. iwanaflattie
    iwanaflattie
    I'm leaning towards using it
    anthony myrick likes this.
