Technical Yeah, Its got a Hemi/41 shop truck
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, Jun 29, 2018.
  1. Wholly ****! It looks like a truck again!!
    Stogy and Bandit Billy like this.
  2. For you being such a detail guy and me being the Critic I am and only because we are friends (I think) I have to ask you, What's up with all those fittings on the inlet side of the Fuel Filter? Sorry but if I didn't ask someone else was going to.
    Bandit Billy likes this.
  3. Roothawg
    Roothawg
    Man, look at you go!
  4. Bandit Billy
    Bandit Billy
    I absolutely love this part, re-***embly. All the detailing, installation of all my neat little things I built over the last few years and everyday in every way it get better and better.
    Buddy, I figured if one fitting is good, 5 or 6 would be way gooder! It is just the hard line end, the 90 degree and a swivel to tighten.
    Painting really slowed things down, I don't want to rush things as this is my winter project this year. If I build it too quick I will have to housework or Christmas shopping or something, ugh the mere thought.
  5.
  6. Bandit Billy
    Bandit Billy
    Anyhoo, it'll have a hood...I hope
  7. hotrodA
    hotrodA
    Amazing! That’s gorgeous. Thanks for the incentive to get back on mine.
    Still fugging around with the 283 engine install in the coupe.
    The things that interfere and slow me down seem to come faster and be more involved.
    One of the side effects of old age. I really need to focus on my productivity. Or lack of it.
    bchctybob and Bandit Billy like this.
  8. Bandit Billy
    Bandit Billy
    They longer they sit the more I forget where I put stuff. That is really the reason I work as fast as I do. :cool:
  9. Bandit Billy
    Bandit Billy
    The flooring in the PU will be rubber and actually would have been done by now except I f'd it up. I bought the uncut rubber floor from Carpenters 'cause my brake pedal is a hangy not an erecty, however I needed to cut the steering column hole...uh yeah, I cut it on the wrong side. It seems that when I put it in I had it upside down. What a dumb ***. Anyone with RHS need a truck mat? :cool:
    I did apply sound deadener to the entire floor and firewall including under and behind the seat. I added carpet over that on the firewall down to the toe board where the rubber mat will be and the under seat area including the sides of the seat riser. Odyssey PC925 bolted in it's final resting place.
    This is my new Glide seat frame that opens to access the under seat area which will contain all my electrics far from the eye of p***ers by.
    Sound deadener is SecondSkin and it is applied in the front kick panel areas and up the back of the cab. I ran out and ordered another box to complete the doors and the remainder of the cab.
    I added the brake pedal bracket and the gas pedal. I have to install the cowl vent and motor, the Newport wipers and then the Vintage Air in that order as it gets tight under there. Then I can make up my AC and heater hoses. I am taking advantage of not having the doors on right now.
  10. Dick Stevens
    Dick Stevens
    Why not use the F'd up rubber floor covering to cover the firewall instead of carpet so it would look like it belongs in there?
    Pist-n-Broke and Bandit Billy like this.
  11. Bandit Billy
    Bandit Billy
    Well...because I hadn't thought of that yet? Not bad ****, not bad at all.
    bchctybob, Roothawg and Dick Stevens like this.
  12. Bandit Billy
    Bandit Billy
    I haven't had a lot of time to work on the truck due to an indoor show I entered my roadster in last weekend but I did find some garage time yesterday.
    I installed the column drop. This is a piece I built out of a connecting rod and polished, the bolts that secure it to the dash also secure the steel brace I built that runs to the brake pedal bracket. The bracket braces the dash as well as the pedal ***embly. I still have to add a couple of nuts back there on top. I made it in two pieces for ease of installation. You can also just see the ground bus on the firewall. I welded studs to secure it early on so there is no bolts through my firewall.
    I also started adding some of the switches to the dash (becuase that is the box I opened). There are only 4, ignition, headlights, fog light and wipers. They all got some cool chrome steel bezels I dug up on line. The Wiper switch is going to require a custom nut that I will have to build. 7/16 24 and it needs to be deep reach like an inverted GM headlight switch retainer with female threads. The jeweled lights are my e-brake warning (red), fog light (amber) and there will be a green one just because it makes it look like a traffic light. Not sure what I will use it for.
    I installed Vintage Air AC and since I purchased directly through them they are allowing me to borrow the crimping tool to make my lines. I should receive it by the weekend. I just have to install the under dash unit and mock up those lines inside the car. The engine bay is already mocked up. Over in the corner peaking around the inner fender are the water heater lines. They line up nicely with the compact ac unit as the water lines are in the bottom of the unit, AC lines are up top. The receiver drier is mounted to the inner fender using an aluminum fuel pump mount that I sourced on line.
    Every little bit get's me closer to the finish line.
    bchctybob, Stogy, The 39 guy and 7 others like this.
  13. Tim
    Tim
    from KCMO
    Green could be blinkers or high beam. Though high is typically blue
  14. Bandit Billy
    Bandit Billy
    The Cl***ic Instruments cluster I purchased has the blinkers and high beam indicators built in. Good idea though.
    Stogy likes this.
  15. milwscruffy
    milwscruffy
    Just pigtail off the high beam indicator light and put it to the green light, so you have two high beam indicator lights that way. For the most part neither will be on much. Or you could make it a low bourbon indicator warning light.
  16. Tim
    Tim
    from KCMO
    Oil pressure light? Chrome needs polished light, Back up light, gas low light, you need tacos light, make people ask questions light, your phone charger is powered light, car is running light ~ favorite cuz it’s green ;)
  17. Bandit Billy
    Bandit Billy
    That sir, would not be green!
    Stogy, milwscruffy, MRW1994 and 2 others like this.
  18. 64Pony
    64Pony
    That engine is deserving of a line lock tied to that green light for some Smokey moments. Truck is looking great!
    Bandit Billy and Tim like this.
  19. Parking brake reminder light?
  20. X38
    X38
    You left the iron on warning light?
  21. DDDenny
    Only need three lights!!!
    High beam
    Low beam
    Low on Jim Beam
  22. patsurf
    patsurf
    jim beam wouldn't quite measure up...
  23. DDDenny
    I know, but nothing rhymed with Makers Mark!:D
    Hamtown Al, Stogy and Bandit Billy like this.
  24. Bandit Billy
    Bandit Billy
    I like it but I usually know when the line-locs are set...my balls start sweating.
    It doesn't have an iron. It does have seat heaters, hmmm
    You guys are killing it today! Low on Jim Beam.:cool:
    Everything goes with Makers Mark. I was watching Return of the Pink Panther the other night and Sellers was drinking Kalua and Ginger Ale, that's disgusting.
    Stogy and Desoto291Hemi like this.
  25. DDDenny
    Cripes Billy, did you run out of things to polish!!!
  26. Bandit Billy
    Bandit Billy
    It's embarr***ing but I need new buffing wheels for my polisher. You would think i would have a kitchen cabinet full of them and mother's polish. But that would be crazy, right?! Who the hell would stock their kitchen with car stuff :rolleyes:
    Baumi, bchctybob, loudbang and 3 others like this.
  27. DDDenny
    Uh, maybe @Moriarity
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    Duh...... gotta use the kitchen for something....
  29. Since it's a shop truck, maybe hook the green light and a safety beeper up to your transmission reverse switch. Or is it NOT really a shop truck?
    Stogy likes this.
  30. Bandit Billy
    Bandit Billy
    Well, it was built in my shop, painted in my shop, ***embled in my shop so I guess that makes it a shop truck right?
