Hot Rods Homogenized ‘28 roadster build
Discussion in 'The Hokey Ass Message Board' started by Anderson, Oct 24, 2021.
  1. Atwater Mike
    Atwater Mike
    Critics act like you're goin' ta Tube-axle it at a Jeepers' Jamboree!
    Jacking it was an extreme example. :p:cool:
    E.C., Tim and Tman like this.
  2. Anderson
    Anderson
    Took a not quite o/t picture of the definitely o/t project with the roadster rolling stock on it…and the same on the ‘57 while I was at it.
    Just Gary, Jibs, Deadbird and 18 others like this.
  3. Rolleiflex
    Rolleiflex
    Love the stance you've got going on.
    Are you setting up the suspension setup like the one you had a Dogfight years ago?
    And forgive me if you've mentioned it already, but what size and brand are tires and wheels?
  4. Anderson
    Anderson
    Thanks! Yeah, just bolt on ch***is stuff. Not as crazy with customizing, will appear mostly stock externally.
    These wheels are polished American Racing TTOs 15x5.5” front with 5.60-15 firestone/Coker and the rear are 15x7 with 28.5” Towel City recaps.
  5. Rolleiflex
    Rolleiflex
    Should be really nice, can't wait to see the end results!
    Thanks for the info on your wheels/tires.
    Anderson likes this.
  6. Tim
    Tim
    from KCMO
    Saw this and thought of you this morning 17D7CA32-E8B8-4B20-8F17-FAEF09D5D0A8.jpeg
  7. Anderson
    Anderson
    The Gathering helped realign my priorities. El Camino is on the back burner, roadster is front and center again. Did some welding today on the ladder bar mounts, engine mounts, steering box recess, and front spring notches. #gatr2023
    D8ADE30F-DDCF-4D17-B7BB-35BAA7B1AE87.jpeg 966B539D-8B44-4BC4-9EAB-82323FFAC8CF.jpeg 01F0FAAB-F5CB-4A5E-A4A0-E85B64120773.jpeg 4F1EBBD3-4CBF-4859-B68E-80EEA0A291BD.jpeg 8C139607-ED87-48EC-AC5F-361F8B15F1F7.jpeg AC19BFA3-1DEF-4D27-AFF9-4DB91CFDBAF3.jpeg
    -Brent-, Just Gary, dvsz28 and 24 others like this.
  8. Tim
    Tim
    from KCMO
    **** yeah! Get after it :)
  9. Dan Hay
    Dan Hay
    Cool. I thought I saw you there from a far but wasn’t sure. Glad you’re back on it!
    chryslerfan55 and Anderson like this.
  10. Hitchhiker
    Hitchhiker
    Homogenized is looking pretty good from here
    Anderson and oliver westlund like this.
  11. Anderson
    Anderson
    Picked up a parts car today…
  12. KKrod
    KKrod
    Nice Eric!
  13. Tim
    Tim
    from KCMO
    Awesome, those spare tire arms are hard to come by! I’m sure someone else will take the left overs. Good buy!
  14. caprockfabshop
    caprockfabshop
    Parts car? Let me know if you're going to sell the body! I wouldn't mind having that for my old A ch***is!
    ~Peter - Lubbock-
    chryslerfan55 and WC145 like this.
  15. Parts car? That's a builder!
    brEad and WC145 like this.
  16. bschwoeble
    bschwoeble
    Please don't mount the rad./ grill shell forward of the crossmember. It makes the "29" on deuce rails look like an aardvark. It's all about proportion. Great build. Your approach is spot on.
    Just Gary and chryslerfan55 like this.
  17. Anderson
    Anderson
    I initially thought I might use the whole body but my cowl and doors are in great shape and better than this one. It was going to take forever to get all the little bits and pieces to build the rest of the body and I need to save as much time as possible to get the car done for the Gathering. My p***enger quarter is ok but the other side is really rough. And I wanted as much original sheetmetal as I could get. So the new plan is to use the back half of this car for mine. This new car has everything I need. It also looks a lot nicer than it is. It isn’t bad…but they did do patch work all around the bottom. It’s certainly not too nice to cut up. I will more than likely be redoing the patches in the quarters…but it’s all the brackets and braces inside that make it worthwhile. I’ll ***emble this one back together with my old parts and a few reproduction pieces and it’ll still be a good car for someone who has the time. It would also be a great candidate for making into an RPU.
    I also might see if I can make this thing run. The engine does spin.
    13ADE890-29DD-474B-B141-8C9DEF284673.jpeg 28C62F57-C8C8-443D-BD59-C8C6B1E475CB.jpeg 57B24EF1-B09E-4217-9166-505FC0835EA4.jpeg
  18. Tim
    Tim
    from KCMO
    Well then if your not gonna use the spare tire arm I am looking for one lol.
    Looking forward to seeing it rubble into Oklahoma!
    brEad and Anderson like this.
  19. Anderson
    Anderson
    Well I had yet another distracting project…I sold the daily and bought something much cheaper and a little more “economical” but I couldn't leave it alone. It does also help insure I don’t bring home anything else to get in the way! But now that’s done, and the funds left over from the whole deal are getting put to use rounding up all the rest of the parts I need. This weeks arrivals include some rear brakes and a third member. This one from speedway is a new nodular iron case, 31 spline, 3.89:1 gears, and limited slip. By far the cheapest option available. Even one from Quick Performance was more expensive and used a factory cast case. I’ve been a party to these speedway diffs in a few other cars over the years and not seen any problems with them.
    B02AF142-6F00-4B04-BC2A-51BFF4E33862.jpeg 257A2851-C604-47FA-8D64-B21F9C49B37C.jpeg
  20. Anderson
    Anderson
    Some progress. I hadn’t actually put a third member in the rear end housing before. So this morning I did…it took a little but more clearancing around the flange inside the back of the housing for the left side bearing cap. Finally got it taken care of, trimmed the axles and installed them with the brakes. Re***embled the ch***is and mocked up the two halves of the body. I needed to see the whole thing again. I think I’ll narrow the rear and another inch per side now that I have a better idea of where the quarter panels sit. Starting to think about header plans some other details.
    BBD6FC2C-459E-4FFB-97C7-940F51ED53BE.jpeg A14843E8-9C48-42EE-95AF-6E98FEA48FEE.jpeg 47796956-22CA-4736-B21E-DE2CB0B21A0F.jpeg
    And the other one is back together to hopefully find a new home soon. It is listed in the cl***ifieds and I don’t plan on parting it out.
  21. Anderson
    Anderson
    Got a little more time in on it tonight
  22. alchemy
    alchemy
    Are those Corvair taillights?
    Dan Hay likes this.
  23. Anderson
    Anderson
    Yup!
    panhead_pete and Dan Hay like this.
  24. Tim
    Tim
    from KCMO
    Looks ****ing great!
  25. Anderson
    Anderson
    Not sure how much further I’ll get on the headers this weekend but I got my flanges made. Original Hedman’s are 5/16 plate, but I already had a bunch of 3/8 so that’s what I used. Bought a few carbide hole saws off of Amazon for $12 each but only used one for all the holes, pretty impressed. I have abandoned my original pie-in-the-sky plan of some crazy 180 degree headers for some more traditional ‘lakes headers’. Going with a real split ‘35/6 driveshaft for the main cone. Found some 4” radius bends from summit that should work well for the primaries. Have to figure out how to get from the 1.5” to the driveshaft piece, but time will tell!
    C27933E2-8B6C-4AE5-8998-DFE6FDA3B1B5.jpeg 346DD6B2-06CE-4083-B7BF-3F79F311659B.jpeg 32C7003E-4C02-4021-9F14-B22EBE91DD30.jpeg
  26. Anderson
    Anderson
  27. Tim
    Tim
    from KCMO
    Man that white roadster is killer. Thanks
    For the updates
  28. Anderson
    Anderson
    That’s the McGee/Scritchfield roadster. I think I’m going to make a pretty close version of these headers. I was wondering how they made the transition from the front primary to the driveshaft since the driveshaft is so much bigger….here’s the answer I guess!
    02934450-9360-43A9-A62E-F239937A7CD4.jpeg 8F718DA8-3CBE-4E28-B7BC-A54F046B8D7E.jpeg
  29. Tim
    Tim
    from KCMO
    Good stuff :)
  30. Dan Hay
    Dan Hay
    DBFC1307-D1CB-41E1-BADA-E9E2BEF0A56F.png I was watching a video today on YouTube, Piero at Mad fabricators is cloning tweety pie. They made the headers and it looks like from the front primary into the cone they made relief cuts to soften the transition. Here’s a ****py screenshot
