  1. swade41
    swade41
    from Buffalo,NY
    Thanks, that'll get my idea across to him
    Rot 'n Kustom likes this.
  2. Movinman
    Movinman
    I just picked up a 52 Mercury that was customized in the 80’s. I love everything about it except the front grille treatment. You guys do some amazing work. Can you restyle this front end? Maybe a 54 Pontiac grille? 55 Desoto? I’m open to ideas. Thanks!
  3. Rot 'n Kustom
    Rot 'n Kustom
    Great score! If this were my car, I'd avoid the cliche grilles and go for something clean and different.
    I used a 1954 Lincoln Capri or Cosmopolitan grille and bumper combo. I deleted the three lower vertical bars, but you could use them if you like. I also reworked the hood scoop to better complement the new face.
  4. Rot 'n Kustom
    Rot 'n Kustom
    Here's the Lincoln grille stock.
    hotrodjack33 likes this.
  5. Movinman
    Movinman
    @Rot 'n Kustom love this idea. It works well with the hooded headlights! Thanks!
  6. Acres
    Acres
    from Sweden
    Did this photoshop lowering of my Buick, maybe i should get the grinder and start cutting coils.
    40two, OahuEli and themoose like this.
  7. themoose
    themoose
    @Movinman
    Here's another idea.....clean and mean
  8. Movinman
    Movinman
    @themoose damn it! I do like that! What is that front bumper from?
  9. caprockfabshop
    caprockfabshop
    Looks like a 1954 Pontiac.
    ~Peter
  10. Unclebrad
    Unclebrad
    8D398629-293F-4036-8164-DE1FAEA4A5DD b.jpg 56 T-Bird grill w/o the bumperettes.
    40two, Peanut 1959, Rand Man and 2 others like this.
  11. Ned Ludd
    Ned Ludd
    I gave this one a go, as I've been playing with layer modes in Gimp: Swade41 gasser with fade.jpg Too subtle?
  12. themoose
    themoose
    Yes it is but I think it would take some modifications to make it work...
    Peanut 1959 and Movinman like this.
  13. silent rick
    silent rick
    narrowing it down
    on the above image, the brick structure just above the carbs always bothered me, can we make that disappear to give the carbs more definition?
    and speaking of the carbs, can we change the intake to a 6x2 dragstar?
    then, most important, add a lake style header that's capped off with a cut out running downward and under the frame to tie into the exhaust seen poking out under the car?
    i've decided on the 6 carbs but can't make up my mind on whether to run stock exhaust manifold or the lake header tying in to an under car exhaust.
    still some welding and fabbing left to do, fit the turtle deck, sand it down to bare metal, good winter project. if you want to make the changes to the actual car, here's a photo of it.
    thanks guys
  14. themoose
    themoose
  15. silent rick
    silent rick
  16. hotrodjack33
    hotrodjack33
    Hey guys,
    A few years ago, I did a deal with @Hamtown Al and he ended up with my old Sedan Deliv...and then spent months "de-greening" it...busting my *** the whole time. 0.11.jpg
    Anyway, Al is building a new Roadster Pickup and is undecided on the wheel color.
    Hot Rods - Is this a Brookville roadster pickup? Update: NO. Now building 1929 roadbriolet/cabrioster pickup | Page 22 | The H.A.M.B. (jalopyjournal.com)
    If someone could add my green wheels, caps and rings to his RPU so I could post it on his build thread (giving full credit to the photoshopper of course). I think Al would love it...and hate it at the same time;)
  17. Unclebrad
    Unclebrad
  18. hotrodjack33
    hotrodjack33
    Holy **** @Unclebrad ...That's PERFECT:D
    Gonna post it over on Al's build thread...this'll be great.
    Thanks so much,
    Jack
    Hamtown Al and lothiandon1940 like this.
  19. swade41
    swade41
    from Buffalo,NY
    Thanks man, I'll send this to him, I told him either the Winfield stripe or panels done with the old yeller
    Ned Ludd likes this.
  20. waylow64bird
    waylow64bird
    from Buffalo MN
    Can somebody put this paint job on this 64 tbird
  21. jimmy six
    jimmy six
    ^^^^ Looks to me you already have it just a different color. Pealing clear coat is not attractive to me but might what you are looking for but tough to replicate without time and elements.
    lurker mick likes this.
  22. OahuEli
    OahuEli
    from Hawaii
    While you're at it, maybe chop that top a bit? 6. 1952 Buick Acres chopped.jpg t?
    40two, Acres, hotrodjack33 and 2 others like this.
  23. Flamed48
    Flamed48
    Can one of y’all put the rockets on the 56 please and thank you
  24. themoose
    themoose
  25. OahuEli
    OahuEli
    from Hawaii
    Seeing the picture of the '56 F100 picured above got me thinking about the paint job on my avatar. After taking the truck apart in 1996 to drop in the 429, four speed, 3rd cab and fibergl*** front clip, I ran out of time and couldn't paint the bed and rear fenders before finishing the re-***emby of the truck and moving from VA to CA. (hence the U-Haul trailer).
    I'm not too good at photoshopping paint and would like to request the help of my fellow photoshoppers to finish it up. Any takers?
    Eli
    Jim Bouchard and lurker mick like this.
  26. OahuEli
    OahuEli
    from Hawaii
    Re the previous post, here's a side shot if that helps. (As you can see, photography is not exactly my forte) :D 11. yep, they're hooked up!.jpg
    40two likes this.
  27. Unclebrad
    Unclebrad
  28. themoose
    themoose
    @OahuEli
    Here's something to take a look at...Time to get the spray gun fired up!
  29. madfish
    madfish
  30. Rot 'n Kustom
    Rot 'n Kustom
    55 Ford Eli Final 2.jpg @OahuEli
    In lemon yellow. Cleaned up the background, too.
