Customs Has anyone 3 window swapped a 40 ford coupe. Not just filled quarter windows.
Discussion in 'The Hokey Ass Message Board' started by Hitchhiker, Oct 9, 2022.
  1. Hitchhiker
    Hitchhiker
    Like the ***le says, has anyone 3 window swapped a 40 Ford coupe? Not just filled the quarter windows, but changed the roof line? Think 36 3 window roof on a 40 ford....maybe even lengthen the doors?
  2. Kiwi 4d
    Kiwi 4d
    Earl Bruce coupe nick named “the armoured car” you can see why.It may be historic but that doesn't make it nice. It needs what @Hitchhiker mentions.
    Okie Pete, warbird1 and Hitchhiker like this.
  3. JimSibley
    JimSibley
    I would like to think I have seen it done, but I am not sure. Seems like it would look alot like a willys.
    Hitchhiker likes this.
  4. 40Vert
    40Vert
    Here are a couple of pics of two different styles.
  5. tubman
    tubman
    Ya' know, I really like how it looks, but it's just WRONG!
    slayer, seadog, jimmy six and 5 others like this.
  6. Hitchhiker
    Hitchhiker
    Exactly what I was talking about! Thanks!
    hrm2k likes this.
  7. X38
    X38
    Several have tried. I haven't seen one that was an improvement. I think the dark blue one above is about the best. The others are all pretty much deformed.
    mgtstumpy, brEad, F-ONE and 2 others like this.
  8. Hitchhiker
    Hitchhiker
    I was thinking poormans Zephyr. But willys would be spot on.
    caprockfabshop likes this.
  9. Tim
    Tim
    from KCMO
    There was a gl*** 37 three window made at some point. Might be worth looking Up for a point of reference
  10. Interesting idea Hitchhiker.. That said, those fibregl*** '37 three windows missed the mark in my opinion as the window opening and roofline were distorted somehow - much like the primer example 40Vert showed. I agree that the blue example looks much better. This conversion really requires an exact replica (or transplant) of Ford's '36 three window. It's proportions are spot on.
    As I said, interesting idea and I bet the fellows on the Photoshop thread would jump on this one. ..Maybe a slight chop as well?
    -Dave
    Rolleiflex likes this.
  11. X38
    X38
    There have also been multiple photoshop versions over the years too. That gl*** one was hideous. Wasn't that supposed to be a 37?
  12. Not a '40, but here's how it should be done:
    -Dave
  13. RMR&C
    RMR&C
    from NW Montana
    This looks good. Any more pics of this one?
  14. 41woodie
    41woodie
    Many have tried, many have failed.
  15. That's a tough one to pull off but the 39 above looks to have pulled it off from the angle of the photo.
    seb fontana likes this.
  16. Hitchhiker, do you have a 40 Coupe your thinking of cutting up?
  17. adam401
    adam401
    Ive kicked the idea around for years. I think the ticket is to use 2 door sedan doors on a coupe with the b pillar moved back. Door tops of course would need extensive work.
  18. Fogger
    Fogger
  19. 40FORDPU
    40FORDPU
    It may be easier to accomplish by putting a '40 front end on a '36 3 window, if someone feels the need.
    I'm like most, love the '40 Ford for its overall look, which includes the roofline (except for the '40 Convertibles, my top will always be down).
  20. moparboy440
    moparboy440
    from Finland
  21. stanlow69
    stanlow69
  22. Dan Hay
    Dan Hay
  23. X38
    X38
    the 38 has a different roof shape to the 39/40 in the crown to deck transition, so is easier to pull off. While a couple are pretty good efforts I still haven't seen a 39/40 that would make me want it more than a stock version.
  24. goldmountain
    goldmountain
    A forty three window just looks wrong.
  25. toolz
    toolz
    Tow Truck Tom and warbird1 like this.
  26. BamaMav
    BamaMav
    from Berry, AL
    I dunno. Why mess with perfection? If Henry thought a three window 39-40 looked good, he would have built one…
    Tow Truck Tom, RICH B and seb fontana like this.
  27. choptop40
    choptop40
    Foose Sr. 1940 chopped 5 window was amazing..to each his own .......
  28. finn
    finn
  29. 1934coupe
    1934coupe
    Not exactly the same but "Dutch" Comstock from Herkimer NY did a 46ish Ford coupe into a 3 window. The guy was on here must have been 4 years ago. Car looked good, Dutch did quite a job.
    Pat
