Projects The Build Without (Now With) a Body
Discussion in 'Traditional Hot Rods' started by LostInOC, Jan 27, 2021.
  1. grumpy gaby 2
    grumpy gaby 2
    Lookin good to me for first test!
    LostInOC and Six Ball like this.
  2. Six Ball
    Six Ball
    from Nevada
    My mom & brother upholstered his '39 coupe except for the seat. Headliner, doors, package tray, kick panels, & carpet. It was near perfect. Yours is looking good just don't make yourself any sundresses. :eek::D
    LostInOC likes this.
  3. LostInOC
    LostInOC
    Now it’ll fly!
    Got a wild hare to strip the fan and polish it up like an old prop. Made sure it wasn’t too blingy. Body is on for good and the doors close nicely. Running out of time to paint before the cold weather sets in. May need to wait for spring to lay down some color. 0BEAF632-DEFB-4841-949F-E1DEF6D47A4D.jpeg
    41 GMC K-18, Texas36, burl and 9 others like this.
  4. Six Ball
    Six Ball
    from Nevada
    Very cool!
  5. grumpy gaby 2
    grumpy gaby 2
  6. LostInOC
    LostInOC
    Cut and polished the tank. You can polish a turd!!!
    Got rid of all the fish eye and 99.99% of visible scratches from 4 days of sanding.
    F6554981-9C37-4F13-ACDA-91B57B014DB0.jpeg 9FC392A8-A8C0-4800-A29A-E0352FD90F5B.jpeg 497AABEA-47BA-4BA7-8EA5-254D7E3ED647.jpeg
  7. rusty valley
    rusty valley
    Nice job. I put yellow tips on an A fan once, its kinda nice to see when running, and a good visible reminder to keep your fingers outa there ! Carry on.....
  8. LostInOC
    LostInOC
    Tried to install the tank welt tonight. What a pain in the ***. Contemplating leaving it off. Worried the the welt line will crack after painting, like every other A I’ve seen. What are some good options?
  9. LostInOC
    LostInOC
    Most difficult thing on this car as of yet…..tank welt! Damn thing better not squeak. 39BE1E5F-F8DE-4732-A988-112ED06853FD.jpeg
  10. Tim
    Tim
    from KCMO
    Dang that dash looks great! Got me excited to paint mine eventually
    brEad and LostInOC like this.
  11. LostInOC
    LostInOC
    Installed one of them fancy *** Carter fuel pumps and now have all sorts of fancy *** challenges to get everything plumbed. The goal is to hide the pump and regulator behind the firewall so all you see firewall forward is the gl*** bowl and fuel line. Got the new radiator in and polished the shell up a bit. Couldn’t resist mocking up the intake and exhaust with the newly scored Thickstun air scoop. Damn it, I’m getting antsy to drive the car!!!!! Figured it might be a good idea to put a small fuse box up in the drivers side cowl area now there’s a bunch-o-e-lec-tronic doodads going in.
    Looked at all the old receipts today, that was dumb.
    She needs a name, whatcha think? 404ED875-30A3-4B96-A503-44B3F7D67EF8.jpeg B4596543-4345-4AAF-9CE2-12E732629B00.jpeg 2002BE4B-867A-4A27-BD9F-2B0FC1CC974F.jpeg 6E104005-EB34-4D41-896C-928160369096.jpeg 944CE16A-2789-40B1-8967-2F2D674AB2C0.jpeg
  12. 41 GMC K-18
    41 GMC K-18
    The Hamilton Standard Propeller sticker on the polished fan blade is cool. I am sure you will be looking for a smaller one of those that is porportionally correct, but that will do for now!
    Atwater Mike, Outback and LostInOC like this.
  13. LostInOC
    LostInOC
    Fuel system is in place. Tried to minimize the visual impact from outside the car as much as possible. You can just barely see the fuel in and out lines exiting the firewall below the gl*** bowl, outside of the firewall.
    The routing is as follows:
    Tank valve>Hard line through firewall>soft line>carter pump>soft line>Holley fuel pressure regulator>soft line>hard line through firewall>fuel bowl
    All the hard lines through the firewall are protected with rubber grommets. Not super excited about how pliable the aluminum “hard line” is but at least I have great patterns for future steel lines if the aluminum proves to be an issue.
    Bought a fancy *** Optima red top battery and installed it, electrical to come. Cooling gets plumbed next, then it’ll be time to start the car.
    Good luck making heads or tails of the pictures….
    9EE1EF21-0D32-439A-B551-1C790610B491.jpeg 4E7EDC49-55FF-4C2A-AB45-1FFA9C0FD0F4.jpeg 2F28E232-74A7-48DE-9153-DBDD61961D7A.jpeg
  14. Six Ball
    Six Ball
    from Nevada
    Man! This thing is really coming together with cl***. I spent the day rewiring most of my solar system. I do much better when I'm plumbing stuff I can see. Leaks are safer to find. :eek::rolleyes::D
    Outback likes this.
  15. LostInOC
    LostInOC
    Well, she runs….she runs damn fine.
    Lots of blood, sweat, tears, hours, money, doubt, joy, and anticipation to get here. F-ing stoked!
    J.Ukrop, Tim, rusty valley and 8 others like this.
  16. grumpy gaby 2
    grumpy gaby 2
    Sounds MIGHTY FINE!!!!!!
    osage orange and LostInOC like this.
  17. Six Ball
    Six Ball
    from Nevada
  18. That's the most beautiful banger sound I've ever heard! I can't wait to hear it at cruising speed.
  19. LostInOC
    LostInOC
    Purists look away…
    A7BC12CE-C140-4FA1-9A3A-DDA848FD62D3.jpeg 10CF5BE6-E8B7-4D88-91A6-1AE217B92905.jpeg
    brEad, ottoman and Six Ball like this.
  20. LostInOC
    LostInOC
    Gauges are in and wood is stained/finished in spar urethane. Bought a fancy polished aluminum column mount but it was too tall. A quick trip to the bandsaw, grinder and drill press solved that. Everything works as it should. Now just a little tidying here & there and she’ll be ready to cruise around the block. 21BEF477-FED4-4E39-8453-E8D2DB225E5D.jpeg 7EA0E90F-0B43-43F3-A86E-BC6906443A51.jpeg 4C79B2A8-7D42-46DB-A891-ECD4B014F951.jpeg 54F744ED-5D42-485A-A0E8-46B0A8E3245F.jpeg
    Tim, 41 GMC K-18, Vic Walter and 5 others like this.
  21. LostInOC
    LostInOC
    At least when I don’t get pulled over for speeding, I’ll know how fast I’m going (speedo installed). Also, replaced the brakes.
    Still not certain the car should be black. Found some vinyl wrap in blue grey for poops n grins. Tried a spot to see how it looks. Whattaya think…..blue or black? C172B4E4-00DF-4576-B69A-307FD7834606.jpeg CF59191C-7D9B-4211-A18D-E395B2C7313A.jpeg
    brEad, Six Ball and 41 GMC K-18 like this.
  22. Six Ball
    Six Ball
    from Nevada
    MY basic rule is that real hot rods are black. At least it is a safe bet and saves an otherwise nice build from being spoiled by a stupid color choice. That said I like that blue. You could vinyl wrap the whole thing and avoid runs & over spray. :rolleyes:
    brEad likes this.
  23. V8-m
    V8-m
    from Alaska
    Maybe mixture to lean....
  24. LostInOC
    LostInOC
    Fully rebuilt the engine and am now running the same mixture, never gets above 150°. I replaced the radiator this time around. I believe the old radiator let some **** go and clogged while I was driving. A combination of heat and pistons without expansion slots led to the issue. I now have Egge pistons with expansion slots and a temp gauge to keep an eye on things. Knock on wood, haven’t had a single hiccup since the rebuild.
    brEad, V8-m and Six Ball like this.
  25. rusty valley
    rusty valley
    Black is my vote. Driving time will be here soon, ya better get to work !:D
    Six Ball, brEad and V8-m like this.
  26. LostInOC
    LostInOC
    Finally getting some color on the car. Pretty cool brother team that owns a local old skool shop with some really neat stuff on the property shot it. Cut and buff this weekend. 75AB34A8-AECB-4B20-BD46-C0B67819E827.jpeg 27BC22FF-71E1-4C41-88F4-F65B3AD0440A.jpeg 6CC351DB-632C-4843-BE10-F939EB51782B.jpeg C2A36940-10C7-4CF4-AB3C-36D45A818175.jpeg 31A06BB4-08FE-4DFF-9EEC-E103DFCBF0B1.jpeg D52F314F-16FF-4BB6-A636-DC5C74C56403.jpeg
  27. Outback
    Outback
    from NE Vic, Oz
    No pics here?
    48fordnut likes this.
  28. LostInOC
    LostInOC
    I see the pics on my side. Here’s a couple more. Just about to roll it outside. C6739C13-E823-41DC-809D-D820B7B3A9D7.jpeg E63EC57D-F7A4-4921-B540-1EA0BC9D3072.jpeg
  29. 05snopro440
    05snopro440
    Wow, looks great!
  30. RodStRace
    RodStRace
    looks like it's ready for a good cleaning of the masked off sections to match that Beautiful Black finish!
    The Blue tulip panel looked nice, but that Black is chef's kiss!
    LostInOC and Outback like this.
