rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. 427 sleeper
    427 sleeper
    Agree with Mike... There's no good reason that didn't blow the back of the motor off... other than sheer luck!!! :eek:
  2. squirrel
  3. patsurf
    patsurf
    Calkins likes this.
  4. 57 Fargo
    57 Fargo
    Glad you caught it Brian.
    mad mikey, racer-x and 427 sleeper like this.
  5. DDDenny
    Time to buy a lottery ticket Brian!
  6. 427 sleeper
    427 sleeper
    Does the torque converter show signs of fatigue , also?
  7. milwscruffy
    milwscruffy
    Count all ten toes and be happy !
  8. Hey Brian ,
    Did you say you went 85% recently,,,or was that just for an exhibition ?
    I remember you recently went through the converter,,,,,,and I’m certain you examined the flywheel while you had it out .
    That means it happened quickly or was hidden from site at the time .
    Could the new converter contribute to this ?
    Man,,,you got lucky with this find,,,,,,,and yes,,,,,that’s a very expensive part to replace !
    Tommy
  9. Johnboy34
    Johnboy34
    from Seattle,Wa
    That part is a lot cheaper than it could have been, being so diligent is a blessing.
  10. seb fontana
    seb fontana
    from ct
    What is the material, ie, 6061, 7075, etc?
  11. That's why I check things carefully. I changed the stator again in the converter. I saw the damage as I was wiping off the flywheel prior to putting it all back together. Over the off season last year I upgraded to a Browel 360 degree bellhousing. It will contain a explosion but I don't care to test it. The other big issues would be at speed and the fluid comes out of the converter. It's a huge fire risk hitting the red hot headers. The other big issue is fluid getting under the tires.
    The converter looks fine. I don't think the extra nitro is the cause. My thought are the heat treat. It will go back to Boehr Racing to be examined. A few teeth were also missing from the starter ring. Like they just snapped off. im just glad I caught it in time. My regular servicing regiment will now include a careful inspection of the flywheel going forward. I will be on the phone first thing tomorrow
  12. I forgot the material it's made out of. I know it's special. I will find out.
    When I take out the converter I leave the flywheel on the crank.
    Increasing the nitro percentage makes for a slower burn. This reduces the chance of harmful detonation. I don't think the nitro was the cause.
    The clearance from the converter to flywheel is set at a minimum of .150
    The converter under load balloons that much according to Coan. I will be calling them also. Maybe there is pressure pushing against the flywheel. After all it's a flex plate. It might be flexing too much.
  13. The 39 guy
    The 39 guy
    So glad to see you found that before disaster struck. You have chosen sport/hobby that can be very dangerous. After watching your thread for the last couple of years I can see that your attention to detail and caution are keeping you as safe as you can be. I am happy you caught it . Thanks for sharing.
    mad mikey and racer-x like this.
  14. Updates. The material is 4140. It's cut into discs to get the heat treat all the way to the center. Some companies don't do this and have a soft center. They are gas nitrided. They are heat treated to 28hrc. They told me the treating process is no longer used in their products. They are now black oxided. They have also changed the shape of the windows along with some other details. I was told they see these surface crack. Most times the crack doesn't go all the way through. Just like high dollar cranks. I think some of my cracks go all the way through.
    The good news is they have the latest design on the shelf. It will be red labeled today. They will cover shipping and gave me a screaming deal on the replacement. That's great customer service. They wanted my pics to look at. It helps them improve their product. It's refreshing to have a company not hide issues or deny they have ever seen a problem. Honest answers is all I'm looking for and I found them. It will go back together after work Friday.
    bchctybob, TFoch, Turnipseed and 14 others like this.
  15. 57 Fargo
    57 Fargo
    Good to hear they are interested in learning and improving their product.
    racer-x likes this.
  16. They make serious race car parts. They are part of Bonnafontti racing. Good companies do that. Replacing a part intended for nitro racing and covering red label shipping is unheard of.
    bchctybob, TFoch, SS327 and 4 others like this.
  17. DDDenny
    Gotta wonder how many cars did actually experience something worse than a "close call" before they re-engineered their flywheel.
    Budget36 likes this.
  18. 55Belairretrorod
    55Belairretrorod
    from Australia
    Reading between the lines, I wonder if the treatment process they were using was hardening the material too much and making it somewhat brittle, hence not allowing it to flex enough? Way above my pay grade, just thinking out loud.
    racer-x and SS327 like this.
  19. mad mikey
    mad mikey
    That is very good news Brian. A upgraded part.:)
    racer-x and Desoto291Hemi like this.
  20. Yeah,,,,,4140 sounds right .
    I knew it wasn’t any aluminum,,,,,especially with the starter gear teeth made on it .
    Sounds like they already knew they needed an engineering change .
    But,,,,,racing is what helps make the everyday components we enjoy today.
    Make it ,,,and break it,,,,,,,find the point of failure .
    Great job Brian,,,,,,this thread ,,,and hot rodding in general,,, is why we enjoy so many vehicles that last many thousands of miles .
    Tommy
    chryslerfan55 and racer-x like this.
  21. tomcat11
    tomcat11
    After cringing at the pictures of that flex plate last night I went to the website and the first thing noticed was the change in the window shape and how they added considerable material to the failed area. You have to wonder how many earlier designs failed. It's a serious eye brow raiser thinking about the converter ballooning .150" and wonder how long before converter fatigue sets in.:eek:
    Budget36 and SS327 like this.
  22. I know several racers that use the earlier design without failure. I was told there were some inconsistencies with the heat treat process.
    All converters balloon some. To combat that race converters have anti ballon plates on one or both sides of the converter. This is nothing new. Setting up the clearance so as the converter balloons it's not bottoming out against the pump.
    The new flex plate is showing up Friday. I will put them side by side to see the upgrades. The pics will be posted.
  23. 57 Fargo
    57 Fargo
    There’s always room to improve things, shows they are p***ionate about their products. As they should be.
  24. tomcat11
    tomcat11
    Yea, nothing new there. Nice to see a company offering that level of customer service as well as component upgrades. That is one high maintenance street/strip machine!
    racer-x likes this.
  25. lippy
    lippy
    from Ks
    What about a pedal clutch system. Lippy
  26. A clutch would be the answer on a strip only car. It just won't work on the street.
  27. lippy
    lippy
    from Ks
    Could you elaborate a little? Lippy
  28. A clutch needs constant adjustment. As the clutch wears it allows more rpm at the hit. Clutches are adjusted after each p*** or two. Now put hundreds of miles per day on a clutch. The converter is the same all the time. Every time I want to go get a ice cream or drive to work I don't want to pull the floor and reset the clutch. It's labor intensive and time consuming.
  29. indyjps
    indyjps
  30. Hemi Joel would you like to share your experiences with a clutch on drag week?
    57 Fargo and squirrel like this.
