Projects T on A : Fjant the complete novice builds a hot rod
Discussion in 'Traditional Hot Rods' started by Fjant, Aug 2, 2020.
  1. panhead_pete
    panhead_pete
    Great to see you still chgipping away at this! :)
    Fjant likes this.
  2. I took the braces out each side on both my T’s and made a steel floor to go right across at about that angle. Bonus is you can use the A pedals unmodified.
    Fjant, AndersF and 48fordnut like this.
  3. Also I found an AA handbrake that sits a few inches back and misses the T fuel tank.
  4. Fjant
    Fjant
    from Sweden
    that sounds like a god idea. Well the pedals are adjusted and the floorboard done. But I will save the design idea for the future. I guess it gives a little bit more room for the foot.
  5. Fjant
    Fjant
    from Sweden
    So got the dash done and kind of mounted. The gaugepanel will be filled when I find a Speedometer. The gaugepanel was very rusty and heavely pitted. I just put it in acid bath and put some paint on. Might look for a better one in the future. 54522BAC-084C-4A0E-8758-645A9043639C.jpeg 7C7FF831-AAA2-4C18-8361-372C5C48A07F.jpeg
    1biggeorge, sko_ford, hfh and 10 others like this.
  6. Atwater Mike
    Atwater Mike
    My '27 tub sits on an 'A' frame also. (temporarily, while I repair sub rails and some sheet metal)
    My 'gl*** '27 roadster is temporarily sitting on my '32 frame, which will go under the tub.
    Too many T's spoil the tatter...
    Fjant likes this.
  7. Fjant
    Fjant
    from Sweden
    Well, I have told my self not to do ”unnessesery”stuff on the car until I get it running. But when I lifted the body the other week to do front body mounts I kind of got an urge to do some body work. Since the lower panels are just bent and dont have any shape (that need an english wheel) I was able to do these patches with an hammer as only tool. For beeing my first body work ever I think i went pretty okej. Still need some finishing touches thu. I also replaced the bottom 1,5 inch of the subframe.
    I do need to make a new panel that sits at the door. Seen in the picture you can see that it will be hard to repair. 22A9144C-89F4-4093-9334-26DC8435A149.jpeg 4CEFFC30-4BEA-4071-929F-9A2B902DCA2B.jpeg 168EF5C3-04CE-4048-B995-D0DB2910A0A1.jpeg 3AEA9414-C729-43D6-B032-5B1F6BEA5699.jpeg 8C55C12B-7C37-4CAC-96F1-2F1395C2FEAA.jpeg C334138A-3702-49E4-8217-73E98A6FAD2C.jpeg
  8. nunattax
    nunattax
    nice work there bud.that panels a sieve if i ever saw one chris
    Fjant likes this.
  9. nunattax
    nunattax
    a couple of coats of high build primer and a sanding would have it looking like new.
    Fjant likes this.
  10. Fjant
    Fjant
    from Sweden
    Yeah. Thats the plan. I will paint it att the bottom for now, and hope I can make it look as it is kind of the faded original colour.
    nunattax likes this.
  11. nunattax
    nunattax
    thing is a couple of blemishes give it a bit of character
    Fjant likes this.
  12. brEad
    brEad
    Nice work on your patch panel!
    Fjant likes this.
  13. Fjant
    Fjant
    from Sweden
    Thank you!
  14. Fjant
    Fjant
    from Sweden
    Spent a little time trying to do beads without a beadroller. Hard to make it really good. But I think I’m on to something. 980D7E59-EBD6-4EDF-AD9E-E8D0C049F121.jpeg
  15. Fjant
    Fjant
    from Sweden
    Put some rattle can paint on the repair and mounted with the front body mounts I made looks better than before i any way. 842BD318-F935-4419-BF6D-315EB2E9C25B.jpeg 74C9FEF7-23B9-4640-9775-B2073A222A4D.jpeg 9509469A-563D-4DFA-AFD4-B8A733A55F6F.jpeg
    Outback, don colaps, Tim and 10 others like this.
  16. nunattax
    nunattax
    it looks the finest . nice work
    1biggeorge and Fjant like this.
  17. Fjant
    Fjant
    from Sweden
    Tank you so much!
  18. nunattax
    nunattax
    let the truth be told
    Fjant likes this.
  19. v8flat44
    v8flat44
    Love it !! You're doing a GR8 job on this build.
    Fjant likes this.
  20. Fjant
    Fjant
    from Sweden
    Tank you so much!
  21. Fjant
    Fjant
    from Sweden
    9E34D614-55D4-453B-B0F0-38E6430CA0D4.jpeg 0F5F878B-BFBF-40EE-8640-CD7297DF9C3D.jpeg 536DB684-F066-431D-92A1-9C062D851630.jpeg 4C3216D3-B482-4663-9A5D-4877E0EF287A.jpeg So I started doing some eletrical wiering. Not my strong side att all. I really have to work hard to understand it. But I do think it’s kind of fun anyhow.
    I have just taken apart and renovated this old power switch. I think it looks really good. Earlier today I installed A headlight switch in the floor. I belive it comes from my old -32 plymouth.
    Allso, I found i that the pad that puches the stoplight switch was so worn that the botton has gone straight thru it.
  22. Fjant
    Fjant
    from Sweden
    5DE8A256-92F4-4F52-A907-2232EEC36844.jpeg 6A5833C5-AC0D-4142-A36E-F75464E4C708.jpeg D819E896-E9B2-4361-9BED-D1F51FF2EF0E.jpeg 376C8C39-257B-4F84-AD24-6BED7DDB771B.jpeg F4F31AC4-C439-4A4C-A734-4FD8E9F9E0F8.jpeg 5003F498-011F-42D7-A326-8718614C0307.jpeg 5F658519-9CCE-4DCA-B768-B517E0324308.jpeg 1AA3C809-F009-421F-9285-0B43144F9C06.jpeg 3BD921AB-1059-4969-B576-80F7C0FBA91A.jpeg After many hours fiddeling and researching auto elecricity I finaly got most of it done and working. I have some more to do around the engine and generator (i’m looking for an generator to hook up to my 12 v system).
    I also got some new wheels, big and little. These have much better tires and I could sell my old for the same I bought this set for, wish of course always is nice. But the big tires really made the rear look high. So I have started to found and grind of the edges of my model-T spring so I can mount it and get it some what lower.
    hfh, 1biggeorge, don colaps and 6 others like this.
  23. patsurf
    patsurf
    YOU should have been a "denizen of the dry lakes"-this is very 1947 in california--just get it done (well) w/ what you have--bravo!
    Outback, don colaps and Fjant like this.
  24. Fjant
    Fjant
    from Sweden
    thanx man! That means a lot!
  25. Kume
    Kume
    Builds like this motivate me to get back onto my T build. Thanks for your posts.
    Outback and Fjant like this.
  26. Fjant
    Fjant
    from Sweden
    Yeah! Do it! ❤️
  27. Enjoying the simplicity of this , you are doing great and it will be all yours.
    Sweden is a great country to cruise in.
    Outback, j hansen and Fjant like this.
  28. Fjant
    Fjant
    from Sweden
    Thank you! Yeah it is!
  29. Fjant
    Fjant
    from Sweden
    06346A10-B2E1-431A-9DCD-851CDCC47CF1.jpeg 9B77F97F-4F0D-4AC8-A530-985673AF0202.jpeg 61B0F9C4-3832-4C84-BD3B-80CCDC03F59A.jpeg The choke rod was heavealy interfeared by the T-gastank so I came up with this solution. Still needs just a little fine tuning. But seams to work fine!
  30. 1biggeorge
    1biggeorge
    Fjant likes this.
