Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Six Ball
    Six Ball
    from Nevada
    When my youngest son was 6-7 we were pulling weeds in the yard nee the shop. He pulled up a string with a rusty pointed weight. He asked what it was and I told him a plumb bob. He said. " Sounds like a Walton. Good night Plumb Bob!" and tossed it in the trash pile. Sorry I never see or hear one mentioned without thinking of that day. :D
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sometimes things just come together!
    Hahahah we used to watch the Waltons all the time when I was a kid. I can totally see where he was coming from!
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    We're rolling into a jam-packed week, but I figured I'd post a progress photo from over the weekend. IMG_8528.jpg
    I can't stop thinking about it. Full update happening soon.
    JalopyJimbo, catdad49, Stogy and 22 others like this.
  4. Tim
    Tim
    from KCMO
    I can just see this from a clip of my
    Three sons, or maybe happy days in the drive way in front of a white painted single car garage tucked next to the house/ back yard.
    Stogy, J.Ukrop, Outback and 1 other person like this.
  5. Six Ball
    Six Ball
    from Nevada
    Or the perfect '36 Wally took home and parted out in the driveway much to the dismay of June & Ward.
    Stogy, J.Ukrop, Outback and 2 others like this.
  6. Dick Stevens
    Dick Stevens
    I was thinking more of Bud in Father Knows Best.
    Stogy, J.Ukrop, Six Ball and 5 others like this.
  7. Outback
    Outback
    from NE Vic
    It looks great, you must be so excited!
    Stogy, J.Ukrop and Six Ball like this.
  8. Looks like you may make RPM to race next year. :)
    Stogy, J.Ukrop, rod1 and 3 others like this.
  9. warbird1
    warbird1
    Lookin' Good!
    Stogy and J.Ukrop like this.
  10. sshep
    sshep
    Looking good, keep up the nice work!
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hahah that's how you know it's of the era! I'll have to take some black and white pictures of it again.
    Stogy, Six Ball and Tim like this.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! I keep on going back to the pictures and smiling. David sent me this shot from the shop this morning. My reply? "The gang's all here!" IMG_0141.jpg
    That's the plan, Tim. Hopefully I'll have a lot of the kinks worked out by then.
    Thank you!
    Thanks! Just taking things one step at a time.
    catdad49, Stogy, Mikko_ and 5 others like this.
  13. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I just finished writing a feature article for print that I'm extremely excited about, so I figure I better strike while the iron is hot. Let's dive into a roadster update.
    Last Saturday, I had two distinct projects in mind. First, I planned to re-install the radiator, grille and headlight bar. Second, I would focus my attention to the pedals.
    Just like on Version 1.5, I wanted to make rubber gaskets for the headlight bar. I cut pieces of reddish rubber to shape at home and drilled holes. When I showed them to David, he suggested that I hit them with his hole punch. Note the wood block backing. "You have a tool for every job," I said.
    When I put the headlight bar into place, I could immediately sense something wasn't right. "What changed?" I asked myself. The answer? Nothing. The more I looked, the more I realized the headlights were way too far forward. I hadn't picked up on that last time.
    Undeterred, I reconfigured everything and drilled two more holes in the frame.
    This puts the headlight bar in line with the shocks and tucks it closer to the grille. Coincidentally, the base of the bar is in a nearly identical position on Version 1.5 and 2.0.
    Once everything was in position, I couldn't help but grab an old step stool and jump behind the wheel. David handed me a banjo wheel and I was off to the races. This was the first time in a long time I've sat in the car. Talk about an exciting moment.
    Getting a feel for things.
    Imagining pedal and steering column placement—and dreaming of watching this wheel roll as I drive down the road.
    A friendly reminder from @Lucky Burton. I love that it says that my lucky day is Saturday.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 10.15: Leveling Up
    Right before lunch, I started cleaning up tools. As I did, I kept on looking at the ch***is sitting in front of the shop. There was no doubt about it: things are really coming together. I felt confident in the work David and I had done thus far, and everything looked good to the eye. Yet, for whatever reason, I felt the need to test it one more time. I walked into the shop and grabbed a bubble level. I set it on the headlight bar and took a deep breath.
    It was almost perfectly level.
    Back when David was building bicycle frames, Bruce Gordon told prospective employees that if they couldn't see a 90 degree angle, they should just pack up their things and go home. From day one, David saw the right angle. He went on to work with Bruce for more than a decade.
    When I saw that level, I felt a sense of relief—and I thought about David and that story. I thought about all the pieces that had to work in concert to make that happen. Wheels, tires, spindles, front axle, shackles, spring, U-bolts, headlight bar, frame and more. These are all things we had our hands on to get this far.
    As we sat down at our card table for lunch, I told David about our success. "That's what happens when you do things the right way," he said. "Now take off that level. It's blocking our view."
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I started working on the pedals. After consulting Vern's book, we decided that the '39 pedals would be the way to go. David gave me a few pointers on the dis***embly process.
    Off with the old master cylinder.
    Then I ground down the head of the pin and drove it out with a punch. Much to my surprise, it slid out easily.
    Then I soaked the pedal ***embly and drove out the main shaft with a br*** drift.
    Once I had all the pieces on the faux wood paneled table, I was able to inspect them.
    A new shaft and bushings are on their way.
    I then made a template for the plate that will be added to the K-member. I'll be cutting this out of 10 gauge next time I'm at the shop, and David is going to show me the best way to get everything mounted.
    Stogy, Shadow Creek, Jeff34 and 10 others like this.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    As the day wound down, I rolled the ch***is out towards the middle of the lot for a mini photo shoot. The lighting was good, and it's never been more complete.
    For me, this was huge. You guys know how much time and effort we have in this ch***is. You've been here every step of the way. I know we're far from finished, but it felt really good to take a step back and see it on all four wheels outside of the shop.
    Oh, this reminds me that I still need to clean up those headlight stand pads!
    So there you have it. I left the shop feeling great. I'm excited to jump back in next time I'm there and keep trucking on the pedals.
    That's all for tonight!
    Gambler 1962, cactus1, Stogy and 25 others like this.
  17. BigJoeArt
    BigJoeArt
    Good stuff man! headlight placement on point.
    I actually just had a buddy bring over a headlight bar last night to mock up mine.
  18. Tim
    Tim
    from KCMO
    Fantastic update. I remember the first time I sat the 46 on four wheels and tires and it really did feel like “wow! I’m almost done!”
    all the work going into a hot rod ch***is to make it hold drive train, steer and roll. No one but someone who’s done it knows how many times you’ve stared at it sideways making sure that cross bar lines up with the shocks and the fronts of the headlights hit the perfect spot of the ark of the front tires.
    It would almost seem the more simple a ch***is the more staring and tweaking that’s been done.
    now all that’s left is the rest!
    I’ve been reading my build thread on my A trying to remember where I left off a year ago and knowing My ch***is isn’t far from where yours is has really put some excitement back into the day dreaming.
    Stogy, Outback, Budget36 and 4 others like this.
  19. Tim
    Tim
    from KCMO
    D8778638-CC2F-42B0-BF8F-EC027AE315D7.jpeg I can see this in the back of rod and custom
    magazine advertised as “new Ukrop foot warmer for those foggy nor call roadster mornings!” With a simple line drawing and a po box to send funds to
    Stogy, J.Ukrop, 41 GMC K-18 and 2 others like this.
  20. Excellent progress Joey!! You never realize what a triumph it is to get to the point you are with the build. Most would look at it and wonder where the rest of the car is. Until you have pieced one together you don't have the appreciation for just how much work it took to get to this point.
    Well done and loving how every piece is falling into place. Well thought out and executed!!
    Brian
    Stogy, J.Ukrop, Outback and 4 others like this.
  21. Malcolm
    Malcolm
    from Nebraska
    Exciting progress, Joey!
  22. Excellent! What kind of clearance does the tie rod have to the frame? It looks like they might might lean in and kiss each other from what I can see in the picture with your boot.
    Stogy, J.Ukrop and Budget36 like this.
  23. Six Ball
    Six Ball
    from Nevada
    Tim said, "now all that’s left is the rest!" How profound! A simple statement to be used in any situation especially in hot rod building. Even when the builder thinks it if finished. Easily up there with "And this too shall p***." Down right Biblical!
  24. Tim
    Tim
    from KCMO
    Hey if Jesus left Chicago and he’s bound for New Orleans, and zztop knew about it ya gotta ***ume he’s rolling in style and knows how this all works ;)
    59' Fridge, Outback and Six Ball like this.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hahaha I can imagine the line drawings in the ad right now.
    Thank you! You're totally right about the asking where the rest of the car is. It reminds of me of one of my favorite quotes, "It's simple to make something difficult, and it's difficult to make something simple."
    Thank you, Nick!
    Nick, you make a good point. By jumping up and down on the front frame horns, I was able to get them to touch a little bit. David and I plan to un-drop the tie rod ends a little bit and then narrow the tie rod some more. I think the Speedway ends are forged, but they kind of look cast to me? If that's the case, we'll have to find another solution.
    What a great way to put it!
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Friday, I made the trip down to LA for Pat Ganahl's Celebration of Life. The whole thing was incredible. So many familiar faces from hot rodding's history books. Pat's son, Bill, and wife, Anna, shared some powerful words about him. He really was a huge inspiration for hot rodders worldwide.
    I usually have a lot to say about hot rod happenings, but I feel like this isn't the time. I may share more later, or I may not.
  27. Marty Strode
    Marty Strode
    Joey, it was good to see you there, you are right, quite a night !
    Six Ball, Outback, Stogy and 3 others like this.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The week before I left was a busy one. On Wednesday night, my friend Erik dove into Part I of a two part photo shoot on Version 1.5 of the roadster. With any luck, you'll be seeing the rest of the set soon. IMG_8618.jpg
    As someone who takes photos for a living, it was interesting (and fun) to be on the other side of the camera.
    The following morning, I hopped in the truck and drove up to Petaluma to make more headway on Version 2.0.
    It all started with helping David with some things around the shop, including a final brake bleed on his customer's 1935 Ford pickup.
    I then focused my attention to my pedals. Since the mounting points on the '39 pedals and the stock Deuce K-member don't align all that well, David recommended that I made a new plate out 10 gauge to weld into position. IMG_8631.jpg Clamping it in place and getting a feel for the general positioning.
    IMG_8629.jpg The sun was out, so we decided to stop at a local park for a leisure lunch. It was refreshing to be out in the roadster and relaxing a**** the trees.
    IMG_8633.jpg When we got back, we had a clear goal in mind: remove that piece of the K-member. We debated whether or not to use a cutoff wheel, and I opted for using the oxy/acetylene torch. After spending a whole lot of time removing the rear frame rails with the former, I figured this would be the more efficient route.
    David gave me a few pieces of metal to practice on. After about 15 minutes, I realized I was as ready as I was ever going to be. I donned my shade 5 gl***es, slipped on some gloves and started cutting.
    As the torch hissed, I worked to follow the soapstone line. A couple minutes later, I pulled the old section out. Next time, I'll be cleaning up the perimeter and tacking the new plate in place.
    Thursday was one of those days where I felt like I didn't accomplish as much as I wanted to. But as I look back, I remind myself that I'm moving closer towards my goal every time I'm at the shop. My pedal pads, cross-shaft and bushings just showed up in my mailbox today, so we should be able to make some big progress next time I'm there.
    Once the pedals are finished, we're going to focus on steering, brakes and firing the engine. One day at a time!
  29. Tim
    Tim
    from KCMO
    Good progress man :)
    Does David ever drop the top on the roadster? Seem to see it up most the time, curious if it folds or lifts off.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks! He usually keeps it on there. If I recall correctly it does fold, but if it's down he takes it completely off.
