Projects '51 Mild Custom shoebox coupe
Discussion in 'Traditional Customs' started by Tony Ray, Sep 12, 2017.
  1. [​IMG]
    Yes, these are 1949 Mercury only. I'm home now and can get you the actual size. I think without the S.S. can do a cut in and mount from behind.
  2. Tony Ray
    Tony Ray
    I been trying to dig out my old ones and can’t find the damn box with them in it. Can’t remember how big they were lol
  3. Atomic Kustom
    Atomic Kustom
    Small right at 1 7/8"
    Tony Ray likes this.
  4. The 50-51 signal lense mounts to a corner piece that is part of the Grill. The signal lense mounts to that part. It mounts to a totally Flat surface.
    The lense coming through the retainer bezel may be in fact be 1 7/8" the total lense is right at 2 3/8"
    Bexel and all is about 2 7/8" od. and totally flat on the back side.
    The 49 Merc is a bit different. Slightly larger overall at 4 1/2" with bezel
    Without bezel 3 1/2" wide. Guess I should get you a height measurement. This unit has a contour that lays nice against the fender, not flat on the back
    This didn't turn out like it looked in the view window. I'll get a better photo next time I'm in the shop.
    Hombre, chryslerfan55, Thor1 and 2 others like this.
  5. Moedog07
    Moedog07
    I don't know how I missed this but now I'm following this thread.
  6. Here's the amount of curve in both the Lense and Bezel. Fit's the Ford fender real nice.
  7. Tony Ray
    Tony Ray
    54delray and Pist-n-Broke like this.
  8. Peanut 1959
    Peanut 1959
    Is it too late to consider grafting a pair of outer grille bar sections from a '53-'54 Studebaker onto the outer ends of your grille bar ***embly? That'll get you turn signals without disturbing the sheetmetal below your headlights.
  9. Tony Ray
    Tony Ray
    That is pretty cool!!
    Peanut 1959 and 54delray like this.
  10. Atomic Kustom
    Atomic Kustom
    Yea don't go below the headlight keep it clean. If nothing else just tuck some small turn signals in on the core support area
    54delray likes this.
  11. Tony Ray
    Tony Ray
    D6F13C2C-DEE4-4DCD-971D-4482FFBACFBA.jpeg 403A3763-4C39-422E-81AD-F16C96EAC22D.jpeg 633CEE99-BAE4-45A6-B4A2-4C878A481BC2.jpeg BBE34D13-CEF7-41FA-9E88-98D3EBFBAAE1.jpeg 796E3D1B-493E-481E-8D21-7BFA3488C47E.jpeg 2BDEBAB7-6FCF-4DFC-9849-6818548EE916.jpeg More pictures of my coupe, from Chopolds shop, Customs by Flash.
    The grille coming together and the quarter windows..
  12. Tony Ray
    Tony Ray
    DB2A0037-EEEF-4B6F-A63C-A5D1B01E955C.jpeg 395A42D1-47E3-41B5-A347-FD865BF8B357.jpeg EA4DDB9C-3263-470D-947F-6BD6AEC9C01E.jpeg 7B5E7E54-5A13-4A94-BEC5-D1165D2BF748.jpeg 3D92C848-87F3-4B94-BC37-AF6279573EBF.jpeg 82DC2C6C-DF59-49F5-A57B-E379E99963EA.jpeg 82E34AB3-C96E-4283-BFF8-E1ACD6085EB0.jpeg C750A519-B353-432C-9801-15343755D426.jpeg DC76C709-C771-4E62-8F61-2431E505184E.jpeg 6628B007-4D36-4F86-87BA-AA7E0B2869E0.jpeg Couple pics from last weekend.. all gl*** is now in except the windshield. Chopolds had to weld up the section around the p***enger side sunvisor. Apparently mice got in the headliner and well you know.. had some rust sports and holes there. Engine is running but the new water pump is leaking. Hopefully just the gasket since that was painted gold. I recently got a seat from Mikey Miranda that originally came out of the ClarkKaiser 53 ford. I had to cut off the white pillow tops off of it. Just couldn’t deal with it. We are talking about putting a small console built into the seat where the notch was cut out for a shifter. But for now I have a seat. The Chrome guy called and my grille is done!! Unfortunately I have to work next weekend so it’s gonna be two weeks before I can finally pick it up.. can’t wait! Wednesday we got the window garnish in and the trunk latch set and adjusted. Now it’s like a hundred little things to do before I can drive it..
  13. brokedownbiker
    brokedownbiker
    Looks like you're getting close Tony! I'm sure the excitement is building (no pun intended, lol). The grille insert looks great; if you're still pondering the turn signals, how about this. If you plan on mounting bumper guards on the front bumper, how about flush-mounting them in the bumper guards? Check out Brad Masterson's Fleetline on Kustomrama, he did it on his rear guards. Just a thought
    Thor1, Tony Ray and chryslerfan55 like this.
  14. bobss396
    bobss396
    Smart to keep a checklist going. All my stock cars had a clip board hung over the windshield. One side of the list was mandatory tasks, the other a wish list.
  15. Tony Ray
    Tony Ray
    So it’s been trying to cross all little things off the list lately so not many updates, fixed a water leak, fixed a gas leak, ****oned up a few things under the car, and trying to decide what bumpers I want to use.. but on the mean time I did score one thing from eBay that I’m pretty happy about.. now just need one more.
    2564C8DE-A897-4FB3-8C45-979949E31CC5.jpeg E50E20E6-BAAD-4311-95CE-80579B0BB223.jpeg D4405CD0-CDCC-4A50-9EC3-870FD7B0100C.jpeg 5C089221-D9A3-4E02-8843-05E03EC37EC8.jpeg 5511B67A-6E2D-4746-9A40-C0F9F07450E5.jpeg 1B25AE41-6BF0-45B6-9B53-FFE60C58D245.jpeg 81DCF8C2-CE00-4185-BFDA-6773F6F0A302.jpeg 52AAA089-901A-471A-B798-2D6164EC1519.jpeg BD71B86D-6C8E-435E-8157-95F1E12CA60E.jpeg E633C9AD-9EB9-4326-BC9C-3ECE7E02006B.jpeg 386B10B9-F469-48EB-B88F-B53047AE7F44.jpeg
  16. Tony Ray
    Tony Ray
  17. Rand Man
    Rand Man
    This looks like a great project. Want to see more.
  18. Tony Ray
    Tony Ray
    So I didn’t post much the other week and this past weekend I had to work, but Chopolds has been hammering on my coupe and sent me some updates.. two major things are done.. the trim is now all cut, welded, polished and on the car! The other thing is the grille is finally back from the chrome shop and he picked it up Monday! It’s so awesome to see something I wanted to try, then see it fabricated up and then chromed.. I can’t wait to get it on the car! Also Mark went on the photo shop post and got a couple guys to do a photo shop of my car. Madfish was able to get a basic shoebox done up and it looked great! Themoose took the picture of my car with all it’s restyling and , man I can really see how it going to be!
    The 55 royal lancer trim finished and installed!
    Madfish photoshop of the colors and trim!
    TheMoose’s photoshop of my actual car!(and he cleaned up Chopolds shop for him! And added some cabinets!)
    my grille after Mark stretched and welded the pieces together.
    grille back from the chrome shop!
    As you can imagine, I can’t wait to get to the shop this weekend!
    Petejoe, BigRRR, juan motime and 11 others like this.
  19. 54delray
    54delray
    from Fremont NE
    Brilliant, excellent, bravo!!!
  20. Thor1
    Thor1
    Wow, everything is looking fantastic! I love the grille, it looks so good in chrome!
    Tony Ray and 54delray like this.
  21. 210superair
    210superair
    from Michigan
    Yeah man, that looks awesome. Looking forward to seeing it ready to roll!
  22. brEad
    brEad
    Going to be a sweet ride! Love the colors!
  23. Tony Ray
    Tony Ray
    Thanks! Came our way better then I hoped!
    Thor1, 210superair and 54delray like this.
  24. brokedownbiker
    brokedownbiker
    She is going to have a beautiful smile!
  25. Tony Ray
    Tony Ray
    2C0924DB-D45E-436E-BE18-055B568EE4C5.jpeg 175E4677-8A46-46A1-849F-C6A3380E9B28.jpeg F814A8D8-2EAD-49AD-82DB-042C8F99A061.jpeg DF0B8008-30F9-4562-9879-71D6745AE181.jpeg 5C16ECAD-6C07-43E0-8605-42F8492C8CAE.jpeg 59352312-2673-44D5-BAA9-D074D6C0DC84.jpeg C14735D6-EB16-43E4-9954-0B8330C9C0A2.jpeg 2D9ADCAF-B652-4078-AD7A-40D8B9599793.jpeg 30825A2B-3B3D-45BB-9583-C502F6FB0490.jpeg More pics from shop today
  26. bobss396
    bobss396
    How did you shorten up the side trim? It really sets the car off.
  27. mikhett
    mikhett
    from jackson nj
    Lookin Good .I like the way your headin.IM 70 so ive had to deal with some medical issues latelyTony like prostrate issues and early onset of Parkinsons but my buddy Mark from KUSTOMS BY FLASH is gonna give me a hand so right now im looking for a SBF mill and C4 ******.THANKS and stay well!!!
    Tony Ray and lucky like this.
  28. Tony Ray
    Tony Ray
    Mark(Chopolds) cut and welded the pieces together, then made a buck to form the ends
    bobss396 and 54delray like this.
  29. Tony Ray
    Tony Ray
    I heard!! Swapping out that y block for it!
  30. Tony Ray
    Tony Ray
    Big update.. car is running, moving, and the grille is installed, and I took my very first ride in it.. can’t thank Chopolds enough for everything he has done. He’s gone above and beyond, and I can honestly say I don’t think he does it for just the money, but for his huge love of Kustoms. I can’t wait until next year when I get it painted t to proudly display the Custons by Fkash badges on my fenders. 353D7EA1-AC8C-4B8C-A514-4AE5C0473935.jpeg AAB1D23F-9CC5-49CA-9339-65D556E64829.jpeg 04B9F721-9F2B-4FAA-96B8-A1C617B60173.jpeg 70101EC7-084F-495D-B3C1-C8C80C894FAB.jpeg ABFA0025-1F63-467F-85C0-78E2A0FCADA8.jpeg FE7F08B9-7352-4413-870B-CA8669BFCC54.jpeg C86F2AFA-8C42-4ED6-9F97-433DB5CE2EF0.jpeg 02B8FB54-EFA6-44E6-A478-E1620AB9E2E7.jpeg 72C3CFA4-D1AC-477C-A40E-F0604E8369F4.jpeg 0679B49B-7915-4DE6-80FC-837649E3443C.jpeg 95A91519-8629-42DF-B3B1-BEAE9CF88DB2.jpeg
    Gambler 1962, lucky, brEad and 6 others like this.
