Projects "Budget" 58 Chrysler Windsor 4dr Hard Top
Discussion in 'Traditional Customs' started by Mopar Tony, Oct 6, 2022.
  1. Mopar Tony
    Mopar Tony
    Part 4 of my 58 Chrysler Windsor. Got it painted but will need redone after a few mistakes.
    3AMideaz, Gotgas and Okie Pete like this.
  2. Mopar Tony
    Mopar Tony
    Looks good over all but will need sanded and reshoot
    Okie Pete likes this.
  3. Mopar Tony
    Mopar Tony
    Couple more pics
    Okie Pete, SS327 and Squablow like this.
  4. Mopar Tony
    Mopar Tony
    Picked up a new paint gun and plan to respray the car this weekend, weather looks decent.
  5. Moedog07
    Moedog07
    I think the Astro gun is superior to the HF purple gun you have used. If you hate it maybe I can buy it from you. I traded my Astro for a Satajet NR95 and a Sata digital. I was better off with the Astro.
  6. Mopar Tony
    Mopar Tony
    Thank you and I will. I was planning on painting it tomorrow but nothing has gone to plan so most likely will be saturday.
  7. ottersea
    ottersea
    Let me know how it works. I am limited on air supply so need on that works with lower air. I am now using a Eastwood Concours LT and works fairly good but would not trust it for final coats.
  8. alchemy
    alchemy
  9. 73RR
    73RR
    The change over occurred for the 1962 model year. 1962 saw a new block bolt pattern and the crank was changed to accommodate the new flexplate drive.
    The only direct fitment is the 55-56 331 and 354. If you put them on a 392 you won't have an intake (except for the individual log type pieces)
  10. Mopar Tony
    Mopar Tony
    Do you happen to have any engine mounts for this era?
  11. theman440
    theman440
    from Las Vegas
    Regarding your motor mounts - the ones on it now look to be '66 -'72 big block b-body mounts. So all you need to find is '66-'72 small block b-body engine brackets. You can reuse you rubber mounts and it will bolt in.
    caprockfabshop and Okie Pete like this.
  12. Mopar Tony
    Mopar Tony
    Part 5 of my 1958 Chrysler
    Okie Pete and Dan Hay like this.
  13. Mopar Tony
    Mopar Tony
    A few pics
  14. Moedog07
    Moedog07
    Looks good to me!
    Mopar Tony likes this.
  15. Mopar Tony
    Mopar Tony
    Thank you, that astro gun was way way better than the other.
    Moedog07 likes this.
  16. Mopar Tony
    Mopar Tony
    Few pics outside
  17. caprockfabshop
    caprockfabshop
    SS327 and Mopar Tony like this.
  18. oldwood
    oldwood
    from arkansas
    Nice to see a '58 Chrysler. Really nice cars. I have a '57 NY'er 4dr HT with every option. Probably never get to it but nothing like owning a 392 Hemi. lol
  19. Mopar Tony
    Mopar Tony
    Man I'd love to have one that complete and original, especially with the 392 in it!
  20. Mopar Tony
    Mopar Tony
    So a little update with the paint, as much as I don't want a shiny paint job I may have to cut and buff this paint. It has been 2 weeks and the paint still seems to scratch so easy. If you rub it with your finger lightly it will scratch the surface, not really sure why. I mixed the paint 8.1.1 with the hardener and had a few days in the 70s and parked the car in the sun and it is still soft.
  21. loveoftiki
    loveoftiki
    from Livonia,Mi
    8:1:1…what kind of paint is this? Flattened single stage of some sort?
  22. Mopar Tony
    Mopar Tony
    Blitz Black single stage satin.
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
    Ok is that tractor supply enamel? I’ve never used it, so I can’t help ya there..but it would really **** to have to get it all off there if you chose to repaint it…which is what you’ll have to do, if you want it done correctly.
    remember what you put additional topcoats over is now your base..and if it’s unstable, you risk major issues down the line
    flynbrian48 likes this.
  24. Mopar Tony
    Mopar Tony
    No it isn't tractor supply but it is john deere paint. I want this paint to last 5 years, and I'll strip and start over. Everyone swears by this stuff and to me it isn't living up to its expectations. I'll probably wet sand and buff it. It is supposed to be valspar paint.
    caprockfabshop likes this.
  25. Moedog07
    Moedog07
    JD Blitz Black single stage has been on many a hot rod. I've seen and heard of it all my life.
  26. Mopar Tony
    Mopar Tony
    Same as me and heard a ton of good things but seems to scratch easily.
  27. Mopar Tony
    Mopar Tony
  28. Moedog07
    Moedog07
    I may have missed it in the video; did you use activator or hardner with the paint? If not it may be cured by spring time.
  29. Mopar Tony
    Mopar Tony
    Yep I used hardner, 8.1.1 mixture
  30. Moedog07
    Moedog07
    You should be good then.
