Hot Rods Another Money Pit, but... Oh Well.
Discussion in 'The Hokey Ass Message Board' started by SOHC427, Oct 24, 2018.
  1. Rickybop
    Rickybop
  2. SOHC427
    SOHC427
    Found a few hard to find parts. A set of Modified SOHC covers, with the rear Breathers, for Fender clearance, and the Hilborn 4 Port, thanks to a Great Hamber. Also a Old Hurst T Handle, with the Metal Roll Control ****on, for my Line Loc. Good times.
  3. SOHC427
    SOHC427
    Here they are
  4. Inland empire hot rods
    from so cal
    Bad*** Dean!
    SOHC427 likes this.
  5. SOHC427
    SOHC427
    Thanks Man, need a Vintage Chute, next!!
  6. The37Kid
    The37Kid
    DSCF0252.JPG DSCF0254.JPG Maybe I should part with the pack from the 9th fastest car at the 1965 U.S. Nationals.
    Bob
    VANDENPLAS, rod1, elgringo71 and 4 others like this.
  7. Inland empire hot rods
    from so cal
    I'll look around at Bakersfield today
    SOHC427 likes this.
  8. SOHC427
    SOHC427
    Well, the Hilborn 4 Port, was a win, pedals are mounted, and Column is next. Also the shifter hole for the V Gate, is in. Slow but sure
  9. wrenchbender
    wrenchbender
    That Hilborn sure looks familiar and looks perfect on there keep up the good work
  10. Inland empire hot rods
    from so cal
    Keep on keeping on Dean!
    SOHC427 likes this.
  11. SOHC427
    SOHC427
    I bet it does!!!
  12. SOHC427
    SOHC427
    Here is a ***y Rear End, like 501's, and the Pretty Blond! Resized_20221114_101329.jpeg
  13. TFoch
    TFoch
    Nice metalwork!
    elgringo71 and SOHC427 like this.
  14. SOHC427
    SOHC427
    Thank you. Knowing the right people helps!
  15. SOHC427
    SOHC427
    Here is the real Cammer, in place. Next will be front engine Plates, Clutch and Slave Master Cylinder, final hood hole t*******, and Headers. imagejpeg_0(17).jpg imagejpeg_0(16).jpg
  16. elgringo71
    elgringo71
    You are making fantastic progress. That Cammer barely fits. There were very few Willys Coupes that had them even back in the 60s.
    Thor1 and SOHC427 like this.
  17. SOHC427
    SOHC427
    This took a few rounds of Re Engineering! I think we have it this time, but as we are all where aware of, there is a lot more to do. Column is on order, as well.
    warhorseracing, Thor1 and elgringo71 like this.
  18. AmishMike
    AmishMike
    Nice build, following. Love willys but always felt rear fenders to body lip messed up from factory design to build. The center of rear fender should be higher to gently flow into body, which body already has. Hope/trust you follow what trying to describe.
    SOHC427 and Thor1 like this.
  19. SOHC427
    SOHC427
    Interesting thought. I never really found a Flaw in these Cars, looks wise, but man, what a Cheap built little Guy!
    hotrodtodd1960 likes this.
  20. Where will the radiator go?
    SOHC427 likes this.
  21. The37Kid
    The37Kid
    Like the scoop cut out in the hood, few hours there I'm sure.
    SOHC427 likes this.
  22. AmishMike
    AmishMike
    I was talking about factory design to factory built. On front fender, body to fender over seam is smooth. On back fender, front and read of fender smooth to body. In middle of rear fender, body has small curve out to fender, but fender is half inch + down from body. I always felt this was factory goof when stamped rear fender & I feel might look better if center rear fender smoothly met curve up into body shell. Do not have body work skills or cash to do it & never seen hotrodder attempt. Seems complicated as hell to cut up rear fender, move center pieces for tight fit to body then make one piece fender again. Hot rodders have followed factory style. Challenge for a chop top builder to put one together ( smile ).
  23. SOHC427
    SOHC427
    Looks like down low in front. There is a bit of room.
  24. SOHC427
    SOHC427
    To many!! But it's a bucket list build!
    Thor1 likes this.
  25. And now for some useless trivia ....
    According to an article in the the Feb 1968 issue of Car Life ... "the SOHC Ford is sold only with cast iron heads, and the aluminum units are sold as replacement items. This should lead to a goodly pile of cast iron heads around the back door of top engine builders".
    The above segment was taken from an article about a SOHC powered dragster owned by Lou Baney, driven by Don Prudhomme and engine builder Ed Pink.
    elgringo71, Thor1 and SOHC427 like this.
  26. BILL LUPIANO
    BILL LUPIANO
    from Canada
    Looks great!Following!
    hotrodtodd1960 and SOHC427 like this.
  27. ccain
    ccain
    Mmmmm. That ****! :):cool:
    If my ex had an *** like that, I probably wouldn't have left her. :p
  28. SOHC427
    SOHC427
    Anymore, finding cast heads is rare, let alone Aluminum, unless you go Aftermarket.
    Thor1 likes this.
  29. SOHC427
    SOHC427
    imagejpeg_2(7).jpg imagejpeg_1(8).jpg imagejpeg_0(37).jpg Blasted, and Primed
  30. SOHC427
    SOHC427
    123_1(3).jpeg 123_1(3).jpeg 123_2.jpeg Getting Ready for Fast Eddie's Shop Party. I will install the Grills and Lights for this. Headers, Cage, and Rear Tube Bumper, are next.
