Hot Rods 32 highboy roadster, tank or no tank
Discussion in 'The Hokey Ass Message Board' started by krylon32, Oct 21, 2022.
  1. krylon32
    krylon32
    from Nebraska
    77 years old and for the first time in my car building career I can't make up my mind. I've built countless deuce roadsters of all configurations. My current project is a Flathead powered roadster with a quick change, A spring and A cross member. I debating tank or no tank, bobbed horns with curved spreader bar or as I've done several with tidy small rolled pans. This is my last project. Looking for opinions, criticisms etc. Getting old ain't for sissies.
    Tim likes this.
  2. 325w
    325w
  3. swifty
    swifty
    No tank makes your 32 roadster look like a Model A. Admittedly it does allow you to show off your QC which is not really visible with the tank in place. How important is that ?
    Also consider why do folks building Model A's go to all the effort of fitting a 32 tank ? They want them to look like a 32.
    Dak Rat and The37Kid like this.
  4. X38
    X38
    I'm a tank person.
  5. BJR
    BJR
    If no tank, where will you put the gas tank? In the trunk?
  6. No tank, put it in the trunk
  7. A Boner
    A Boner
    I vote for something like this…especially with a QC!
  8. DDDenny
    I chose the Pinto location for my car.
    lothiandon1940 and sdluck like this.
  9. kabinenroller
    kabinenroller
    I prefer a stock tank, with a stock looking filler. With the front of the tank notched for the quikie. I despise reproduction tanks that look like a “loaded diaper”.
    Just my opinion.
    da34guy and Dan Hay like this.
  10. chevyfordman
    chevyfordman
    I like no tank but saddle tanks in the sides of the trunk, rear really shows up good. With saddle tanks, you still have plenty of trunk space.
  11. alchemy
    alchemy
    If it sits kinda low, no tank. If it sits average highboy height, then a tank is OK.
  12. X38
    X38
    Call me weird, but I just don't get this compulsion some people seem to have to 'show off' the differential in their car.:rolleyes:
    da34guy and The37Kid like this.
  13. It's like an automotive tramp stamp!
  14. alchemy
    alchemy
    Custom guys don't understand. ;)
  15. X38
    X38
    I say that to my deuce roadster all the time! (with a tank in the tank location):D
  16. charleyw
    charleyw
    I vote Tank
    lothiandon1940 likes this.
  17. Dan Hay
    Dan Hay
    It really depends on the style of the car, but a tank is a good default because it usually always looks good, but no tank needs to be on the right car…
    clear as mud?
    lothiandon1940 and Just Gary like this.
  18. The37Kid
    The37Kid
    Has anyone ever started a pole on Quick change rears? "Have you ever changed gear rations in your quick change? Do you own different ratio gears to make the swap?
  19. SPEC
    SPEC
    Another vote for a Tank.
  20. X38
    X38
    It has come up. The short answer is, with very few exceptions in street cars, they never get changed.
    The37Kid likes this.
  21. 1935ply
    1935ply
    from peyton,co
    No tank, show your quick change.
  22. Rocky
    Rocky
    Classified Editor
    No tank here. Show off that Q.C.. If I had a car with the tank out back, I'd worry I'd get run into with gas spraying all over my car. Not for me.
    And I swap out the gears 34repairs4_19.jpg in my quick change when I'm taking an interstate trip or racing at the HAMB drags. Got 3 sets.
    Dan Hay and rod1 like this.
  23. oldiron 440
    oldiron 440
    I like the both so I'm no help but if the look is old hotrod how was it done in the 40s and 50s?
  24. big duece
    big duece
    from kansas
    At least with a Winters V8 unit, you shouldn't have to notch the tank. If no tank, and the rear horns are shortened, will the front frame horns be removed?
  25. No tank.... roll pan!
    seadog likes this.
  26. clem
    clem
    Depends on the style of the car really.
    Some visual aids…….
  27. seadog
    seadog
    Roll pan…no tank
  28. Fogger
    Fogger
    The gas tank is a design feature of the '32 Ford. I like them on both a HiBoy and a full fendered '32. IMG_0664.jpg
    alfin32 likes this.
  29. 26hotrod
    26hotrod
    from landis n c
    <<My tank is in the trunk so you can see the rearend. Looks a little more racy than a gas tank..........
