Customs Ron Hings custom 56 Chevy convert
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Sep 16, 2022.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, I need to order one and a few other things for it..
  2. BamaMav
    BamaMav
    from Berry, AL
    I knew it would bug you until you fixed it! Glad you found something that worked.
    chryslerfan55 and Moriarity like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. SS327
    SS327
    Look! It’s the great pumpkin Charlie Brown. He is real! He brings goodies to all the good girls and boys every Halloween who are in a pumpkin patch.
    lucky ink and VANDENPLAS like this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    So, I replaced the missing steering column to firewall seal. In doing so I had to remove part of the clutch linkage. I found one end of it about 75% sawed through. So I tig welded and filed it round. I put a little grease on it when I put it back together. Man I am glad I found that before it broke!! E4B97D13-F665-4265-B95E-7A66FD3F9363.jpeg 8CD9A5AF-D95C-43CA-AB2C-F59CA5613133.jpeg
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    I picked up a 1965 Portland roadster show program and the 56 is in it AF8DF20F-B019-4D6B-8234-CDBB59FF75E4.jpeg 0AA96E25-A8A9-4474-BA45-9BA84C6CF402.jpeg 31D56E3A-A738-417C-B1FA-B3C8D198C4A7.jpeg
  7. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I'm sure if you poke around some more you will find some more sawed / knawed through parts. :eek:
    It's a old custom ! :)
    bchctybob, 54delray, Stogy and 5 others like this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. verde742
    verde742
    SURE LOOKS BETTER THAN GREEN !!!!
    AND I LOVE THE WIDE WHITES
    54delray, Stogy and Moriarity like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    new firewall seal and master cylinder AB4F0A5C-6122-4034-AD53-1C3CF93FD431.jpeg
  11. chevy57dude
    chevy57dude
    It's the little things.. Gotta kèep out the Minnesota winter!
  12. Another great custom purchase Mark. I've just discovered how much fun convertibles are myself! I'm impressed by how thoroughly the colour change was accomplished on this one (and, you certainly didn't need another green chevy - right?). ;D
    Oh, and I'm glad you discovered that worn rod too! Whew!
    -Dave
    54delray, Stogy, Sancho and 1 other person like this.
  13. 54delray, Stogy and Moriarity like this.
  14. lucky
    lucky
    I'd love to see it without the parade seats boot
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    A4B389EB-65C8-4C7C-A960-3A192A846E87.jpeg 20AA2AAF-E357-4F48-B027-080B3940F1A1.jpeg
    glendale, SS327, lucky ink and 16 others like this.
  16. Squablow
    Squablow
    The work it took to make that back seat full-wraparound like that is pretty impressive, even more so if that's the original upholstery from the first custom build. Even if it's not, the work it took to make that upper center piece of vinyl and the two outer upper pieces have that much curvature with no wrinkles and with only the two seams connecting them, that must have been an incredible effort.
    bchctybob, 54delray, Sancho and 6 others like this.
  17. verde742
    verde742
    Mark Tomlinson , one of the BEST. Wonder if he is still around,
    anybody know ?
    54delray, Sancho and Stogy like this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    The miss elegance 55 has a very similar rear seat and also original to the first build D334719E-2CE4-46DC-8E1F-B9533E453A7E.jpeg 6C3214DD-EB73-433A-B241-271BFA035E18.jpeg
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    Did a little tidying up in the engine compartment, made a hard line from the fuel pump to the carb, replaced the orange master cylinder with a new one painted cast iron. Replaced the sun sending unit cover with one that has a logo decal. And added deco battery caps and logo decal to the battery, before and after pics
    9138FB84-AB99-4BA9-9A61-D5478DA7182A.jpeg D024FBBD-1FB9-411B-B187-C482E7574FA6.jpeg
  20. Dan Hay
    Dan Hay
    Nice! It’s all in the details. How well does that supercharger work?
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    honestly I have run it with the supercharger and without when I was fighting a carb flooding issue (had a bad float in the carb) and it runs way better without it hooked up, I am getting a warmed up surge with it hooked up. I guess I need to figure out what is causing that
  22. Bandit Billy
    Bandit Billy
    @Moriarity I have never seen spark plug wire looms like that, one-off? And the coiled lines on both sides of the engine, chrome? And is the intake polished or just the runners? I like the look of that bay!! You have some cool **** but this engine bay does it for me.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    I have never seen plug wire looms like that before either. I think they may be one off. the chrome coils are fuel pressure gauge on the p*** side and oil pressure gauge on the drivers side. the intake is the stock cast iron unit chromed
    VANDENPLAS, 54delray, Sancho and 4 others like this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    Engine compartment pic from the 1966 magazine article. Virtually unchanged A0335346-67C2-4C9B-9625-030678989D57.jpeg
  25. Bandit Billy
    Bandit Billy
    Transistorized Ignition? What a time capsule under the hood.
    54delray and Stogy like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    corvette dual point....
    54delray, Sancho, Stogy and 1 other person like this.
  27. Dan Hay
    Dan Hay
    In my limited knowledge of power adders, I know you can buy a carb off the shelf calibrated for blow-through boost situations. Which means that not any old carb will do on a blow-through application. Might be worth finding out what those calibrations are, as when this car was built they might have been thinking more of the cool factor than actual performance.
    I won't post them here but a quick google search came up with some articles and threads on modifying an Edelbrock/AFB for blow-through applcations.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    It has a proper Avanti blow thru carb. Maybe I need to get a kit and go through it B3FD25B1-E6D1-4246-BB30-6E0E37464690.jpeg
  29. Dan Hay
    Dan Hay
    WOW! That carb is probably worth a mint to a Studebaker guy! This car get's neater by the minute.
    54delray, Sancho, Stogy and 2 others like this.
  30. carbking
    carbking
    Virtually ALL genuine Carter AFB carbs can be modified for blow-through; one simply needs to look at the modifications Carter made on the Avanti carbs:
    (1) idle mixture control screws seals
    (2) accelerator pump seal
    (3) float baffles
    (4) throttle shaft seals
    (5) Double the airhorn gasket
    (1) The idle mixture control screws are the easiest of the modification. Remove the idle mixture control screws, mill a shallow larger diameter hole centered on the idle mixture control screw threaded holes. Insert an O-Ring of the appropriate size. The O-Ring should just stand proud of the casting. Now ***emble each idle mixture control screw with the original tension spring, and a small steel washer with the I.D. just sufficient to slide over the screw. Insert the idle mixture screws through the O-Rings.
    (2) The accelerator pump seal may be fabricated by fabrication a br*** plug with a center hole 0.005 greater than the accelerator pump shaft. Acquire two (2) neoprene (or Teflon) washers, and a two diameter spring with the smaller I.D. on both ends slightly smaller (0.005) than the O.D. of the accelerator pump shaft. The larger diameter of the spring should be in the center. When the spring is depressed, it should collapse on itself. ***emble the plug with a pilot shaft, a washer, the spring, and the second washer; and press the ***embly into the airhorn on the pump side. Remove the pilot shaft. The accelerator pump shaft will be inserted through the plug when the airhorn is placed on the lower body. There is now a seal on both sides of the pump shaft, held in place by the spring.
    (3) Float baffles. The two halves of each float should be un-soldered. A cross-baffle to fit along the seam of the float should now be fabricated from very fine expanded aluminum, with pins at 90 degrees from the baffle to hold the baffles in place. Insert in the male half of the float. Re-solder the floats (remember to free the equalization hole to allow temperature equalization, and close the hole after the temperature equalizes). Soldering should be done with an iron, not a gun. I have yet to see an electric gun that produces sufficient heat (there probably is one). PHENOLIC floats are only good for a boost of maybe 4 psi. We have used the normal reinforced Carter br*** float (the ones with vertical indents) of up to about 8 psi. At this level of boost, they will slowly deteriorate. About 6 psi has shown no deterioration. With the baffles we have not seen issues with 10 psi (and more) of boost.
    (4) Throttle shaft seals. This is the tricky operation. There is a low pressure area in the secondary on each side of the auxiliary valve. Machine 3/16 inch holes through the floor of the secondary in this low pressure, through to the flange. Mill 1/8 inch grooves from these holes to the center of each of the throttle shaft bearing surfaces. Remove both throttle shafts (remember to grind off the back sides of the throttle valve retaining screws prior to dis***embly). The screws are 6x32 and must be replaced with new. Use a drop of blue Loc***e on the threads when re***emblying. Machine grooves in both ends of each throttle shaft to correspond to the grooves in the throttle body. Use a solid mounting gasket between carb and intake approximate 3/16 inch thick (I use Armstrong N-8090 material for these). The seals are vacuum seals. The pressure at the ends of the throttle shafts will be relieved through the grooves by the low pressure areas.
    (5) Self-explanatory. The two gaskets should be stapled together just before the slots for the bowl secondary baffles (again, I use Armstrong N-8090 material for these gaskets).
    Remember that the genuine Carter AFB's were pressure-cast and are more dense than vacuum-cast units, thus much less prone for leakage though the castings.
    Oh, and the groove technology for the vacuum seal was also used on the Holley 4000 series used on the supercharged 1957 T-Birds.
    Easy as pie, right?
    And before anyone asks: NO, I am no longer rebuilding carburetors, too busy making kits.
    Jon
    bchctybob, Baumi, VANDENPLAS and 10 others like this.
