Projects 1930 Oliver Roadster Build
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Dec 22, 2021.
  1. flatheadgary
    flatheadgary
    from boron,ca
    that side bead is almost the same as a '28 chevy roadster. think hugh tucker
    oliver westlund likes this.
  2. oliver westlund
    oliver westlund
    Got the covid round 2...or a cold, still not sure I believe the test, my wife got sick too but she tested negative everyday... anyway, birthday party for me tonight (day early) and figured I would try her on and make some vroom vroom noises....Hey! My wife even fits! 20221009_152604.jpg received_5826179390749985.jpeg
    Bandit Billy, scotts52, brEad and 2 others like this.
  3. flatheadgary
    flatheadgary
    from boron,ca
    she is cute from her hair to her toes.
  4. oliver westlund
    oliver westlund
    Yeah, shes a special lady! Just started doing pinup contests at car shows this last year too! Im a blessed man
    brEad likes this.
  5. flatheadgary
    flatheadgary
    from boron,ca
    i have always believed that beauty should be noted .
  6. oliver westlund
    oliver westlund
    Well I did some measuring and I determined 2 things....1st, firewall to fan tips my lincoln 337 is 29 inches long and I have 32 inches of room for it in the roadster! So thats great! And 2nd....the back half of this thing is wonky as hell, the drivers rear quarter is just in the wrong spot and I created too much tension by narrowing the seat back as much as I did....so I took out a sawzall and...snip snip.... 20221010_194605.jpg I will be starting with more new structure and lots of measuring and get this thing sorted out so it will be pretty in the end!
  7. oliver westlund
    oliver westlund
    Well....I cut the drivers rear quarter off. 20221011_164302.jpg It was about a half inch north of where it needed to be and an inch west, got it tacked back on in place. 20221011_173547.jpg Some sub frame in, will get some floors made and some permanent structure to get this floppy body secured. It had to be done! Ive known for a while that it would come to this and I definitely was putting it off...
    brEad and scotts52 like this.
  8. oliver westlund
    oliver westlund
  9. oliver westlund
    oliver westlund
    Little side mission today, diss***embled door latch and fitted some random handle to it. Grinding, filing, sanding, wire wheeling and cursing later and I have a functioning door handle! It has been one of those little annoying things that slows me down every time I need to open it. At some point I will have to address the nightmare on the drivers side. 20221012_172224.jpg 20221012_172422.jpg
  10. oliver westlund
    oliver westlund
    If anyone has a handle that matches that you can part with give me a holler! I thought I had 2 but it appears I was wrong
  11. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Oliver;
    Eons ago, when I did my '32 5w, I didn't have the oem handles - inside or outside. Since it was a severe-low-budget-build, what I found to work well, was to use acvw inside handles, both the door latch & window(from a karman ghia circa 64 ,almost a perfect fit on the square shafts, & they look good, too). On the outside, I used the locking-handle version of a generic aluminum-pu-topper latch handle. The square-shaft was also almost a perfect fit into the latch. The mounting holes were slightly different, so I just made a thin adapter to allow the machine screws to angle in easily. No cross thread issues. If I hadn't wanted to *not* alter either the pristine doors or the chromed handle-base, it'd been easier. Both were inexpensive, looked period.
    Which look similar to your handle.
    FWIW.
    Marcus...
  12. oliver westlund
    oliver westlund
    Good idea! Thanks! I found a few on fleabay that match but theyre around 50-80 each. Im sure at some point I will get a nice matching set as this is going to be a bodyworked and painted car but i figured maybe someone has a junky one layong around til then. I wouldve given the one Im using away before I found a use for it! I will look into the volkswagon handles
  13. nrgwizard
    nrgwizard
    from Minn. uSA
    Oliver;
    Hope you can find a match.
    Early acvw stuff is getting spendy, but if you're lucky... :) . The early handles used nice small white tapered knobs, not the ugly clunky black discs later ones used.
    Those latch handles worked surprisingly good. & were very cheap, like ~ $10 usd, maybe...
    You could also look at the-repop modelA outside handles = almost perfect copies of each other. ModelA being a whole lot more expensive, & since you're modding the sheetmetal anyways, <shrug>.
    Marcus...
  14. oliver westlund
    oliver westlund
    I might go with these...i kind of dig em Screenshot_20221013-200645_Chrome.jpg
    scotts52 likes this.
  15. nrgwizard
    nrgwizard
    from Minn. uSA
    Same idea, using what you can find, not necessarily an auto part. Lots of old auto parts were adapted &/or repopped for commercial industry applications, & sometimes became much cheaper...
    Marcus...
  16. oliver westlund
    oliver westlund
    Well i bought a trailer load of rusty old stuff (mostly model a) for s**** prices and this crusty old tank was on it...trailer was last touched in 1982 so odds are its off of an old rod! It just happens to be exactly the right size for the trunk of the roadster and capacity will allow some long road trips! 20221016_115251.jpg Knocked the crusty junk off and started spray bombing it, heavy walled. Pretty solid old tank 20221016_115300.jpg
    brEad, scotts52 and Papas32 like this.
  17. Atwater Mike
    Atwater Mike
    Little by little...
  18. oliver westlund
    oliver westlund
    The 49 lincoln trunk lid was calling to me, i dig the inner structure 20221016_191330.jpg as well as the ridge down the middle. 20221016_185946.jpg 20221016_190358.jpg Will have a bit of clean up and m***aging to do before its a trunk lid but I think its on the right track. Also replaced an earlier patch I did with a better one, the previous patch didnt have enough contour and was causing a buckle. 20221016_204144.jpg Definitely little by little. Have a cpl options for hinges(49 linc and some exterior hinges off of a humpback) I think it will end up with a really neat look! Slowly looking more and more like a car and my vision
    brEad likes this.
  19. oliver westlund
    oliver westlund
    (Other side of the inner structure and the 49 linc hinges) 20221016_183709.jpg
    brEad, Squablow and Papas32 like this.
  20. oliver westlund
    oliver westlund
    Little more sub frame, 20221017_210236.jpg beginnings of rear floors, 20221017_203921.jpg gotta get some more weld through primer tomorrow and clean up the insides of the quarters before I put the floors in permanent. Also want a good coat of weld through on all the sub frame so rust doesnt start next week. After rear floors go in I can add some quarter supports that should really tighten this thing up. Not gonna be any wood in it so it needs a lot of structure added
    brEad, Squablow and scotts52 like this.
  21. oliver westlund
    oliver westlund
    Funny thing is....once I get the body sort of put together....I will be at the point many of you start your builds at! Once its a car, I have to tear the whole damn thing apart and start makin it nice hahaha the things you do for love
  22. oliver westlund
    oliver westlund
    Ooooh I think the 49 lincoln trunk treatment might just work! 20221018_171907.jpg
    Will need some t******* and fitting but I really dig the look! 20221018_171858.jpg Also tried a low headlight mount. I dig it, not sure I am sold yet but used an existing hole and a bolt so no harm no foul. 20221018_173706.jpg Headlights are chevy, I dig the big chrome. I dont want too much chevy on it but they do look good on there 20221018_173713.jpg 20221018_173716.jpg
  23. flatheadgary
    flatheadgary
    from boron,ca
    some states have height requirements.
  24. oliver westlund
    oliver westlund
    Good tip! Oregon has many laws this roadster violates. Cops dont tend to enforce em though, I will likely chance it. The stands came off another oregon rod anyway
  25. oliver westlund
    oliver westlund
    Knocked some rust off and sprayed some primer on. 20221018_212606.jpg If I find time tomorrow, Ill do the other side and perhaps even get the rear floor in!
  26. oliver westlund
    oliver westlund
    Started off today by knocking the crusties off the p*** side. Got it sprayed in red oxide and then tackled the floor 20221019_144617.jpg The floor is primered on the underside; once I got the floor spot welded in, I added two rear quarter supports. 20221019_154447.jpg Pretty amazing to have a semi solid car to work with! More supports are in order and more floor but pretty big steps today! 20221019_155924.jpg Also mocked the trunk and tires back up as well as raised the rear to where I think itll sit... it will get shorter front tires as well 20221019_161648.jpg 20221019_161636.jpg 20221019_160017.jpg 20221019_160659.jpg
    Might have too much windshield still as well...I can see through the gap well but the overall profile with the car seems a touch tall
    dwollam, Squablow, brEad and 2 others like this.
  27. oliver westlund
    oliver westlund
    Little more floor 20221020_135859.jpg seat back supports
    Getting stronger and stronger!
    brEad and Bandit Billy like this.
  28. oliver westlund
    oliver westlund
    Tackled drivers door today...since it got run over or stomped on or something, I had to cut some of the sheet metal off to release some of the tension holding it out of shape. 20221021_172904.jpg Then welded up a bunch of cracks in the structure. Then I fitted it with what I think is a gm door latch, seems to work fine! 20221021_172919.jpg
    Squablow, scotts52 and brEad like this.
  29. oliver westlund
    oliver westlund
    Tackled the dash this evening. Yes, as others have astutely and rudely pointed out, I have A.D.D. and I work all over the place. Oh well. I make it work. I have had a plan in my head for this dash since I first saw the front half of the 25 dodge touring tub in the wrecking yard. So much so that I went and purchased guages immediately for it. Tonight I started that plan into effect! I am going to cut out the entire center section and replace it with a custom 18 guage panel blended to look stock 20221023_193122.jpg
    The first thing I did was stencil the existing dash shape onto my piece of steel. Then I cut it out. 20221023_185240.jpg
    After that I measured and marked and erased and measured some more until I had my guage location in the exact right spot and then I drew on and with the bead roller, stepped my guage panel 20221023_193102.jpg
    Next I am going to cut out the holes for the guages, ignition and toggles
    Squablow and brEad like this.
  30. oliver westlund
    oliver westlund
    dwollam, Squablow, pprather and 2 others like this.
