Projects BENNETTS ‘Midnight Special’ speedster
Discussion in 'Traditional Hot Rods' started by jordabennett, Mar 3, 2022.
  1. Joe Blow
    Joe Blow
    I'd vote for paint too. Maybe single 36 Desoto Airstream/Airflow vents (or similar) in the foward/upper hood sides? Just a thought....but like you said, something there might be to busy with the pipes. Whatever you decide on is not going to detract from the bad***ness of this killer speedster.
    post-61534-143141898446_thumb.jpg post-61534-143141898478_thumb.jpg 1936-desoto-sd1-deluxe-airstream-coupe-1.jpg
    brEad, Stogy, hfh and 1 other person like this.
  2. alchemy
    alchemy
    machine turned
    GirchyGirchy, brEad, Outback and 4 others like this.
  3. Those are damn cool! Even one would look good above the heads.
    Stogy and Joe Blow like this.
  4. Stogy likes this.
  5. I’ve decided to give the polish a crack, if it doesn’t cut it I can paint, maybe half half?
    Anyway I had a go today and got one hood side polished, it’s still foggy but the steps taken were wet/dry 1200, 1500 on the orbital followed by 3000 and then buffed. I can’t seem to get it to really shine more foggy,
    Anyone have any tips for polishing aluminum?
    I will end up laying out the pattern for louvers on top and most likely leave the sides simple to keep your eye on the pipes! I found some latches. Not sold but could work 41FE70CE-8F27-482F-8AEE-C28F0E868DD8.jpeg 31AE8944-5CD4-4F56-8647-E9F27A40A240.jpeg F92E4084-A50B-4FB8-B942-4085B677F098.jpeg 5E235D3A-D98A-4C52-B99F-E7297C8E7DD6.jpeg 60FF99D9-3D53-4E15-B040-8DCDE2B983E0.jpeg
    brEad, 41 GMC K-18, Tim and 3 others like this.
  6. 282doorUK
    282doorUK
    Often friction shocks can look a bit clunky and spoil the looks, but yours really enhance the front end and look great. It's all in the detailing!
    I would leave the hood plain and paint it as I think that will make the whole car look longer, and all one piece.
    Leaving the sides polished ally may enhance that effect, not too sure though.
    Outback, Stogy and Ed hardenburgh like this.
  7. acme30
    acme30
    from Australia
    Looks are important but so is function. Flatheads put out a lot of heat and with no windshield and louvers in the top then that heat is going straight into your face. As will any coolant if you are unlucky enough to blow a hose.
    Louvers in the sides will still look good and makes more sense to me.
    Outback, Stogy and 282doorUK like this.
  8. Joe Blow
    Joe Blow
    Jorda, sent you a PM.
    Stogy likes this.
  9. Fabber McGee
    Fabber McGee
    Wouldn't be difficult for a guy with your skills to build those little vents with stainless rod or tubing. Most likely faster and easier than finding and shipping.
    jordabennett and Stogy like this.
  10. Stogy
    Stogy
    Decisions, decisions, all of you have great opinions, hence the likes...Jorda you have the pick of the suggestions in the hat...and as was mentioned you won't disappoint...it's obvious...I say it all the time...The Hamb delivers...Thank you...;)
  11. Getting a bit better polishing, still a bit to go before a punch some louvers 9889D64B-FE37-478A-B9E1-F79FF2B99115.jpeg CE9F7150-73D3-454B-B02D-774F39CD955F.jpeg A72D457D-7376-466E-9E98-F6035DE9A83F.jpeg 122008B3-FCE2-4EEC-BA3E-C8EF2A0E8F6B.jpeg CEAD284D-B23F-4EEE-B34B-44546DA639E2.jpeg
  12. 282doorUK
    282doorUK
    Liking the reflections of the pipes a lot, hope you don't mind I had a quick paint of the hood to see how it might look, your painting may be better!
    Stogy likes this.
  13. Can yeah do the whole thing hahah? Sides and all
    Stogy likes this.
  14. Stogy
    Stogy
    :rolleyes:...I love Aluminum...I used Mothers mag wheel polish...it was only hand rubbed...but it did shine...I suspect like paint the finer the finish ie 1000 grit and up the shinier it gets...I'm not a buffer but that's the experts who truly can answer that question...Aircraft, Airstream...or @Bandit Billy polishes everything quite expertly...He may have some good info...I agree with 282...your polished look 2nd round with the reflected pipes is quite the money shot....dayuuum...
    That said the painted top and sides may win out...I feel you already have shiny details setting it off, grill, shocks, pipes...etc...perhaps some polished riveted doublers around the pipe holes with hood and sides painted...
    brady1929 and Joe Blow like this.
  15. 282doorUK
    282doorUK
    Excuse the over brushing on the pipes...someone who knows how might do it with matching paint for you if you're lucky.
  16. Stogy
    Stogy
    I think you answered the query even with overspray...that looks really convincing...to me...yes to paint...yes to matching paint yes to pinstripes...
  17. ratrodrodder
    ratrodrodder
    from Boston
    Ah man, you got paint on the tires! ;)
    RileyRacing, Outback and Stogy like this.
  18. 282doorUK
    282doorUK
    Looks like it crept along the exhausts when I wasn't looking, , tricky stuff that paint! o_O
    brEad, ratrodrodder and Stogy like this.
  19. Stogy
    Stogy
    You done good...no vintage parts were damaged by the process...I am big digital art fanatic AND an Artist...I'm sure you fellas can appreciate how complex this process is...Regardless I felt the positive vibe right away...and remember practise makes perfect...;)
    41 GMC K-18, brady1929 and Outback like this.
  20. patmanta
    patmanta
    from Woburn, MA
  21. No it’s a water proof binding tape, it’s almost impossible to tear and should help keep the moisture out
    Stogy, 41 GMC K-18, Outback and 3 others like this.
  22. Managed to get another weekend in before the baby is due, we had 2 great days of racing ‘test and tune’ with good dry track conditions and we’re creating by an unexpected storm that nearly left us high and dry on the side of the lake, large marble size hail and lots of rain made it slippery. Had to do a few circles prior to loading up. F1AA8F61-DC03-4F8B-A66E-8AC8CFEC7F03.jpeg CBC8EFB1-713E-41C7-B876-5EF2B59A1F86.jpeg 0E4D4353-3D57-414C-8848-20EF106A6BF9.jpeg CCC67DF6-D138-458C-9227-9AD298AFF399.jpeg E64CA947-703A-4EE9-B2CB-7CC2F6172F07.jpeg
    brEad, Stogy, 41 GMC K-18 and 16 others like this.
  23. AmishMike
    AmishMike
    Get er dirty & have a hell of a good time
    Outback likes this.
  24. acme30
    acme30
    from Australia
    Looks like another big day of cleaning and polishing is on your future:)
    porkshop likes this.
  25. It most certainly was!
    BILL LUPIANO likes this.
  26. BILL LUPIANO
    BILL LUPIANO
    from Canada
    Man just read the whole thread! Great build,congrats!
  27. gary kessler 1932
    gary kessler 1932
    Man I read the whole thread, U knocked it out of the Park!! dont know where u got those shocks, but they look KILLER!! just noticed how they match the front axel drill pattern, your car is UNREAL!!
    jordabennett likes this.
  28. Thanks a ton Gary! It was a blast to drive, still lots to do
  29. Six Ball
    Six Ball
    from Nevada
    You shouldn't treat a good hat like that. :eek:
