Technical 1952 Ford F1 not driving straight - front AXLE
Discussion in 'Traditional Customs' started by Hessler, Oct 24, 2022.
  1. Hessler
    Hessler
    Hi guys, this does not apply only to my truck because I know a lot of you guys drive trucks or cars with axles here, so my truck has a 3in dropped axle with mono leaf on the front and it does not drive straight I have to constantly correct. I had to bend the spindle to help the draglink be as straight as possible, I do have a shorter pitman arm to help as well, so its almost parallel to the ground, almost everything in the front is new, because I changed the springs, added disk brakes, and new dropped axle, what could be causing the truck to not drive straight? and to correct constantly?
    issues: the steering does have some play, I have a new ccp steering box
    Flathead Freddie likes this.
  2. ROADSTER1927
    ROADSTER1927
    Put it on a front end alignment rack and get it checked.
    X38 likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Steering box, tie rod ends can cause the constant back and forth with the steering wheel. HRP
  4. alchemy
    alchemy
    Toe in, caster, box not centered when the drag link attached.
    flynbrian48, deathrowdave and RMR&C like this.
  5. BJR
    BJR
    Check your caster, 6 to 8 degrees.
    flynbrian48, deathrowdave and X38 like this.
  6. Hessler
    Hessler
    will try to do all of the above, thanks guys, I will check caster, toe, box not centered (this I know if off a bit) tie rods are new, if nothing works will probably just take to an alignment shop, does anyone know of a shop any where near the Los Angeles California area? its hard to find shops familiar with front axles
  7. Hitchhiker
    Hitchhiker
    It could be as simple as the tires.
  8. Hessler
    Hessler
    you have me thinking now, have you had this issue before and how was it fixed?
  9. 57 Fargo
    57 Fargo
    You will be hard pressed to make it stop wandering with play in the steering box.
    wandi harry, LOST ANGEL and bobss396 like this.
  10. Flathead Freddie
    Flathead Freddie
    Have not read your complete thread yet but send me some pictures of the tire threads so we can read them it's first thing I always do when walking up on a front end job Thanks .
  11. Flathead Freddie
    Flathead Freddie
    Johnson's in Torrance they are off the 405@Crenshaw is take it to Alan Mest if you think you need parts he may have them . Also just start a conversation I'll come look at I'm in South Bay area matter of fact your avatar looks familiar . I'm in Torrance
  12. Hessler
    Hessler
    thanks, I will take some pictures and upload this week, and will try a few of the tips here but at the end I have a feeling I'm gonna have to take it to a shop
  13. Hitchhiker
    Hitchhiker
    I've bought vehicles that needed tires and were almost impossible to drive with the tires on them due to separated plys.. I also worked at a large tire chain. And I've seen all sorts of weird stuff.
    Old tires do all sorts of weird ****. Even ones that look okay.
    I'd be looking at the steering box and tires to start with. If you can find a good alignment shop that will actually shake down the front end instead of throwing all new parts at it would be my best advice.
  14. Any big truck or RV repair place will be familar with straight axles.
  15. deathrowdave
    deathrowdave
    from NKy
    I’m betting on reversed caster , happened when dropping the axle took place . There are wedge shims available to correct this issue . You can do a simple check with a magnetic protractor , it will get you very close .
    Ever turn the fork backwards on your bicycle as a kid , and try to control it ? Well this is the effect of reversed caster , explained as simple as I can
    Budget36 likes this.
  16. Hessler
    Hessler
    I will check again, but I'm almost positive it was ok, I did but some shims to add more so I will try that as well
  17. Hessler
    Hessler
    The tires are new, they are radials, I'm just gonna check if the have direction, meaning, fwr
  18. rusty valley
    rusty valley
    Is the stuff all new and greased ? Tight, or dry and sticking king pins will drive like ****
    bobss396 and Kevin Lee like this.
  19. Kevin Lee
    Kevin Lee
    Super Moderator
    Parallel to the ground doesn't really mean much either. I'm driving an F1 with a 3" dropped axle, 3" frame Z, de-arched leafs, and my steering box has been moved forward on the rail to compensate for a channel and other things. And it gets down the road great. I have no idea what the relationship from my draglink to the ground is. Way more concerned with relationship between the parts its actually interacting with.
    Bending your... spindle? (I'll ***ume steering arm specifically) and shortening the pitman arm could cause all kinds of bad behavior too.
  20. 6 Degrees of caster will solve it, go to a dump truck repair shop they bend axles all the time and can do it with the axle in the car. A steering stabilizer will help too, auto parts shops have them listed under 56 Ford pickup steering stabilizer kit.
  21. Kerrynzl
    Kerrynzl
    Negative caster will not cause the car not to drive straight , constantly needing correction.
    It will make the car feel unresponsive and understeer. [and the steering won't return to centre]
    Too much toe-out will make the car feel unstable and constantly needing correction
    @Hessler You need to check all the components first [king pins, ball joints etc]
    And please report back to us, if you want help, or else this becomes another HAMB mind-reading exercise in futility.
    The symptoms of "the car not to driving straight constantly needing correction" are pretty vague.
    It could be mechanical bump steer, or alignment, or it could be rear roll-steer
    So an accurate description of what it is actually doing would be a start.............
    flynbrian48, Kevin Lee and Happydaze like this.
  22. bobss396
    bobss396
    Low caster on stock cars would cause the car to dart around on the straights. On those it was an easy fix. Bad toe will do it to a degree. So will a sloppy steering box. I had a '64 Ford that had play in the steering, driving that was an adventure until I adjusted the box.
  23. X38
    X38
    This would be the solution I would guess at too. What you have done to dump the nose down has no doubt killed the original caster (or much of it,) unless you've put in spring wedges to compensate. So yes, check the caster of have it checked. It's important.
    I had to deal with a beam axle car that drove as you described. When I checked the caster it was barely 1 degree. Made it 6 and all was good. (Sounds like a quick fix, but the way the car was built needed quite a bit of work to enable those extra few degrees. Wedges would have been so easy!)
  24. X-cpe
    X-cpe
    Are you defining "not drive straight" as pulls to one side or wanders back and forth.
  25. gary macdonald
    gary macdonald
    Did you add the little tapered shims that usually come out between the factory spring and axle pad ? Very important.
  26. Hessler
    Hessler
    will check this
  27. Hessler
    Hessler
    yeah, kind of wanders and need to correct constantly
  28. Hessler
    Hessler
    Don't remember, but I did just ordered some shims to
    just ordered some shims with 4 degrees, we will see what happens
    John Lee Williamson likes this.
  29. Hessler
    Hessler
    I do not remember, just ordered some shims with 4 degrees, we will see what happens
  30. Hessler
    Hessler
