Projects K-88 Dragster / 6 Cylinder
Discussion in 'The Hokey Ass Message Board' started by Countn'Carbs, Apr 30, 2019.
  1. WiredSpider
    WiredSpider
    Looking killer Dave.
    Can,t wait to see it in June.(HINT HINT)
  2. AmishMike
    AmishMike
    Love your dragster & post - but, any more pics of the yellow cowl dragster facing yours in the one pic??? Looks like a great pair ready to run
    chryslerfan55 and winduptoy like this.
  3. jimmy six
    jimmy six
    Dave, your going to love this. Your not the only one. Here’s an original one being done by Jim Busby. I was at his shop for a “50 years in racing” celebration today and couldn’t resist taking a few photos. It has a little Dodge hemi for power. FA841FC2-9C28-474D-BC94-C1011EF386E1.jpeg 5CD97649-7A1A-4434-B67F-661A0F147470.jpeg 0761092C-D0C4-4444-8E5D-E85587AF13CF.jpeg
  4. Countn'Carbs
    Countn'Carbs
    from CO
    Oh Man JD!! You had me pegged on that. I've seen some shots floating around of Jim's restoration and THANK YOU for snapping and sharing some shots of it. Hopefully Jim will share more about it's history but that is beyond cool - Thank You Again!!
  5. jimmy six
    jimmy six
    Always have my eyes open. All the internal parts were on a bench. Ross pistons and aftermarket rods and a finished crank from Marine Crankshaft here SoCal.. they do mine too. I heard it was found in a s**** yard field. I looked for a # but didn’t see one.
  6. Countn'Carbs
    Countn'Carbs
    from CO
    So dang good and I love that kind of stuff. I'm not sure if Scotty Fenn and crew ever numbered the ch***is....for some reason I don't think they did but I'm not 100% sure on that. Hope Jim posts more updates as that is a gem for sure.
    winduptoy and chryslerfan55 like this.
  7. Countn'Carbs
    Countn'Carbs
    from CO
    winduptoy likes this.
  8. Countn'Carbs
    Countn'Carbs
    from CO
    Here's a few shots of the car prior to the Denver Timing ***ociation club meeting. Still a long ways to go but bolted the bare headers on there to get the effect. Headers will probably get painted white here pretty quick and time to start figuring out some simple scallops and what not.
    Chucky, rod1, winduptoy and 5 others like this.
  9. Countn'Carbs
    Countn'Carbs
    from CO
    It was a pretty fun night with some deep Denver history in the house. First off is Bob Corbett's record holding dragster. The 12 port on this GMC was designed by Bob and this car still holds the Inliner International record...ET 7.79 @ 170mph. This was set at Bandimere (on 85% fuel) and I highly doubt it will ever be broken. @AmishMike this is the car you were asking about.
  10. Countn'Carbs
    Countn'Carbs
    from CO
    Also a special treat was seeing Joe Umphenour's engine again now owned by Mike Nicholas. You may recall at the beginning of all this, Joe's first dragster (a TE-448) was the major inspiration behind my dragster build and the fact that this engine is still in the area is incredible and it's in very good hands.
    Here's Joe's dragster that I'm referring to:
    It's really cool that the engine is still in the area and is being very well taken care of.
  11. Countn'Carbs
    Countn'Carbs
    from CO
    And yet another 12 port that we were treated to was Cal Kennedy's. Many of you know Cal from the T-33 car and the Hot Rod Hill Climb. As I understand it, the T-33 is getting a new bullet and it was on display prior to going into the car.
    That's Cal on the left and Bob Corbett on the right of Cal's new engine.
    Cal with his new engine.
    And the legendary T-33 that it's going in.
  12. Countn'Carbs
    Countn'Carbs
    from CO
  13. AmishMike
    AmishMike
    Wow, what a collection of beautiful 6’s. Did Bob Corbett design that head and cast in iron or aluminum.?
  14. Outstanding brother!!
  15. Countn'Carbs
    Countn'Carbs
    from CO
    Yes..Bob designed that head and it's machined out of aluminum. Here's another picture I took of it a couple of years back. That whole car is truly a work of art and hauls ***!!
    D-Russ, Dyno Dave, winduptoy and 6 others like this.
  16. Countn'Carbs
    Countn'Carbs
    from CO
    Thank you Steve - that means a lot!! June isn't that far off so I better get my **** together.
    winduptoy and WiredSpider like this.
  17. Very cool meet you guys had down there in Denver! Do you know why the Corbett engine has a side cover on the left side? For looks? Or some super secret speed tricks? I also have a GMC infection, my Bonneville O/T race car has a Howard/Arias 12 Port head and Mike Kirby @ Sissell’s built my Lump Port stock head blown engine. Definitely no 1-800 stuff going on with these bad*** Jimmy’s!
  18. Countn'Carbs
    Countn'Carbs
    from CO
    It was nice to meet you too and sounds like a hell of a stable you have!! And you are so right....no 1-800 stuff going on with the Jimmy crowd.
  19. Countn'Carbs
    Countn'Carbs
    from CO
    Not much progress as of late but was able to carve out some time and get the brakes plumped.
  20. Marty Strode
    Marty Strode
    High on detail, beautiful stuff !
    OFT, 48fordnut and winduptoy like this.
  21. Bearing Burner
    Bearing Burner
    from W. MA
    I just sold my120" wb K-88 dragster with flathead which hadn't been run since 1970
  22. Countn'Carbs
    Countn'Carbs
    from CO
    One of the things I've been putting off is how are we going to start this thing. After much thought and ideas of threaded holes, riv-nuts, etc...my brother Jay had the idea of drilling/tapping the mid-plate and bringing bolts in from the backside to act as mounting studs for the starter.
    From there I was then able to squeeze a mini-starter down in between the frame rails and when it was all said and done I lucked out with having the correct drive-ring gear clearance with enough depth engagement to where I think we can check this off the list.
  23. 0A9908FC-7654-44AD-AF1F-8467E7082648.jpeg In case you get the itch to build an I-6 comp coupe here’s a little gem you might like. C97581AA-44DB-4762-86C6-81ED2E58802C.jpeg
    Dyno Dave likes this.
  24. Harv
    Harv
    from Sydney
    Neatly done on the starter. Looking great.
    Cheers,
    Harv
    Countn'Carbs likes this.
  25. Countn'Carbs
    Countn'Carbs
    from CO
    That's such a great car. Ricky Neal is so talented and definitely builds some cool stuff!!
  26. Countn'Carbs
    Countn'Carbs
    from CO
    Carved out some time and finally started plumbing this thing. Was able to get from the tank to the barrel valve. Still need to source new nozzles and injectors lines but some progress anyway.
  27. Harv
    Harv
    from Sydney
    Neat job on the plumbing. You get a smiley face stamp and two brownie points for not using red or blue anodised tube fittings (mebbe it's just me, but they scream 1980's).
    I'm at a similar point with my FED. Decided to run -8 suction and -6 return lines, mostly bent rather than use bend-fittings or hoses. Bought stainless line, in hindsight should have bought aluminium. My el-cheapo tube benders have done a lot of work on bundy tube, but the stainless tube laughed at it, crimping every time. Bit the bullet and bought a pair of high-end Rigid benders. They are clunkier to use (long handles) but make beautiful bends.
    Do I spy a Hilborn F500 filter in your photo? I've got one, but elected for a smaller, later model filter for now. I suspect weight is going to be my enemy (220HP and chasing a 10.99 cut-off for Modified bracket), but may fit the F500 later if I can make the cutoff.
    Cheers,
    Harv
  28. Countn'Carbs
    Countn'Carbs
    from CO
    Nice Work Harv and that looks great!! Yeah this is my first rodeo with this AN stuff and it's kicking my ***. Guess I'm a rubber hose and hose clamp type guy but trying to build a car with a late 50's / early 60's vibe while being able to p*** current tech is a fine line.
    I too opted with -8 between the tank and the pump and then -6 for the rest. I don't like my Rube Goldberg antics coming out of the pump with the 2 90 degree fittings but needed to move the shutoff inward for the pill holder(and lines) to clear the ch***is. I was trying to come up with some type of bracket but no good way to mount it to the engine so it is what it is.
    Yes - that is a F500 filter. A sprint car cast-off spare that was basically NOS - there again trying to run the early stuff if possible.
    I'll be pulling for you to make the cut-off in yours and keep us posted! In my case we just bracket race and I can't go faster than a 11.50et otherwise I need to start adding roll-bars and what not which I planned from the beginning not to do.
    winduptoy and catdad49 like this.
  29. cabong
    cabong
    My very good friend "Big ****" Deutsche built this rail back in 1952. It was powered by a 216 Chevy. If you look close by the shoe on the frame rail, you can see the special ****tershield. I believe it's a 6.50-16.... That's **** standing with his hand on the carb.... Ironically, his next rail, which he began building that year, was a rear engined design.... Dicks rail 3.jpg
  30. Stan Back
    Stan Back
    Wow! I'd guess a tire would slow down some things. Too early for a radial. In early Colton days I saw an Olds-powered Chevy Sedan Delivery p*** (after warning the week before) with flat black painted cardboard.
