a couple progress pics
Discussion in 'The Hokey Ass Message Board' started by HotRodDrummer, Sep 9, 2006.
  1. HotRodDrummer
    HotRodDrummer
  2. SlamCouver
    SlamCouver
    from Brazil, IL
    what a misleading post! i expect to see real ****s sir.
  3. Crusty Nut
    Crusty Nut
    Nice work, looks really good. But, if you think those are nice ****s you need to open the window while your welding next time.:)
  4. Royalshifter
    Royalshifter
    Moderator
    I love breastesesses, hey where are they?
  5. HotRodDrummer
    HotRodDrummer
    Opening the window would cause the flow of air to be disrupted!!...messing with the flow of air durng welding...not good!!....in a week or two.. you will see What WE have coming!...
  6. Gummi Bear
    Gummi Bear
    I like the 'speed holes' in the frame. Did you use a dimple die, or are they cut-n-fit pieces?
  7. erock805
    erock805
    pretty awesome...how did you do it?
  8. low620
    low620
    did you build your frame bench or purchase it?
  9. mackster
    mackster
    ****ies? Huh!
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    ...no ****ies...Matt=liar...:p
  11. dabirdguy
    dabirdguy
    At the very least I expected to see Hotroddurmmer standing next to someone.
  12. Crusty Nut
    Crusty Nut
    Can we at least sneak apeek at some man ****?
  13. breeder
    breeder
    well, heres some built in air ****s!!umm , i mean ,bags!!:p
  14. HotRodDrummer
    HotRodDrummer
    We have dies for belling holes and I just welded a 3" hole saw slug to the back.
    Cutting and grinding, man....4"x1/8" tubing...3feet long
    Ran some tape starting in the center opposite the seam and pulled it to the other end about 120 degrees off center. Cut, marked where it needed ground and ground on it until it followed the curves in the side rail.
    We built the frame jig for 1932 ford ch***is, this table is just a big heavy aluminium surface plate that my dad got from a g.m. sale many years ago and he built the roll-a-round structure deal under it.
    Oh, and sorry about the **** thing. here is a picture of a very!!!Very!!big ****!!hahaha
  15. Clark
    Clark
    Matt....is it going to be a cut out or the exhaust? Looks real good!! I was wondering why only the three holes now I know why.
    Originally I wanted to do that to the 32 and use it as the exhaust. Was gonna use a sidepipe mufler with inlet and outlet on the same end.
    Clark
  16. HotRodDrummer
    HotRodDrummer
    It will be the exhaust...Thought about making mufflers, but will probably just use some cherry bombs, It's got to be quiet enough to drive in Ionia...so I'm alittle concerned.
  17. kustombuilder
    kustombuilder
    from Novi, MI
    ****in awesome Matt. good to see your making some serious progress on the ole girl. lookin good. REAL good.
  18. It's looking good, Matt. Can't wait to see the body back on the frame.
  19. Ragtop
    Ragtop
    Nice stuff outa your shop Matt!
  20. fab32
    fab32
    So, you'll be driving it to Kalamazoo next weekend, right? No paint needed for a shakedown run.:eek: :D Seriously, Matt, it's looking good and I can't wait to see how it turns out. Keep the pictures coming.
    Frank
  21. Clark, I had the same thoughts on my T. I really dig the exhaust tunnels!
  22. spicoli
    spicoli
    from in a house
    here you go
  23. HotRodDrummer
    HotRodDrummer
    Dude...That's not really called for!! Damn man....
  24. DragginWagon
    DragginWagon
    from Tyler,Tx.
    Here you go guys!
