Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. blowby
    blowby
    from Nicasio Ca
    Good point, I only lifted one rear wheel on a Vette. Did that easy, no idea how it would do on a heavier load.
  2. ^^^ Great idea on the vacuum line and very clean!
  3. ekimneirbo
    ekimneirbo
    I had a regular HF hyd jack (full size) years ago. It was ****py and you could not control it when lowering. Got rid of it. Haven't had any problem with newer small ones, but I'm sure they have some bad ones on occasion. I'd say try one when someone buys one and see how it does. They really are handy when you are out in a field buying an old car and needing to put some tires on it........or alongside a road when no one is around to help.:)
    Its amazing how much heavier things have gotten as I get older.
  4. Dick Stevens
    Dick Stevens
    I have one of their 1.5 ton jacks and it works good lifting my cars but isn't great lifting the front end of my 4WD pickup. They do sell 2, 2.5 and 3 ton light weight racing jacks too, so it depends on what you buy on how much it will lift!
  5. I won one of those HF 1.5T 'racing' jacks at a chinese auction and was impressed enough that I bought three more. I waited until they were on sale though, got 'em for $50 each. Won't pick up what my 20+ year old 3T CostCo-bought jack will but weighs in at about 1/3 as much if not less. But will pick up one corner of any of my vehicles with no issues. Test 'em when you buy 'em, HF does have a 90 day warrantee and will exchange defective units.
    mad mikey, ekimneirbo and fauj like this.
  6. Ron Brown
    Ron Brown
    This is the rapid jack I got from Harbor Freight about 7 years ago.....use it daily....never any issues, the rapid pump feature is way cool...about 5 pumps with the foot pedal and its all the way up, but its not for lifting.....use the foot pedal until it gets to whatever you are putting the jack to then switch to normal handle jack...it's low profile too, low enough to slide under my Snap-on tool chest to stow. 104CF5EE-1545-412D-A473-6439901E375C.png
    ratrodrodder and ekimneirbo like this.
  7. seb fontana
    seb fontana
    from ct
    I spotted a friend's HF 1.5 light weight jack. I picked it up and thought it was light so I bought one. The one I bought wasn't as light. I can feel the difference and so could my friend!:confused:o_O
    ekimneirbo likes this.
  8. Six Ball
    Six Ball
    from Nevada
    I started reading this thread yesterday. Today I was in town and went to HF and checked out the jacks. I'm way more confused now. I shouldn't have clicked on this one. :eek:
    Jet96, vtx1800 and blowby like this.
  9. ekimneirbo
    ekimneirbo
    Try this one......$99
    Six Ball likes this.
  10. AGELE55
    AGELE55
  11. sunbeam
    sunbeam
    I have a piece of aluminum with 3 speaker magnets glued to it that I use. Easy on easy off easy to store I just stick it on the back side of my rollaway.
    AGELE55 and Six Ball like this.
  12. Super slick! Great idea. That has an ol' school look and feel that's right at home in there
    You could also braze instead of solder.
    X-cpe likes this.
  13. iwanaflattie
    iwanaflattie
    Im gonna share this hackery here...I built this little cart for my auto trans when I did a flexplate swap...its light,no oil leaks,easy to break down and easy to store...
    Then I modified it in 5 minutes to fit a sm465.
    All I do is roll it out of the way and roll it back when I'm done...
  14. chevy57dude
    chevy57dude
    Plans were to build these from steel angle and plate as drop on accessories for my engine stand, then post 'em to this thread. But others have wood stuff so here are the prototypes lol. I have a big rectangular drain pan that sits on a pair of 4x4 blocks or right on the stored heads. 20221002_191202.jpg 20221002_191233.jpg
  15. blowby
    blowby
    from Nicasio Ca
    On sale this weekend for $85. Gonna get one, an I'm sure I'll blow the other $14 on something..
    Six Ball and ekimneirbo like this.
  16. mr.chevrolet
    mr.chevrolet
  17. southerncad
    southerncad
    Man, that represents a lot of oil changes! But a good idea.
  18. BJR
    BJR
    If you can't get a nut started, try turning it backwards slowly until you feel it click down. Then turnout forward, and it should start to thread onto the bolt.
  19. blowby
    blowby
    from Nicasio Ca
    Hmm, looky what's new at HF
    chevy57dude likes this.
  20. Kentuckian
    Kentuckian
    Ever try changing the battery in a vehicle with side terminal posts. There is a special ratcheting wrench made just for those terminals. But if you drop the wrench it sometimes falls way down out of reach. The cure is to tie an old shoe string thru the hole in the wrench and put it up around your wrist. The shoe string trick works for other wrenches that might fall into the depths of the car never to be reached again.
    X-cpe, Hamtown Al, LAROKE and 10 others like this.
  21. Just Gary
    Just Gary
    Kids' soccer socks are perfect for protecting long thin chrome plated parts like axles & leaf springs.:cool:
    Hamtown Al, brEad, LAROKE and 5 others like this.
  22. Lone Star Mopar
    Lone Star Mopar
    Those long socks can be good as arm protection when wrenching around hot engine components. Just cut the end off and slip it over your arm...easy money.
  23. lostone
    lostone
    from kansas
    I used to use them as arm protection when using grinding and sanding disc's too.
    Got tired of those hot little Johnny balls seeming to always find the crease in my elbow joint, hell I looked like a junkie with needle marks after a hard day at work !!
  24. ekimneirbo
    ekimneirbo
    With me, they always seem to find their way into my socks. And there ain't no way to shake them off .....they just lay there and burn till they cool off. Got a scar on my left foot where a piece of molten slag landed just under the lip of tongue of my shoe...........it was like dancin at a hoedown. :D
  25. Country Joe
    Country Joe
    Good tip. I've always did it this way to start an uncooperative nut.
    And without fail, anytime someone is watching/helping me, they blurt out, "No, it goes the other way"
  26. jbon64
    jbon64
    country joe ....funny you mention this , the first time i saw someone do the "rotate backwards " nut /bolt starter trick was when i was in the navy and working along side an older salt . told him he was going the wrong way and he promptly stood up and punched me on my shoulder....hard punch ....got my attention and then schooled me on the procedure .
  27. Save that 3 or 4-inch toe section that you cut off to use as a shift knob koozie for when parked in the hot sun. Sometimes the knob can get "too hot to handle". :p
  28. Boneyard51
    Boneyard51
    I grew up in snake county on the ranch here in Oklahoma and my Dad made me always wear boots! At 71 I still wear tall boots 24/7!
    So I have to snicker at the guys with shoes, I have seen ….doing the “ hot metal dance” ! :p
    Bones
  29. big john d
    big john d
    from ma
    i spotted alightwieght craftsman jack in the s**** bin at work the person who put it there said it leaked i took it home with intensions of a cylinder rebuild after it sat for a while i put it on the bench and it really did not leak that bad i spotted an old half full bottle of auto trans sealer thought why not it has been leak free for 6 years now but i will not use it without a jackstand even if not going under the var
    seb fontana, Hamtown Al and Six Ball like this.
  30. atch
    atch
    Not being an a$$hat here, but I learned a long time ago that when welding or cutting always wear pants long enough and boots tall enough that the pants cover the boots. Then dingleballs can't fall inside your shoes/socks.
    edit:
    I started this response a while back and got interrupted. In the meantime @Boneyard51 replied saying basically the same thing.
