Projects Quad Headlight Grille Roadster
Discussion in 'Traditional Hot Rods' started by Rocket88NZ, Oct 29, 2022.
  1. Rocket88NZ
    Rocket88NZ
    Hi, just wanted to get some options and perhaps ideas as to thoughts on this mock up, not sure if its worth continuing , your thoughts. P1040376.JPG
  2. I like it, but it's not really era-correct for a Flathead-powered car...
    Quad lights first appeared in '57, the flathead was well on its way out.
  3. X38
    X38
    Thoughts? Okay. Quad headlights became a thing to do after factory cars started coming out with them. However, your build looks to be an earlier style than that. In other words a car built in the early fifties would not have had something that didn't come about until the late fifties/early 60's.
    lurker mick and Dean Lowe like this.
  4. Um....uh....er..... I don't want to hurt your feelings, but.....no! The quads (and maybe the Pontiac grill) don't match the era. JMHO, take it or not....
    lurker mick, VANDENPLAS and Dean Lowe like this.
  5. 38Chevy454
    38Chevy454
    Just my opinion, but I don't think quad lights look good on any hot rod. Even customs some restraint is needed. I'm just not a fan of quad lights.
    low down A, Tman, clem and 4 others like this.
  6. Slopok
    Slopok
    Not unless you're trying to copy the "Ala Kart" ?
    Dean Lowe likes this.
  7. jeff.l.hecht
    jeff.l.hecht
    I like it, is that Edsil or Chrysler head lights?
  8. Mr48chev
    On that car they look way too stuck on as an afterthought. As in "OH, damn, I need to do something to get ten more show points to beat Joe next season".
    I'd have to agree 100% the car wants something more befitting and appropriate for the flathead.
    Actually 36 Pontiac headlights to match the grill mounted in traditional hot rod fashion would look pretty nifty. Maybe even mounted like on a stock Pontiac if you have enough of the nose. 36 pontiac sedan.jpg
  9. Dan Hay
    Dan Hay
    I’m here for it. Proceed!
    Stogy, 3quarter32 and jeff.l.hecht like this.
  10. Mr48chev
    If you just had the A cowl was adding some back section that you scrounged up and cut down that came off a post war car and a overly flashy engine then the quads would be cool as all get out.
    Tow Truck Tom likes this.
  11. Dean Lowe
    Dean Lowe
    Well, you asked.
    lurker mick and dana barlow like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    I love canted quads.... I guess someone could have put them on his hot rod in 58 before changing anything else? Should be real "show rodish" to really pull it off. candy paint, lots of chrome, pearl rolled and pleated interior.... quads.jpeg
    EVL401, don colaps, ccain and 7 others like this.
  13. gimpyshotrods
    gimpyshotrods
    Can't be done.
    ccain, BJR, Stogy and 2 others like this.
  14. Okie Pete
    Okie Pete
    I like it . Looks Kool
    Stogy and 3quarter32 like this.
  15. Rocket88NZ
    Rocket88NZ
    Thanks for all your comments, original idea was early 60's show car with flake paint etc. as Mark suggested but appreciate that the flathead may not have been used in this era.
  16. oliver westlund
    oliver westlund
    I dig it. Building a car to a period is cool but its not how true rods were built, even an early rod built in 46 would get altered in 53, then again in 59 and in 63 and on.... build it how you like it. Looks like something ed roth wouldve done
    Stogy and Okie Pete like this.
  17. Rocket88NZ
    Rocket88NZ
    They are actually off an English car.
    jeff.l.hecht and 26 T Ford RPU like this.
  18. '52 F-3
    '52 F-3
    from Central PA
  19. hotrodjack33
    hotrodjack33
    Hmmm...I don't think you can pull that off without adding some more '60s custom touches to tie it all together. 0.36.jpg
    EVL401, akoutlaw, Just Gary and 6 others like this.
  20. Only if you also have tailfins in the back to keep the same theme.
    Rocket88NZ and Tow Truck Tom like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    A molded grille area between the tail lights with bullets or tubes between the tail lights would work too.... emporer.jpg
  22. 49ratfink
    49ratfink
    I like the design but the rest of the car would have to be equally radical or it would look off.
    Just Gary, Stogy, clem and 1 other person like this.
  23. krazee
    krazee
    Actually, for where you are in New Zealand, there were a few early cars around the 60's early 70's that had quads and Flatheads, although the engines were usually up graded to Y blocks later on. These were generally early builds that had been updated. I'm an old Rod Bender. Build it how you like, it is yours after all. In New Zealand we were generally behind what was happening in the USA and took our inspiration from the next Hot Rod mag we saw. Most things were adapted and m***aged from what we had access too.
  24. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    This is what we call the arc of a story. I'm glad to see all angles represented.
    Every one is right.
    Rocket88NZ has the last word.
    If you don't can't care for it change it.
    The motif factor does hold,, to support the image.
    Rocket88NZ, Stogy and Okie Pete like this.
  25. Rocket88NZ
    Rocket88NZ
    Emperor and the ****roach my 2 favourite roadsters. Thanks for all the comments encouraging and not. Definitely food for thought. Wanted to do something different with the front end but not make it the whole car focus, pretty difficult I guess. As Krazee said there were quite a few cars here modified this way in the early days although not really fenderless hot rods that I know of.
    Stogy likes this.
  26. stanlow69
    stanlow69
    Slim the shell down width wise and highth wise a couple inch and it would look a bit better.
  27. krazee
    krazee
    Most of the ones I was thinking of were sans the front fenders, with modified/bobbed rear fenders. Doug Smiths 36 coupe, another 34 Tudor that was chopped and channeled, 32 Mor door that was channeled only. Most were copied from the late 60's era in the States. For NZ, your mockup could be from the late 60's early 70's.
    Rocket88NZ likes this.
  28. Stogy
    Stogy
    Bring it on like Fink...before it eats your brain...just funnin' ya Mate...I suppose there were some that flatheaded it against the rules of engagement but I agree there were many OHV options tugging at the gas pedal for more in the later 50s and on. You've captured my interest...there's another Hotrod a Hamber has evolving and it sure shares similar details, mind you there are no quads...
  29. 34Phil
    34Phil
    would look better with headlights vertical with that grille IMO
  30. It does not fit the usual recipe, that most find pleasing. You need to decide if that is a good thing, or a bad thing.
