Technical LOUVER Dies to Match a Louver I Like
Discussion in 'Traditional Hot Rods' started by The37Kid, Oct 27, 2022.
  1. The37Kid
    The37Kid
    Found a 6 3/8 tall louver I like, how does one go about making the dies to produce them? Is every louver punch unique or are there standard die blanks that you grind to the shapes you want? Starting at square one, here are the louvers I want to stamp from a WWII Dodge Weapons Carrier hood. Thanks! Bob
    silent rick likes this.
  2. silent rick
    silent rick
    the louver press broke in the middle of punching holes in the hood of my 46 ford when it was in the possession of the previous owner. that was around 40 years ago. ran into the owner of the louver press a few weeks ago at a swap meet. told me he'll finish my hood in the spring. fingers crossed.
    still, i'd like to know the process of making a die that matches an existing louver
    jim32 likes this.
  3. NoelC
    NoelC
    Well, if you scroll the pages, do a search, a video link to just that was posted recently.
    The37Kid and ekimneirbo like this.
  4. silent rick
    silent rick
    on how to make a die that exactly matches an existing louver?
  5. Hitchhiker
    Hitchhiker
    I've seen longer ones like those done with a Pullmax before.
    seabeecmc and Tim like this.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Can't louvers be rolled on a bead roller as well as pressed with a die? Seems like I have run across something where someone did that. Making a long die would mean the die itself would have to be pretty strong. Some of the guys like Rootleib (?) make hoods to order for old Fords and they also aparently sell steel sheets with louvers pre-punched. They do the long louvers that Ford had on the 33/34 Ford Hood sides. I would't think they would have dies for each length louver, so thats why I'm thinking they might roll them .....but I'm guessing. :rolleyes:
    http://www.rootlieb.com/ford-1933-hoods.html
  7. seb fontana
    seb fontana
    from ct
    The louver pictured has a radius edge?
    The37Kid likes this.
  8. Elvis100
    Elvis100
  9. The37Kid
    The37Kid
  10. Elvis100
    Elvis100
    Post some pictures if you are able to make some
  11. The37Kid
    The37Kid
    This is a long way off part of my build, just good to know how things are done.
  12. AZ_Nick
    AZ_Nick
    To add to the above video, most old timers would drill a small hole at each end of louver and cut the slit between them. This will keep the metal from tearing at the end of the louver. You can also cut the slit with a thin cutoff wheel and finish with a hacksaw blade to get a nice square edge at the end of the louver.
  13. craig keenan
    craig keenan
    You can buy a set of Dies to fit a bead roller that work pretty good and you can make the louvers any length you want. These were done with a bead roller.
