Projects Just A Big Model (T)
Discussion in 'Traditional Hot Rods' started by BigJoeArt, Oct 4, 2022.
  1. BigJoeArt
    BigJoeArt
    Worked on the rear p***enger side of the body last night,
    I didnt take any in process pictures cause, well, it was a pain. as with anything, the first side is easy, making the other side match is the hard part.
    I got it tacked together enough to work on the rest of the interior bracing, so I bent up more tubing and that made the body much more sturdy.
    I tested out seat position and seat back thickness, and found that a thick back not only didn't fit, but was uncomfortable. I needed the softest, thinnest foam I could get.
    brEad, 2Blue2, GASSERBOB and 4 others like this.
  2. Tim
    Tim
    from KCMO
    Might consider running another piece of tube down the center of the back and then making a webbing back rest with the 3 uprights like a lawn chair. That soft foam is going to turn into crumbs pretty fast. Might be able to use some old army tent canvas and build in some adjustment to keep making it tighter as it gets older? Kinda like a trampoline?
  3. BigJoeArt
    BigJoeArt
    That sounds really overly complicated for a problem that a piece of foam fixes.
    badshifter likes this.
  4. Tim
    Tim
    from KCMO
    I’m just thinking that foam is a short term solution having used similar stuff over the years.
    though I have always used it along with springs which do end up mechanically aiding the deterioration. Guess we’ll see! Worse case you re do it, medium bad case you wear a hoodie with the hood down when you drive it lol
    brEad likes this.
  5. BigJoeArt
    BigJoeArt
    Im not using it exposed like that, at minimum it will have vinyl sewn up around it. I'm gonna try and convince my old local upholstery guy out of retirement to do black roll and pleat all the way around.
    brEad, AndersF and Sancho like this.
  6. I'm not following what you are thinking. I can understand how dropping the floor gives us more interior space. I don't see how lowering your floor eliminates a transmission tunnel. It would seem you would need an even taller tunnel. I'm not arguing, I really want to understand your thoughts.
  7. BigJoeArt
    BigJoeArt
    totally, so I am doing something unconventional, but not uncommon, by running the bellypan under the trans, from bottom of framerail to bottom of framerail, and then sealing it up around the bellhousing and the back of the trans. so the whole trans body will be open to the p***enger compartment. this means I will not have a tall tunnel, simply cause I wont have one at all. this will make more sense as I close up the gaps over the next month.
    hope that helps clarify, I'm glad to answer questions about why I'm doing things a certian way. Cause I tend to bend the rules a bit.
    also busy day in the shop today, hopefully new post tomorrow.
    winr, brEad, Sancho and 2 others like this.
  8. AmishMike
    AmishMike
    Trans will be a built in heater for those cold days, or hot days
  9. BigJoeArt
    BigJoeArt
    A good birthday weekend.
    Started Saturday morning with pulling the body back off the car, but before I did that, my dad wanted to try it out.
    Being almost a foot shorter than me, he fit without a problem, and should be able to drive the car quite comfortably.
    after cutting the tacks holding the body on, pulling the still fairly floppy body off, i cut loose the under dash structure, and began fully welding it, and finishing all the connections for the tubes.
    while I worked on that, my dad and Mike started making the "subrails" aka 1/8 flat plate, cut to the size of the top of the rails.
    I also pulled a couple strings and got a much better transmission from my dads stash.
    We decided that 4 bolts on the driver side subrail, and 5 bolts on the p***enger side subrail with two under the door would be sufficient to hold the body on.
    I also cut down an aluminum trans mid plate to place the trans input shaft in the correct spot. (4 cylinder S10 trans)
    I welded the under dash brace to the subrails and remounted the body, only to find two of the holes were in spots that don't work. so I re-drilled them, and got them bolted in completely.
    after a little cleaning and putting tools away, I was ready to pull the tamale wagon in for the night.
    Today after church and going around in a costume with my daughter, I got to mock stuff back up and play with shifter location and apparently Co-pilot trials...
    The shifter is one that i've had for awhile, it's a tapered shaft, with an old bakelite knob stuck on it.
    hopefully i'll get a couple parts in the next couple days and i'll continue with progress.
    winr, brEad, Snicklefritz65 and 6 others like this.
  10. guthriesmith
    guthriesmith
    Man you work fast Joey! And, I’m really digging this car! :cool:
    BigJoeArt likes this.
  11. Tim
    Tim
    from KCMO
    Man that’s a lot to get done in a weekend. Six hands make quick work!
    are the holes in the subrails on the p***enger side different front the drivers side - one extra bolt and several not on the same center line as the others- because of the functioning door on the p***enger side and having to have the bolt heads accessible with the jamb etc in the way?
  12. BigJoeArt
    BigJoeArt
    thanks, it is nice to have friends help.
    the holes in the driver side are all existing frame holes except the rearmost one.
    we tried to do the same on the p***enger side, (plus adding an extra one for door support) but the existing frame holes are further out on the rails, so when I put the body on, two of them hit the body bracing. So, I had to move those two. so while random they are still mostly factory holes.
    Sancho and guthriesmith like this.
  13. BigJoeArt
    BigJoeArt
    had a little time after the kiddo went to sleep, so I convinced the wife to come downstairs and sit in the p***enger seat, since next year she will be riding with me to Oklahoma for the gathering at the Roc!
    here's an overview of the ****pit area, I think the trans was in 3rd here?
    it will be really easy to get in and out with the wheel off (quick disconnect) but it is possible to get out with the wheel on, in an emergency.
    winr, brEad, AndersF and 5 others like this.
  14. BigJoeArt
    BigJoeArt
    winr, Snicklefritz65, Jet96 and 8 others like this.
  15. BigJoeArt
    BigJoeArt
    I got more done last night, I just forgot to take pictures of most of it.
    I did take pictures of my driveshaft hoops in place (beginnings of a driveshaft tunnel) I cut the rear crossmember out for clearance, but will be adding to the bottom of it for support. I actually cut the piece out, but didn't take a picture of it.
    I also tore apart an old third row van seat to steal the seat bottom foam out of. looks like it should work great, just have to pick up some webbing for the seat bottoms.
    I worked for a minute on seat base mounts, I'm gonna make the seat bases from plywood that can pull up out of the floor, the p***enger side will be storage, the driver side, wiring.
  16. BigJoeArt
    BigJoeArt
    I will also note that I checked clearance on the rearward driveshaft hoop, and the rearend can droop 2.5" and compress 5 inches without hitting the hoop.
    brEad and Sancho like this.
  17. guthriesmith
    guthriesmith
    You know you will now have to keep the roadster forever since you are making memories with your daughter. :D I screwed up and sold the car that I used to take my boys on road trips in down to the LSRU, etc. back when they were both still in diapers... :oops:
    brEad, BigJoeArt and Sancho like this.
  18. Tim
    Tim
    from KCMO
    Haha I’m gonna try that rational at the next swap meet.
    “uhh timm did you buy a $4000 super charger??”
    “Well I kinda had to it was the first super charger our child touched at a swap meet in April when it was 67 degrees. The laws of father hood deem I shall not break the bind of this obviously core memory. I basically had to in layman’s terms”
    lol
  19. guthriesmith
    guthriesmith
    Let me know how that works out for you @Tim :rolleyes: But, I say you should definitely try it. ;)
    Tim, BigJoeArt and Sancho like this.
  20. BigJoeArt
    BigJoeArt
    well, didn't mean to leave that long, but I have a lot to share now.
    I've been making progress with the ch***is,
    I used the sections I cut off the rear of the frame to make a kick up of sorts to hold the rear deck and to place the top shock mounts. don't worry, they aren't finished yet.
    when I cut the notch out to install the hoop, it took the structure out of the tube, so I added a thick piece of angle as a rear crossmember, in order to add strength back and also close off the end of the frame.
    my buddy Ryan Pope sent me a care package with a near mint door for my T.
    (the Pirellis will get run on something eventually, they are the *****inest tire ever made)
    heres a shot with the deck sitting on the new rear framerails. I still have more to trim and fix.
    I also build the rear support structure for the vw tank, and cut the hole (poorly) for the filler neck.
    more in a minute. . .
    brEad, Lil'Alb, GASSERBOB and 3 others like this.
  21. BigJoeArt
    BigJoeArt
    I decided to roll it back outside to check proportions again, since I raised the deck again.
    I also got a couple peoples opinions on the rear filler panel behind the tub, and I decided to emulate the front cowl piece and add a curved panel that connects the deck to the main body.
    I hopped up on a buddies truck cab to shoot some overhead shots..
    I also roughed in the shock mounts up front, I was waiting on the new (to me) shell to final cut the tops of the frame. they are F1 shock mounts, with the little speedway add on shock mounts on the bottom of the spring perch bolt. once the mounts are done, I'll weld them to the bottom of the batwings, so they don't move.
    More random goodness while I swept the shop out.
    had to have another test fit with the cutest co-pilot
    once back inside, I dove into making a framework for the inner firewall/bellhousing cover. finally got to use my sheetmetal brake I bought this summer.
    even more in a minute....
  22. BigJoeArt
    BigJoeArt
    on a bit of a corelated sidetrack, yesterday I met up with some buddies down in KC and had breakfast and visited a couple shops. we had a good day parking wherever looked good, and generally causing disruptions to average peoples Sunday morning.
    all in all a good day, and I picked up a couple of T grilles that are better than mine so I can cut the front shock . . horns? . . down. hopefully I can get it all mounted today.
    whew. that's it for now. we are now up to date again.
    rjgideon, tr_rodder, 2Blue2 and 3 others like this.
  23. Tim
    Tim
    from KCMO
    D47275D2-D0CF-483C-90E3-321B9B6608AF.jpeg Yesterday was great day
    A Boner, Lil'Alb, tr_rodder and 4 others like this.
  24. BigJoeArt
    BigJoeArt
    Finally got another night in the garage,
    I got a couple pictures of the gas tank mounting structure I built last Saturday.
    Last night I worked on my trans tunnel,
    I finished welding the rear crossmember and made a paper pattern (perks of being an artist with paper everywhere) then transferred it to some sheet metal and plasma cut it out. its kinda a weird shape with one hoop taller than the other but it wound up really nice. I then used some small angle I had laying around, to build the seat frames. I blocked them up so they matched the angle of the top of the frame rails. the seat bottom will be plywood with straps across an open center.
    of course I had to rough cut a piece of plywood and some foam to try the seat out.
    Of course, as soon as I sat in it, I realized my steering wheel needed to move, so I moved the support heim further over, and adjusted it down a smidge. I may even be able to shorten the column in inch or so, but ill wait to see what the seat feels like when its more finished.
  25. A Boner
    A Boner
    Is the floor pan (foot well) going to be flush with the bottom of the frame or ever a little lower…for extra foot room?
  26. Tim
    Tim
    from KCMO
    @A ***** yes he’s making the floor level with the bottom of the frame rails
  27. BigJoeArt
    BigJoeArt
    yes, I am building a thick bellypan that will double as the floor. it will be flat with the bottom of the framerails.
    Tman and Sancho like this.
  28. A Boner
    A Boner
    Cool, that’s an extra 3 or 4 inches of foot/leg comfort! Every little bit helps…especially in a “T”!
  29. redzula
    redzula
    How did I manage to contribute by transporting your turtle deck to the Roc on the first page and only just now find your thread where you built almost the whole car in a little over a month.
    Fear not I'm tuned in now. This thing rules.
    brEad, drdave, Sancho and 3 others like this.
  30. BigJoeArt
    BigJoeArt
    good to have ya buddy! big thanks again for bringing the turtledeck up with ya!
