Projects T C cab. 60's style on the cheap!
Discussion in 'The Hokey Ass Message Board' started by dumprat, Sep 10, 2022.
Tags:
  1. I'm trying to figure out what you were doing with that lathe set-up and how it worked?
    Like your project(s) by the way. What part of BC?
  2. dumprat
    dumprat
    from b.c.
    @anothercarguy
    I needed to thread the ends of the ladder bar tubing. It's slightly too large to fit through the headstock. So I clamped it in a V block to the tool post once. Had the tube centered on the live center. Then I could pull the tailstock back and use the live center to keep the tap straight. Make sense?
    I'm in Parksville
  3. dumprat
    dumprat
    from b.c.
    IMG_1197.JPG Yet another small update from the world of decrepit used hot rod parts! Got all the nastiness filled and ground out of the original front spring mount. Had to make a new center. The old one had lot of torch work done to it.
    tb33anda3rd, brEad, spanners and 8 others like this.
  4. dumprat
    dumprat
    from b.c.
    IMG_1200.JPG A little closer. That speedway spring needs to down to three leaves I think. Way too stiff now.
  5. dumprat
    dumprat
    from b.c.
    Not my first rodeo. It's way to stiff.
  6. I like the traditional method of "mockup" to build your projects. Noticed the dual pattern Turbo 350, used one in my Model A roadster with Buick 225 V6 way back. That was a mock up build too.
  7. Dave G in Gansevoort
    from Upstate NY
    Making good progress. Keep after it...
  8. dumprat
    dumprat
    from b.c.
    Absolutely! Unless your building something from kit plans or have built the same thing three or more times everything needs to be mocked up before final, unless of course you like cutting things apart three or four times! Lol
    I don't know anything about Chevy stuff, usually I avoid them but for $350 for a rebuilt motor and a complete trans with chrome pan I couldn't say no. Is there something special about the dual pattern trans?
    Outback and Tim like this.
  9. Nothing special, other than you have choice of pretty much any GM engine to go in front.
    dumprat likes this.
  10. tricky steve
    tricky steve
    from fenton,mo.
    Wheelies are fun ! man your car is awesome ! love the panel paint too . I can't imagine doing wheelies in this thing without wheelie bars, i think the thing would flip over! doesn't look like your car has them, you must have balls bigger than church bells ! 4gth4h.jpg
    Tim_with_a_T, Deuces, swade41 and 2 others like this.
  11. dumprat
    dumprat
    from b.c.
    IMG_1305.JPG IMG_1306.JPG IMG_1308.JPG IMG_1310.JPG Fitted the king pin bushings and got the spindles ready to make it a roller. I ream one to fit the small pin first and bump the ream up to do the second one. I fit them with about .0002 of clearance. They just pound in with the ball of my fist.
    Halfdozen, tb33anda3rd, winr and 4 others like this.
  12. goldmountain
    goldmountain
    I was working on a car. Said it wasn't my first rodeo. Looked at the car - ISUZU RODEO. It was my first rodeo!
  13. alanp561
    alanp561
    Ahhh, what rod were you using?
  14. A Boner
    A Boner
    Ch***is is looking great. Hope you don’t channel the body over the frame…more mechanical look with the body sitting on top of the frame and the frame showing, and more interior room too!
  15. dumprat
    dumprat
    from b.c.
    Some Esab **** I had. I'm out of the Artec 223 I prefer.
  16. dumprat
    dumprat
    from b.c.
    IMG_1319.JPG IMG_1322.JPG It rolls! Still fooling with bearings and brakes ideas.
  17. dumprat
    dumprat
    from b.c.
    Pulled out my hand dandy "pipe squisher" and built a trans cross member. My welds turn out a lot better when I remember to put my gl***es on before the helmet... IMG_1354.JPG IMG_1355.JPG
    Outback, brEad, Tim_with_a_T and 10 others like this.
  18. 2OLD2FAST
    2OLD2FAST
    from illinois
    Oh LOOK ! someone smart enough to put in a removable cross member & the tie rod behind the axle :p
    Outback, dumprat and Moedog07 like this.
  19. dumprat
    dumprat
    from b.c.
    @A ***** i have this horrible idea in my head to build this int a C cab delivery with an actual steel body, and definitely not channeling it.
  20. dumprat
    dumprat
    from b.c.
    IMG_1356.JPG 69906034339__381CEFFF-6091-4568-BC14-280DD76ACE2A.JPG I got these old fibregl*** buckets from a friend years ago. They should look perfect in a T. They are super cool just too narrow for my hip bones. I'm going to try and widen them a couple inches. Wish me luck....
    brEad, tb33anda3rd, Just Gary and 7 others like this.
  21. dumprat
    dumprat
    from b.c.
    IMG_1369.JPG IMG_1370.JPG Fooling with little side project. Replaced the reflectors in a very old set of steel backed sealed beams. Used some off a set of cheap H4's. Modern lights in a vintage look.
    Finnaly got enough time to finish up the headlight buckets and get the mounts on. Still need grinding and adjusting. But you get the idea.
  22. Tim
    Tim
    from KCMO
    Slick
    treb11 and dumprat like this.
  23. dumprat
    dumprat
    from b.c.
    IMG_1391.JPG IMG_1392.JPG Picked up a couple of parts at a local swap. I think they will work great on the T. I am going to revamp the project and change things around a bit. All for the better.
  24. Tim
    Tim
    from KCMO
  25. dumprat
    dumprat
    from b.c.
    70449227280__A45C4408-5A95-4E43-B7C8-FEE06589A1F7.JPG IMG_1399.JPG IMG_1400.JPG Fun little project today. Getting the rear wheels figured out. One of these had been cut free of a ch***is with a cutting torch! Bet ya can't tell which one.
    I sure miss having a Bridgeport mill at my disposal. Had to build a little cutter to re do the washer spot faces.
  26. dumprat
    dumprat
    from b.c.
    IMG_1405.JPG IMG_1406.JPG I guess I need to move the motor up an inch or so. Exhaust collectors won't fit and no room for steering..
    brEad, tb33anda3rd and Vic Walter like this.
  27. Tim
    Tim
    from KCMO
    It’s about that point when you say to yourself “oh, that’s why everyone runs makes headers out the side”
    lol good progress even if it’s kinda… sideways.
    Outback and brEad like this.
  28. dumprat
    dumprat
    from b.c.
    Very true, but it still doesn't leave room for a steering box and I love a challenge...
    Just Gary and Tim like this.
  29. dumprat
    dumprat
    from b.c.
    IMG_1662.JPG IMG_1667.JPG IMG_1668.JPG Been a while since I updated this thread. Lot s on the go lately life wise. New job means I have more time off which means I actually had a whole day in the garage today! (It's my Sunday, even though it's Tuesday. I work 4 days a week. )
    As I spent the day cleaning and putting away junk I actually managed to spend several hours on the T project. (Notice I changed the ***le of this thread?) I don't have time to build 2 T's or the space so it sold off the dropped 34 axle with the speedway spring and decided to use all the good stuff on one ch***is and hope fully build a neat "show car" inspired T C cab out of it.
    I got a lightly used A mono leaf from a friend and used the stainless bat wings I had with new stainless shackles and chrome perch pins. I've had a chunk of thin way stainless tube in my stash for years for this very reason. I want to extend the cheap 4 link bars about a foot and will sleeve them with the stainless. Should look neat. Haven't decided on hemi joints or tie rod ends yet. Needs to be cheap and shiny! Front axle will actually go down and inch or so.
    Rear is going to come up a bunch! And it needs to go back about 4" . Should be about 107" wheelbase.
    I set the firewall in place. I like the height but it needs narrowed 5" to match the early cowl top I have. Good thing it's not a restoration.
    It might be cobbled together junk but I think it has potential. All I need is a million dollars worth of chrome....
    Outback, brEad, tb33anda3rd and 7 others like this.
  30. dumprat
    dumprat
    from b.c.
    Been "hit" with a slow down.
    Crashed hard on my mountain bike and hit a stump with my arm and dislocated my shoulder. Been a bit of a rough week. Going to be a few weeks before I have enough strength to do much in the garage.
    Outback and Tman like this.
