Projects 1960 Cadillac Sedan "Sharky"
Discussion in 'The Hokey Ass Message Board' started by lincolnkid, Oct 28, 2022.
  1. Lights stuck on high beam- usually the floor dip switch.
    Power vent windows- the driven gear usually strips on these, new ones available through McVey's Caddy parts (not cheap).
    Dash lights- the dim function on the light switch usually ****s out, if you remove the dash light wire from this and feed it from the park lights terminal , you will get full brightness bulbs.
  2. lincolnkid
    lincolnkid
    The way the paint/bondo flaked off the lower half of the car is super weird. It was originally a slightly lighter shade of turquoise, then repainted in the somewhat darker shade you see on it now. Someone welded in some patch panels which are mostly still there but I guess it needed a lot of bondo to smooth it out. There are big patches of bondo that have fallen off the p***enger rear quarter (apparently a bullet hit it) and the driver rear door too. If I leave it a few years it may start to look like a green cow.
    Front seat is sunken in where the driver sits and really uncomfortable, you can tell almost no one has ever sat on the p***enger side. There is a company called SMS Auto Fabrics that a lot of the factory spec restoration guys talk about that can get you OEM reproduction fabric and I may do that!
    Thanks -- gonna order kits for the other two carbs, I popped the lid off the front carb and it was full of varnish and possibly remnants of a mouse nest on the throttle plates.
    That makes a lot of sense because the dimmer switch doesn't do anything until you turn it all the way to the left and the cabin lights cut on. I will have to try that, might be an easy way to fix it!
  3. lincolnkid
    lincolnkid
    Just a quick update: rebuild the outside carbs which were even more gummed up than the center carb.
    Somehow lost the cobbled together fuel lines that go to the secondaries so I took that as an omen to order the proper reproduction pre bent tri power fuel lines from Caddy Daddy. They weren’t too expensive.
    gonna be running on center carb only until that stuff gets here. It seems like I still have a dead spot in the pedal if I stomp on it although it is much better than before I replaced the accelerator pump.
    Next up are exhaust and tires. I also would like to route the draft tube back into the air cleaner somehow.
  4. 37 caddy
    37 caddy
    from PEI Canada
    There is a great forum for these old caddys at the Cadillac-Lasalle clubs website.It is free to join and im sure someone there can help wit your project,it is a fairly active forum and always guys on there who live for this type of stuff. Harvey
  5. carbking
    carbking
    Often, a dead spot on acceleration from a stop is caused by adjusting the idle mixture control screws TOO RICH!
    ***uming the engine condition is somewhere between 1000 miles and not burning oil, then the idle mixture screws should be at 1 turn from lightly seated.
    The choke should touch closed (no tension) on a cold engine with an ambient of between 65 and 70 degrees F. Run the engine until the choke ****erfly is vertical (choke is completely off), and set the idle according to the manual (GUESSING about 550 RPM in drive) using the throttle positioner screw.
    A new engine, badly worn engine, or modifications could change the above
    Jon.
  6. SS327
    SS327
    Please listen to Jon! If you sold the car without the tripower you would loose more money than you would make selling the tripower. GM ain’t building them anymore!
  7. lincolnkid
    lincolnkid
    Thanks! I think it was set to idle way too rich. The annoying thing about this setup is it’s almost impossible to reach the idle mixture screws with the front carb installed. I did tweak it a little bit with the front carb off and it was set wayyyy wayyyyyy too rich. So now it seems a little happier but I still have more work to do.
    Tri power fuel lines will be here at the end of the week by the way — I’m keeping it.
    I found a set of used thin whitewall radials for a good deal. My bias plys are really too unsafe to keep driving the car. While I had the car up on stands I noticed what seems to be gear oil running down the tire so I guess I blew an axle seal suddenly.
  8. SS327
    SS327
    From over here it looks like brake fluid. But your there and seals do go bad.
    chryslerfan55 and 34 5W Paul like this.
  9. Check that your diff vent is not blocked. It is usually part of the br*** brake splitter block mounted on the top of the axle housing. You could put a "T" piece on you vacuum fitting going to the power booster, and install a PCV valve in there.
    chryslerfan55, RMR&C and lincolnkid like this.
  10. carbking
    carbking
    On a factory tripower, the idle mixture screws may be adjusted quite easily:
    (1) Acquire a six inch piece of vacuum hose from your FLAPS that will fit over the head of the screw
    (2) Cut in half, and slide each half over one of the screws with the carburetor OFF the car
    (3) Turn each screw to lightly seated
    (4) Make a mark ((paint, tape, your choice) on a point on each hose denoting the lightly seated position
    (5) Reset the screws to where they were
    (6) Re-install the carb, the screws are now adjustable by rotating the hoses
    Jon
  11. NashRodMan
    NashRodMan
    Just saw this post for the first time. These are one of my favorite cars. Love the big ones. Anyway, you are getting a ton of good info/help here. You've gotten a lot done but still have a ways to go. Just keep at it. Make lists and tackle one thing at a time. I'll be watching this thread!!
    chryslerfan55, MOTOV8N and lincolnkid like this.
  12. lincolnkid
    lincolnkid
    Yeah that is what I thought initially too.... Once I got the drum off it was def gear oil.
    I will have to check that. Stupid question but the diff vent clogged would mean what? It pressurizes too much and blows out the seals?
    Wow. I can't believe I didn't think of that. Great idea. Thank you again for all your help in this thread.
    chryslerfan55, 54delray and SS327 like this.
  13. [QUOTE="lincolnkid, post: 14671302, member: 127761"I will have to check that. Stupid question but the diff vent clogged would mean what? It pressurizes too much and blows out the seals?.[/QUOTE]
    It won't blow the seal out, but the hot air inside (expansion) will blow the oil past the seal.
  14. Fat47
    Fat47
    Welcome back. By the way Sharky's is my favorite bar in Panama City. Go there every time I am in town.
  15. Bleach
    Bleach
    Avoid McVey. His stuff was really expensive even 25 years ago. He was a **** to me after I pointed out some issues on a repop trim part.
    Caddy Daddy is OK. I had good experiences with him.
    chryslerfan55 and southerncad like this.
  16. by the way... your high beams were on.
    nevermind, i see you resolved that, its very often i see people wondering what the little red light means.
  17. Hombrechevy
    Hombrechevy
    Hola, Limcoln Kid,
    Felicidades por tu Caddy, tengo uno 60 4 doors Caddy too, (I present it today in presentations forum),
    Mi Caddy tiene un 390 original con Edelbroock de 4 cuerpos pero nunca lo conduje,lo compre en 2019 y solo he dado una vuelta alrrededor del garaje apra ver que necesita reparar la caja de cambios,de modo que he empezado a restaurarlo,y no te puedo decir si ira bien o mal con el Edelbroock,pero desee luego yo matendria el tripower en su sitio!!!
    No se muy bien como funciona este foro y me pierdo en tantas categorias,foros,subforos y todo eso,por lo que estaríaria bien que hubiera algun modo de poder localizar hilos por modelos.
  18. alanp561
    alanp561
    Click on the magnifying gl***, circled in red, type in Cadillac and click on search
    chryslerfan55 and guthriesmith like this.
  19. nochop
    nochop
    from norcal
    One thing I learned about tri powers is that if they are linked progressively, the secondary carbs have a tendency to load up with bad gas from not being used. So go out and floor it!
  20. nochop
    nochop
    from norcal
  21. nochop
    nochop
    from norcal
    X2 on the fire extinguisher
  22. lostn51
    lostn51
    from Tennessee
    Nice car and great story I will be following hope to see a post from him soon!!
    Outback and nochop like this.
  23. 57Fury440
    57Fury440
    Keep the tri-power!!!
  24. mohr hp
    mohr hp
    from Georgia
    No doubt! Without that tri power, it's just another old Cadillac!
