1948 Lincoln parts
Discussion in 'Parts For Sale' started by two couped up, Sep 28, 2022.
  1. two couped up
    two couped up
    from pa.
    City: Allison Park
    State: Pennsylvania
    Price: in ad
    1948 lincoln parts, hood hinges $50. pr. column shifter ***y. with rods to the trans.$175. clutch swivel with needle bearing $40 clutch linkage $40. clutch release lever $25. motor mounts and trans mount $150. accelerator swivel, bolts to firewall $50. e-brake lever ***y. $40. windshield aluminum garnish and stainless frame trim $150. defroster nozzle $35. front axle u-bolts & plate $50. rear axle u-bolts & plate$50. also, the front and rear axle bracket with the insulators that mount the springs to the frame crossmembers $40 each, trumpet horn $40. one door hinge spring bracket $30. wiper motor $15. wiper tower with the short arm for parts $20.
  2. two couped up
    two couped up
    from pa.
  3. two couped up
    two couped up
    from pa.
  4. two couped up
    two couped up
    from pa.
  5. two couped up
    two couped up
    from pa.
  6. two couped up
    two couped up
    from pa.
  7. two couped up
    two couped up
    from pa.
  8. two couped up
    two couped up
    from pa.
  9. two couped up
    two couped up
    from pa.
