Technical wheel bolt pattern help
Discussion in 'Traditional Hot Rods' started by birdman1, Nov 4, 2022.
  1. birdman1
    birdman1
    I have looked all over the internet and can't find the bolt pattern for a 1960 Mercury monterey. some say 5x4 1/2 and some say 5x5. I am going 225 miles to pick up a newley aquired 1960 Mercury Monterey canvertible. It has 2 flat ties, so I want to take a couple tires and wheels along so I can load it. thanks for any help.Henry
  2. Slopok
    Slopok
    How about a couple of those multi lug pattern compact spares?
  3. greybeard360
    greybeard360
    I am thinking my 60 Merc was 5 on 5.... It had wheels from a Riviera on it if my memory is correct.
  4. AccurateMike
    AccurateMike
  5. squirrel
    Hollanders says 5", they're pretty reliable on that stuff
  6. I see 5x5 from 55 to 60. Jay Carnine had posted that. He was a good guy with good info.
  7. 19Fordy
    19Fordy
  8. Budget36
    Budget36
    Enough information to be confusing. Maybe have the seller take a tape measure across the rear wheel studs and remove all doubt.
  9. 1946caddy
    1946caddy
    from washington
    Why not just take two tires and have them mounted on the existing rims
    LWEL9226, rusty valley, MCjim and 2 others like this.
  10. Beanscoot
    Beanscoot
    Might as well bring a tire pump too, in case the flat ones hold air well enough to load, saving the hassle of changing them.
    05snopro440, LWEL9226 and Brand Apart like this.
  11. Beanscoot
    Beanscoot
    With a lot of sellers, that really won't remove the doubt.
    67drake, 302GMC, Boggus Deal and 5 others like this.
  12. squirrel
    RICH B, Tman, 05snopro440 and 3 others like this.
  13. Beanscoot
    Beanscoot
    Who the heck would compile a chart of old American car wheel data and convert it to metric?
    missmuriel, RICH B, Tman and 2 others like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup as squirrel said Hollander lists a 14x6 wheel with a 5 on 5” bolt pattern. Always believe the books before the internet E0D9F139-4088-4F7C-8198-CB1114D2F596.jpeg
    Tman, Just Gary, LOST ANGEL and 2 others like this.
  15. tubman
    tubman
    In his original post the O/P said "1960 Mercury Monterey canvertible" (that's a direct quote from it).
    Fortunateson likes this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    that chart shows 1950-1974 using 14" wheels, that is what squirrel is talking about
  17. birdman1
    birdman1
    Thanks fellas, the car is 225 miles away and the seller is a 87 year old guy. Most people don't know how to measure wheel bolt pattern . I'm going to go with the 5x,5
    Just Gary and squirrel like this.
  18. squirrel
    you'll be fine
  19. Rand Man
    Rand Man
    Does anyone know of a factory steel wheel 14 inch diameter 5 x 5 1/2 bolt pattern?
  20. Rand man- roadmaster and otaco farm wagons had that bolt pattern as did a bunch of other farm machinery. They shouldn’t have nubs for hubcaps, came in both full dish smoothy style and conventional. These were likely produced in the 70’s. If it is really important I can take pictures. I don’t know of any automotive applications.
  21. Mr48chev
    You are always a hell of a lot better off starting a new thread when you have a question than tacking it on a thread that is actually a differeent topic and where it goes down the page where people who don't read through never see it.
    There are a***** ton of Ford and Mopar 14 inch wheels with 5 on 5 lug pattern floating around. Watch the center hole diameter though as while the lug pattern is the same the center hole may be different.
    Andy likes this.
  22. Mr48chev
    I would have to look but If I didn't sell them the wheels off my daughter's old 79 Mercury Monarch should have been 14 inch.
  23. AccurateMike
    AccurateMike
  24. '29 Gizmo
    '29 Gizmo
    from UK
  25. Rand Man
    Rand Man
    Just to clarify:
    The 5 lug bolt pattern must be on a 5 1/2 inch circle. this early Ford , Ford F100 pickup and some Lincolns.
    I have a 1950 Lincoln. Long story, but I bought a used set of aftermarket wheels that are not right and not easy repair. I have a new set of tires and nice full wheel covers. Thought I might see if some steel wheels were available. I know Lincoln switched to 14 wheels in 1958, that trend went through 1960, but I don’t know how long it lasted. I can do my own research. Just felt like conversation.
  26. Lloyd's paint & glass
    I've never seen big Ford pattern in a 14" diameter myself. I always had to dig hard to find 15" when I was a Model A man.
  27. twenty8
    twenty8
  28. rusty valley
    rusty valley
    Mentioned here before, I have a 14" ford smoothie, like the 40-66 centers. no idea what it came off, its on a home made trailer. now. Gonna break it down soon to get the 34 rear end thats under there too. will report back when its a proven thing
  29. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    twenty8 likes this.
  30. twenty8
    twenty8
    I joined here too late to know him, and many others. It is humbling to be able to read and learn from the stuff these guys contributed. It sort of keeps them here with us, if you know what I mean.
    daylatedollarshort likes this.
