Projects Hotrod31A build thread
Discussion in 'Traditional Hot Rods' started by Hotrod31A, Jun 26, 2022.
  1. vtwhead
    vtwhead
    Much nicer for sure.
    31chevymike, AHotRod and Hotrod31A like this.
  2. brEad
    brEad
    One piece at a time, soon it will all look perfect!
  3. AHotRod
    AHotRod
    Do you @Hotrod31A have a link to the RJ Ch***is you picked? If so I would like to look at it.
    Model A Hot Rod Coupe's RULE!
    Glenn
    31chevymike and -Brent- like this.
  4. Hotrod31A
    Hotrod31A
    Hope this link works. Check his discounts he offers, may save you some money.
    https://rjays.com/
    I ordered the complete ch***is, exactly like the black A he has pictured on his website. You can option as you please and if you call Cory he is very helpful and will modify and build anything you can dream up.
    panhead_pete and AHotRod like this.
  5. speedster t
    speedster t
    Look at Prime welders good machine and real good customer service
    rjgideon likes this.
  6. Fitnessguy
    Fitnessguy
    Great looking build brother! Brings back lots of memories on my coupe build. Doing lots of sheet metal and rust repair on my 56 build right now so I feel your pain on all the welding, grinding etc. Short term pain for long term gain!
    31chevymike and Hotrod31A like this.
  7. Hotrod31A
    Hotrod31A
    Thanks! I’ve went from “not sure I can do this “ to “ hold my beer and wheres my cutoff wheel?” In about 16 weeks.
    31chevymike, brEad, AHotRod and 2 others like this.
  8. Hotrod31A
    Hotrod31A
    Spent the week cleaning up the driver’s door chop lines and some rot on the frame. Wasted the past two days chasing paper thin sheetmetal and blowouts on the old chop lines with the tig.
    Finally today broke out the sheetmetal and started cutting the janky out , then things started moving in the right direction , much quicker with better results. slow but steady…. F6AE15CD-3001-4465-8795-16957FFB68F5.jpeg
    84D159BA-6D4C-4846-8AE0-6D1B21D08BD4.jpeg 392A8768-155E-487A-A4B4-762277679FB4.jpeg 1F53D88C-335C-4A1B-B537-C68519181A44.jpeg 93D24004-4306-4294-8EFE-D36FA3300111.jpeg D0D30F57-D743-467A-AE5D-93E617EE612E.jpeg C116FFED-12AF-4335-866E-CE868096ADAB.jpeg
  9. DG1930 Coupe
    DG1930 Coupe
    Awesome Project....looking good!! Keep at it and good luck
    Hotrod31A likes this.
  10. attitudor
    attitudor
    from Finland
    Great project, Thanks for sharing!
  11. tomcat11
    tomcat11
    Looking good man. Keep at it.
  12. Hotrod31A
    Hotrod31A
    It’s been a minute, as everyone says life gets in the way.
    Big day today as we finally picked up our Rjays ch***is. I can’t be any happier with this decision as it’s exactly what I was targeting. Cory has been very helpful to offer suggestions and he was spot on, it has definitely been worth the wait.
    Unfortunately we are in the middle of a move from Texas back to Kentucky so the build will be on hold until the new shop is built and everything gets moved. I can’t hardly wait to finish this thing..
    The Texaco gas pump jockey stole the show…
    IMG_0135.jpeg IMG_0138.jpeg IMG_0139.jpeg IMG_0140.jpeg IMG_0142.jpeg IMG_0124.jpeg
    Outback, 31chevymike, -Brent- and 9 others like this.
  13. Tim
    Tim
    from KCMO
    Very nice!
  14. Hotrod31A
    Hotrod31A
    Running gear paint and ***embly in preparation for the first body fitting. Need it to be a roller so I can move it soon.
    IMG_0274.jpeg IMG_0281.jpeg IMG_0293.jpeg IMG_0279.jpeg IMG_0280.jpeg IMG_0281.jpeg
  15. -Brent-
    -Brent-
    Everything is coming along very well!
    Brake lines looking good from what I see. Got any detail pics of them?
    Hotrod31A and 31chevymike like this.
  16. Hotrod31A
    Hotrod31A
    Vic Walter, akoutlaw, 2Blue2 and 3 others like this.
  17. I'm in the same scenario myself - although I have seen others run the brake lines across the rear. But with the movement of the rear, it seems running the brake lines across the shock mount above would be much better and solid. Besides, running brake lines in and around the ladder bar mounts could be a bit tricky... Like Brent, I appreciate your detailed photos as well - thanks alot!
  18. X38
    X38
    Just an observation: I hope the gussets on the rear spring hangers don't interfere with the frame rail c-notch at full travel. I've seen that happen when the gusset is welded right at the top of the diff tube.
    They look like JW rails.
  19. Hotrod31A
    Hotrod31A
    Maybe a bit of an optical illusion, should have plenty of room for travel.
  20. X38
    X38
    Okay, if you're happy, I'm happy. I only mentioned it just in case.:)
    Outback, brEad and Hotrod31A like this.
  21. Hotrod31A
    Hotrod31A
    Thanks for the heads up will keep an eye on this during shake down runs.
  22. Hotrod31A
    Hotrod31A
    First progress on the body in many months, p***enger door jamb repaired and fitted with new hinges. Feels good to back at it even though it will be short lived due to the upcoming move to the new garage. Still hinge work left but on the right path.
  23. Hotrod31A
    Hotrod31A
    First fit of the body to frame, good enough to bolt down for the move. Gives me some energy to get moved and finish this thing! IMG_0344.jpeg IMG_0349.jpeg IMG_0351.jpeg IMG_0350.jpeg
    Outback, Vic Walter, brEad and 8 others like this.
  24. Bandit Billy
    Bandit Billy
    That's got the look!
  25. Hotrod31A
    Hotrod31A
    Thanks Man!!
  26. Hotrod31A likes this.
  27. Hotrod31A
    Hotrod31A
    Thanks !! It’s not an original idea I know but a time honored recipe for a reason
    31chevymike likes this.
  28. metalhead140
    metalhead140
    Looking good! Great metal work. I dread doing the same on mine when I eventually want some nice paint... It's pretty rough.
  29. Hotrod31A
    Hotrod31A
    Thanks, I like the sheetmetal work but dread the tedious bondo work. Still undecided about paint but leaning towards the vintage looking flat luster style paint.
    brEad and 31chevymike like this.
  30. Hotrod31A
    Hotrod31A
    Another big step today, finally had the ole girl media blasted and primed.
    Holy moly!!! She has quite a story to share, once shotgunned, swiss cheesed by rust and a slew of half ***ed repairs over her life. Many hours of panel beating and welding in our future together.
    IMG_0367.jpeg IMG_0369.jpeg IMG_0370.jpeg IMG_0371.jpeg IMG_0372.jpeg IMG_0373.jpeg IMG_0376.jpeg IMG_0379.jpeg IMG_0380.jpeg
