Technical 34 ford pu twisted rear shackles
Discussion in 'Traditional Hot Rods' started by tarheelrodr, Nov 8, 2022.
  1. tarheelrodr
    tarheelrodr
    Need some advice of what to check on why my rear shackles became twisted. This is a ground up build with original frame and rear x member, newly rebuild 34 banjo rear end, a used Posies 32-34 compound curve rear spring, and Speedway shackles with the black nylon bushings. I installed the drive shaft and torque tube on the rear, bolted on the main leaf and proceeded to build the spring pack using a threaded rod and clamps so I could install spring center bolt. All went well until I slide the entire ***embly into place under the ch***is. I don’t have a motor/trans installed yet so just made sure front end of torque tube was on top of the frame “u” where it will bolt to trans. As I began to jack the rear end up to seat the spring into the rear crossmember, making sure to align the spring pack bolt head into center hole of the crossmember I noticed that it wasn’t lined up right. It seemed to be leaning back so I used some ratchet straps around the spring and axle tube, one on each side, to pull the spring top forward. Installed the spring ubolts snug for mock-up and put jack stands under the axle tubes. At this point I noticed the spring shackles are twisted and the spring eyelet and axle tube spring eyelets aren’t parallel to one another. See picture. What did I do wrong? Or what is wrong? Can I drive it like this? Are the main spring eyelets bent?
  2. FritzJr
    FritzJr
    Have the mounts on the axle housings been modified to match a straight spring? The shackle bolts in the axel housing do not appear to be parallel to the eye of the spring.
    wheeldog57 and jaracer like this.
  3. tarheelrodr
    tarheelrodr
    I don’t know since I am using a different 34 axle housings and center section than my original. I do still have the original housing as well as a third set. I will compare the axle housing mounts on all of them.
  4. hemihotrod66
    hemihotrod66
    The axle mounts look like they have been modified.... Looks like they have been welded.... Hard to tell from the picture.....
  5. Pete Eastwood
    Pete Eastwood
    from california
    That spring doesn't look right.
    I'd like to see it along side an original 1932 / 34 spring.
  6. alchemy
    alchemy
    A 33-34 with a four cylinder had a different length torquetube. I think it was longer, but I may be backwards. If you mistakenly used a 4 cylinder rearend and then forced the axle/spring into the crossmember, it might be jammed in their crooked. Compare the length of your torquetubes.
    ClarkH likes this.
  7. woodiewagon46
    woodiewagon46
    from New York
    Is that a crack on the top of the axle side of the shackle mount?
  8. rusty valley
    rusty valley
    I have had to heat and bend the arms to be parallel on a couple rear ends. The spring is curved, but the arms, or shackle mount point is still supposed to be square with the world, or parallel to each other
    dirt t likes this.
  9. 1935ply
    1935ply
    from peyton,co
    The 32-34 spring should curve into mounts. Your mounts are curved, but the spring looks straight.
    Andy, RICH B, Pete Eastwood and 2 others like this.
  10. chrisp
    chrisp
    As Hemihotrod66 said: It looks like the mount was welded and the weld ground almost smooth, it doesn't mean it's not in the correct location if it was welded. Especialy if you don't have the curved rear spring but we can't see because the pictures are too taken close.
    Tow Truck Tom likes this.
  11. Fordors
    Fordors
    Using a four foot long straight edge I checked the spring eyes on a Posie’s ‘32 rear spring I have, they are 5* off perpendicular using a machinist’s protractor.
  12. gimpyshotrods
    gimpyshotrods
    Draw a line through the dots:
    Unless this is camera distortion, your spring mount is bent.
    Based on the position of the side plates on this shackle, I would say that it is.
    The bore of this mount absolutely must be parallel with the flange on the axle for the brakes.
    It appears that it is perpendicular to the axle tube, which is tapered, not straight.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Better to view the whole scene
    What he says.
  14. alchemy
    alchemy
    Nope. 32-34 has a curved spring, so that’s not the case.
  15. tarheelrodr
    tarheelrodr
    I still have the original spring that I can compare to the Posies spring. Both springs are compound curved the same. I only have one torque tube, the original one, that is being used. I will post pictures too.
    by the way, I failed to mention in first post that both left and right shackles are twisted not just the one side shown in the picture.
    All these questions have now made me realize that when I was playing around with the mock up of the pu for ride height using the original rear, torque tube and the original spring pack, sans about half of the original springs, I had the exact same problem…I just thought because the shackle bushings were completely gone it was giving me trouble going back in the crossmember.
    Happydaze likes this.
  16. general gow
    general gow
    MODERATOR
    If you had the same problem with OG stuff, I would first suspect the spring mounts on the rearend being bent out of shape. A friend, a torch, and some patience will make pretty quick work of it though.
    badshifter likes this.
  17. tarheelrodr
    tarheelrodr
    so that would mean spring mounts on both pairs of axle housing are bent out of shape..!!
    I just compared my OG axle housings spring mounts to one’s I have installed and they appear to be the same angle in regards to center line of the axle housing.
    Next will compare spring packs.
  18. Happydaze
    Happydaze
    Putting the curved spring in the wrong way around could explain this?
    Chris
    bob b. and jaracer like this.
  19. patsurf
    patsurf
    best answer so far
    choffman41 likes this.
  20. tarheelrodr
    tarheelrodr
    I suppose but it will not fit another way. The crossmember and spring are curved the same.
    bchctybob likes this.
  21. alchemy
    alchemy
    My 32 sedan with an original rear and spring has a little bit of misalignment on the shackles too. I don't think I have anything bent, it's just the nature of that curved spring.
    The OPs hangars have had the small knobs removed from the top that the shock links attached to. That is the smoothed ground spot that was questioned above.
    Carter likes this.
  22. tarheelrodr
    tarheelrodr
    yes, the shock knobs have been removed from the tops of the mounts by me. I am going to use aftermarket shocks.
    so I guess the definitive answer is I need to heat and bend the axle spring mounts to match the spring eyelets? If so, That really ****s because everything is powder coated..!
    I ***ume if I just run it as is I am risking damage or breakage of those shackles and maybe more.
  23. Happydaze
    Happydaze
    OK. What if the main leaf was the wrong way around?
    It would be useful to see the angles of the spring ends with the spring dis***embled. There's always the possibility that the orientation of the eyes has been formed incorrectly relative to the curve of the spring (or vice versa), in which case it becomes Posies problem , I guess.
    Chris ​
  24. tarheelrodr
    tarheelrodr
    With all due respect, I don’t see how the main leaf could be put in the wrong way. All leafs are curved the same. No way it could be put back together backwards.
    it is possible that the main leaf eyes are out of whack since this is a second hand unit. I didn’t buy it new from Posies. I’ll post pictures of old and new spring side by side sometime today.
    jimgoetz and '28phonebooth like this.
  25. Pete Eastwood
    Pete Eastwood
    from california
    So wrong! 1932 / 1934 spring hangers are set at an angle (about 6 degrees) to accommodate the
    curved spring.
    seabeecmc, hotrodfil, Carter and 2 others like this.
  26. Pete Eastwood
    Pete Eastwood
    from california
    nope! not on 1932 / 34
    seabeecmc, Carter and jimgoetz like this.
  27. Have to Tried to Load it with weight to get your shackles at the correct degree? It might work it self out to be acceptable when it's under load. Those '32-'34 curved rear springs can be a little goofy. I'm working on one now also.
  28. tarheelrodr
    tarheelrodr
    that’s the best idea yet but I am a ways off from placing the bed, fenders, fuel tank, etc on there to see how it settles. Guess I will wait and see.
  29. manyolcars
    manyolcars
    or stack blocks or bags for weight
    tarheelrodr likes this.
  30. ClayMart
    ClayMart
    I truly have no idea of how the rear suspension is laid out in one of these cars. But is there any possibility that the rear crossmember could have been installed in the wrong orientation for the spring curvature?
