Technical freeze plug replacement on a gen 1 392 hemi. what's the trick?
Discussion in 'The Hokey Ass Message Board' started by Harley Charley, Nov 10, 2022.
  1. tubman
    tubman
    To put a cap on this, I have occasion to use some oddball sizes. I have found the best source for these to be an outfit called "The Freeze Plug Factory".:eek: I believe they are in San Diego and manufacture and distribute all varieties.:) I have found them to be an excellent source.
  2. Atwater Mike
    Atwater Mike
    That's what I used on my '58 392...Pounded 'em in with my old Xerox machine...with Injun head permatex.
    Wanderlust, VANDENPLAS, egads and 5 others like this.
  3. ClayMart
    ClayMart
    At some point in time I got it stuck in my giant :rolleyes: brain that these shallow core plugs were known as "welch" plugs. Or does that term also apply to the more commonly seen "cup" plugs as well? o_O
    VANDENPLAS, egads and Fordors like this.
  4. gimpyshotrods
    gimpyshotrods
    Even more obscure, I have seen them described as 'Welsh" plugs.
    I have been to Wales. I did not see anything present that would approximately be such a thing.o_O
    They don't fit any known definition of either word.
  5. Fordors
    Fordors
    I agree with welch plug, and no capital w.
    Edit: Hmmm, I stand corrected.
    4AC2991E-A903-4055-8D28-2A25F3830C5D.jpeg 7AAD2DE2-C3B1-4752-A377-D3590A4C79B9.jpeg
    73RR, Algoma56, egads and 2 others like this.
  6. Beanscoot
    Beanscoot
    Something's wrong (with preparation, technique or plug itself) if replacement "welch" plugs come out by themselves. It's a very reliable design.
    I use Permatex 2 on them.
    VANDENPLAS, 73RR, egads and 2 others like this.
  7. TRENDZ
    TRENDZ
    egads and Desoto291Hemi like this.
  8. Budget36
    Budget36
    I had a leaking plug in my car, the mechanic at work told me to go get the rubber one with a washer on both sides. Issue was no way to knock a new one in. So we get the rubber one in and he tells me “it’s a temporary fix. Going to have to pull the engine eventually “. Well, being young, I sorta forgot about it. Sold the car maybe 15 years later and many miles, still had ge squished rubber plug in it.
    Desoto291Hemi likes this.
  9. gimpyshotrods
    gimpyshotrods
    With a capital W, the name makes perfect sense.
    Without, nonsense.
    This ties into my point about using the correct names for things.
  10. Beanscoot
    Beanscoot
    Confucius supposedly said, "Wisdom begins with calling things by their right names".
    Of course the ****ects, attributed to him, were written long after he went the the great junkyard in the sky.
  11. patsurf
    patsurf
    well if that doesn't prove it -nothing will....prove what?
  12. Beanscoot
    Beanscoot
    I don''t remember.
  13. Jagmech
    Jagmech
    Napa has the permatex sealer. Welch plugs fit blocks with a step in the hole. If step is removed, use conventional core plug, install with a socket that fits inside the cup wall of the plug, and drive it in, just hitting in the middle with hammer distorts plug and it will fail. Same method for welch plug. No magic bs involved.
    egads likes this.
  14. Jagmech
    Jagmech
    By the way, for circle track, we used Dev- Con epoxy and 3 screws ( 10-24) around the perimeter, both types of plugs.
    egads likes this.
  15. Budget36
    Budget36
    I thought, and probably shouldn’t think, Welsh refers to people, welch refers to the plug. ****, now I gotta go Google it.
    Wanderlust and gimpyshotrods like this.
  16. gimpyshotrods
    gimpyshotrods
    Welch, with a capital W refers to the plugs.
    Without the capitalization, it means to avoid payment.
    Just like it is not dzus fasteners. It is Dzus fasteners.
    Proper names, and proper nouns are always capitalized
  17. Budget36
    Budget36
    See, I thought it was Welsh-people with the “s”. And a “c” for the plug. Oh well, I’m going just ask for “those round things that go in the block” next time;)
    AmishMike and Desoto291Hemi like this.
  18. 57 Fargo
    57 Fargo
    Core plug works no matter the style.:D:D
  19. andyh1956
    andyh1956
    So, is it an "Engine", or a "Motor"?o_O
    Desoto291Hemi and egads like this.
  20. The37Kid
    The37Kid
    Use Kleenex to remove the excess from your fingers?
    VANDENPLAS likes this.
  21. 73RR
    73RR
    Back in time, just after someone invented fire, in an electrical engineering cl*** the prof said that motors are electrical devices.
    A starter motor is common to our use. A starter engine is common to older large diesels; also called pony engines.
  22. DDDenny
    Had to really laugh the first time I saw someone write Zeus ****on!
    gimpyshotrods and The37Kid like this.
  23. Welch plug
    Casting plug
    Freeze plug
    Blanking plug
    Core plug
    they are all “ correct” as you can go into pretty much any parts house and ask for one or the other and end up with the correct plug you require .
    I’m sure one or two are more “ corrector “:D but , well ….. whatever .
    When I started at Jaguar I went to the parts dept and asked for a compression fitting .
    I got a lot of raised eyebrows and “huh’s??”
    when the parts guys figured out what I was looking for found out they ( compression fittings ) are called ferrules and olives .
    Ok , sure ……. I need 2 of those !
  24. Budget36
    Budget36
    Not at Autozone. Lol
  25. gimpyshotrods
    gimpyshotrods
    Year, make, model, engine, transmission, please, sir.
  26. gimpyshotrods
    gimpyshotrods
    I've seen that!
  27. jimmy six
    jimmy six
    No matter you call it the front and rear of GMC’s have them but not the sides. Many are used at the rear for a cam oil seal to the block. Another place to use Permatex #2 (aviation form a gasket) for me.
  28. That's what an engine builder friend does and what my Studebaker is getting done when the time comes.
  29. gimpyshotrods
    gimpyshotrods
    That's best practice. Of something either does not work, or is risky, just replace it with something that does.
    Paul likes this.
  30. twenty8
    twenty8
    Just like the Welch brothers did back in about 1910........:rolleyes:
