Projects 1940 Ford Convertible now with 303 Olds(updated 11-12-2022)
Discussion in 'The Hokey Ass Message Board' started by 40FORDPU, Jun 26, 2018.
  1. 40FORDPU
    40FORDPU
  2. 40FORDPU
    40FORDPU
    Out with the old
    bchctybob, Tim, 40ragtopdown and 2 others like this.
  3. 40FORDPU
    40FORDPU
  4. 40FORDPU
    40FORDPU
    The "new" awaits
    1950 Olds 303
    bchctybob, SS327, Tim and 5 others like this.
  5. 40FORDPU
    40FORDPU
    This is just prior to me removing the flywheel to have surfaced, I got a little over rambunctious and it took a nose dive..Damn if it didn't break the crank pulley.
    Aware that @Paul is into these Olds engines, and he's fairly close by, I pm'd him, to see if he might have one.
    He ended up making me a sweet deal on a core engine (Thanks again Paul), so I was back in business.
    bchctybob, Just Gary, Tim and 5 others like this.
  6. 40FORDPU
    40FORDPU
    I opted for the Wilcap adaptor plate, mounting the Ford 3 speed to the Olds.
    The pilot bushings OD was a bit oversize, so I turned it down to the proper diameter (no lathe, I used a file with the bushing rotating in the drill press).
  7. 40FORDPU
    40FORDPU
    I had the original Olds 3 spd trans. but elected to use the Ford 3 spd as this car shifted so smooth, and didn't want to fix something that wasn't broken.
    I used the Olds stock 11" pressure plate, with an 11" Ford truck disc.
  8. F-head
    F-head
    Wow love it
    40FORDPU likes this.
  9. 40FORDPU
    40FORDPU
    There's a slight interference at the cowl, the top of the transmission tunnel requires it to be trimmed to install the Olds.
    Also the forward shift linkage arm (stock '4o Ford 3 spd column) interferes with the block, I could have bent the rod to clear, but elected to just cut/grind a small bit of the block for it to clear.
    bchctybob, warbird1, SS327 and 4 others like this.
  10. 40FORDPU
    40FORDPU
    Engine /trans now installed in the car.
    Nice fit, using the Hurst mounts.
    I used the Ross starter, no clearance issues.
    I still have exhaust to fabricate, carb linkage, mount the radiator, etc.
    After I get a few miles on this, I'll probably search out a triple deuce intake and carbs, not that I intend it to be a power house, I just like the look.
  11. 40FORDPU
    40FORDPU
  12. MMM1693
    MMM1693
    Nice job!
  13. Bandit Billy
    Bandit Billy
    My drill press gets "creatively" used as well. That Olds fits in there nice!
    Tim and 40FORDPU like this.
  14. You even have the cool long can Olds air cleaner!
    Just Gary, Tim and 40FORDPU like this.
  15. 40FORDPU
    40FORDPU
    According to the previous owner the engine came out of a restored car, that the owner wanted to switch out to an LS..yeah, I know.
    bchctybob and guthriesmith like this.
  17. 40ragtopdown
    40ragtopdown
    Looking good.
  18. Tim
    Tim
    from KCMO
    Rad!
  19. guthriesmith
    guthriesmith
    Best way to get good deals on engines these days. I recently bought a complete good running y-block because the owner was swapping to a late model engine in his 57 Ford wagon.
  20. belair
    belair
    More cool than the law allows.
  21. stanlow69
    stanlow69
    So says the guy who picked up A Flathead the other day. Some guy was putting an Olds motor in his Ford.
  22. 40FORDPU
    40FORDPU
    Yeah, I get it, the restorers will always wonder "why he couldn't leave it well enough alone".
    Bottom line, as car people we do what suits us (as it should be)..be it the traditionally inspired build, or the current Street Rodder build.
    We all will agree that we don't agree.
    guthriesmith likes this.
  23. X38
    X38
    It could bring your front down. Those first gen overheads are heavy mfs.
    bchctybob and 40FORDPU like this.
  24. stanlow69
    stanlow69
    But the Flathead will end up in a Model A. It seems like everybody wants a little more horsepower. As it should be.
  25. 40FORDPU
    40FORDPU
    Agreed, I considered that, as near as I can tell the Flatheads come in around 530lbs-570lbs with cast iron heads, the Olds around 710lbs, so a difference of approx. 140lbs to 180lbs.
    I've had it on the ground, it is about 1/2" lower, but that is without Hood, radiator, coolant, etc., so it'll be interesting..adjustments may need to be made.
    bchctybob and X38 like this.
  26. 62pan
    62pan
    What for fuel pump are you using? Looks like it just fits.
  27. v8flat44
    v8flat44
    Reminds me of an old pal of mine's 40 Ford p u with a J-2 in it....frightning !!!! But so fast & cool.
  28. 40FORDPU
    40FORDPU
    It's ***e, I got the information from the Olds engine thread
    I used the AC #41209 '78+ Buick Skylarks
    Carter equivalent #M6951
    Airtex equivalent #41209 same as AC
    bchctybob likes this.
  29. 62pan
    62pan
    Thanks, I have plans to replace the flathead in my 39 pickup with a 303 olds. Nice to see a stock fuel pump will work with out going electric.
  30. Crusty Chevy
    Crusty Chevy
    Thanks for the link to this. Car looks great in maroon and I bet it will scoot along with the extra 50+hp.
