Technical ***November 2022 Banger Meet Thread -Hoping for Some Rain ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 1, 2022.
  1.
  2. Crazydaddyo
    Crazydaddyo
  3. The37Kid
    The37Kid
    Has anyone had problems removing a Model A Head? Saw a neat trick on a TV show a few nights ago. Remove all four spark plugs, cut two lengths of rope about two foot long then stuff one in #1 & #4 cylinder while at BDC. Crank the engine over and the head just popped up, thought it was a neat quick way of doing things, no danger of chipping a head or block.
    Bob
    Jet96, Old Dawg and Outback like this.
  4. That's one way. They also make a head puller
    https://modelastore.com/index.php?route=product/product&product_id=3503
    Old Dawg and The37Kid like this.
  5. trikejunkie
    trikejunkie
    from Scotland
    I`m still here, had a huge disappointment with my "B" rebuilt engine but I will surp*** that issue.On the flip side my "B" engine into an "A" is complete and the clutch system /brake system works well - been working on my car transporter as it`s going to be my daily as well as my A coupe transport for pendine and my current car is sold pending collection!
    winduptoy and The37Kid like this.
  6. Bob, you were watching "Roadworthy Rescues" now, weren't ya??? :D
    That WAS a neat trick- probably work for any flathead
    The37Kid likes this.
  7. The37Kid
    The37Kid
    Yes, Worth watching for the one liners. Sparkplug inspection turned up one plug running Richer than Oprah.
    winduptoy, BeaverMatt and Jet96 like this.
  8. Cool hand made deep sump for the speedster.
    rwrj, Lil'Alb, Old Dawg and 2 others like this.
  9. The37Kid
    The37Kid
    Nice to know everything doesn't have to be buffed aluminum with fins and then chrome plated.
    Bob
    rwrj, Outback, Lil'Alb and 2 others like this.
  10. walls
    walls
    I have loosened the nuts on the head about an 1/8” and cranked the engine over without the rope.
    Same effect.
    Guess the compression helps it to pop.
    After that, I slide a couple ratchet strap through and connect them to an engine hoist.
    Comes off fairly easy.
    Or yeah, they also make a head puller.
  11. walls
    walls
    I know it’s not the banger that’s usually discussed on this thread, but I got lucky on and found a Chevy II engine locally for almost nothing. I plan on putting it in my stock-ish model A with a 39 trans for a quick doubling of the horsepower.
    The T body and bed came with it.
    ‘I’ll use the A motor with the T body and make a little hopup.
    Now I just need to find a decent ch***is.
    A1448C03-17B2-488F-AFE4-C418283C3592.jpeg 24C4B205-C430-45B7-88F0-9BEB41ECA54E.jpeg
  12. The37Kid
    The37Kid
    ^^^^^^^^^^^^^^^^^ Looks like a Victoria in the corner.
  13. Bob, that is exactly the idea. Not a lot of aluminum, except the warford and maybe the intake. But more br***, cast iron and steel.
    Outback and Old Dawg like this.
  14. 4bangerbob
    4bangerbob
    from AB, Canada
    314661682_10160838739317033_4744716233149322969_n.jpg 314717482_10160838739162033_7645079214768950155_n.jpg 314754702_10160838739772033_8215853899621365408_n.jpg 314937325_10160838739222033_2521564789864594869_n.jpg 315005359_10160838739342033_6883502288325474462_n.jpg 315535614_833569344456189_2873585051572395013_n.jpg Some interesting photos from facebook group FourBanger's Ball I suspect the B block had an unrepairable crack on the deck...
    Chucky, Outback, Jet96 and 6 others like this.
  15. 4bangerbob
    4bangerbob
    from AB, Canada
  16. noboD
    noboD
    You better 'splain more here. Not all of us are on Fakebook.
    The37Kid and Fabber McGee like this.
  17. Truckster17
    Truckster17
    Hello,
    I’ve been lurking here for years, collecting knowledge and parts. If you guys don’t mind, I have some questions that seem most appropriate for here rather than Fordbarn or Facebook.
    Are the numbers on a Cragar head the date code?
    Was there a Cragar B side plate with a hole for the fuel pump?
    Was there a Cragar aluminum timing cover?
    If my B block checks out, should I run a **** crank or what do you guys prefer?
    Will a B motor and V8 trans with Cling adapter(s) bolt directly into an A ch***is, specifically will the torque tube need modified?
    Am I using this forum correctly? This is more complex than Facebook, and the content is higher quality.
    Thank you Monthly Banger Thread!
    Scott,
    Rural Chicago
    Lil'Alb, Outback and Jet96 like this.
  18. raaf
    raaf
    @Truckster17
    Scott,
    You're using the forum correctly and by the looks of your project you have definitely come to the right place. I cannot answer your questions, but I am positive that other members, far more experienced than I, will be able to answer your questions over time.
    Welcome!
    Raaf
    Outback and Lil'Alb like this.
  19. drtrcrV-8
    drtrcrV-8
    4bangerbob : Well, You just blew the top off the page!!!! PLEASE load all the detailed information about this project on this thread!!!! VERY INTERESTING!!! Question for the rest of the 'banger crowd: as long as we keep the crankcase, crank (& possibly cam) does this count as an "overhead conversion", both here & for X-cl*** racing??
    Outback likes this.
  20. The37Kid
    The37Kid
    Some people would have cleaned the bottom half of the B block you cut the top off of, but there are guys that weld rusty sheet metal too. Your shop to do with as you please.
  21. 4bangerbob
    4bangerbob
    from AB, Canada
    Below are all the comments related to this original post.
    • [​IMG]
  22. 32B5C1E6-195D-4A8A-9B5E-A8B701EF5C0F.jpeg I meant to post earlier. Went to help Craig at RKE Engineering skim his block… It was an old BF engine with good white metal. He’d been donated some aircraft cylinder heads. Plan is to make a deck plate and new cylinders. Trimmed the block down leaving the cam tunnel and lifters in place. Going in a little single seater. He’s making barrels next.
    Outback, Jet96 and Old Dawg like this.
  23. The original aero engine is a 2.2 litre flat four. Similar bore size and a 3” stroke. Craig is planning to make nikasil coated aluminium barrels. Around about 4” to use a smallblock piston.
    3589A527-7354-4A0C-8F02-A156B9EC0127.jpeg 1CA7A293-3B3E-45C9-9B11-E9B42CD46987.jpeg
    Leftovers.
  24. drtrcrV-8
    drtrcrV-8
    4bangerbob & hotrodfil : Could you PLEASE TRANSLATE OUT OF "FAKEBOOK"!! This conversion looks interesting, but it might as well be printed in N. Korean or Farsai if we are not "indentured" to "FAKEBOOK"!! HINT: A LOT OF US REALLY DO NOT LIKE "FAKEBOOK"!! I do hope I was clear enough??
    Outback and fur biscuit like this.
  25. 4bangerbob
    4bangerbob
    from AB, Canada
    پیشنهاد می‌کنم اگر از فیس‌بوک خوشتان نمی‌آید، پست را رد کنید
    페이스북이 마음에 들지 않으면 그냥 스킵하는 것을 추천합니다.
    Dedsoto, Outback, Jet96 and 2 others like this.
  26. I don't do the Book of Face myself.
    I'll keep you posted with progress.
  27. Fabber McGee
    Fabber McGee
    That would be great, thank you.
  28. The deck was fine although we found a crack in the water jacket whilst is was coming apart. Took a good few cuts to get through the deck 3mm at a time...
    It's a BF block. Small bore - you can see the rod clearance slots in my first picture. So pretty much useless for anything. The valves are angled closer to the bores like the flathead V8. But it came with a counterbalanced crank and good white metal.
  29. Does anyone have knowledge on this distributor drive stand on this KONG cover?
    I think I took the photo from one of the SoSS magazines, but cant find which one.
    I've got a blank, and am looking to make some sort of drive gear for it off the camshaft. 288503714_582161710094860_4513811346712342088_n.png
  30. 40 Olds
    40 Olds
    Going through a friend’s old photo album this past weekend and saw these. He thought it was at Pate 1989. I know it’s a rare piece but I didn’t think the asking price would be that high at that time. Wonder where it is now? Speedway maybe?
    Outback, BeaverMatt, Jet96 and 2 others like this.
