Technical chop top cutting windshield to size
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Nov 14, 2022.
  1. fastcar1953
    fastcar1953
    O.k. so top is chopped. I know how to cut gl***. How do I measure it?
    I measured old opening and then new opening. Cut a template to size. The template seems to tight in the new weather strip.
    I am worried about cracking windshield due to stress while driving down the highway.
    I can cut it to fit just don't want it to be to tight.
  2. goldmountain
    goldmountain
    Use the windshield as a mold and make a fibergl*** one to practice getting the size and shape right.
  3. gimpyshotrods
    gimpyshotrods
    ***uming that you are just lopping off the top, take another 1/8" off, and put a thin bead of windshield cement on the new top edge.
    That will prevent pressure, and the cement will keep it from moving.
  4. fastcar1953
    fastcar1953
    Just cutting top of gl***. 1/4 inch more seems to work better
    dana barlow likes this.
  5. rusty valley
    rusty valley
  6. Mr48chev
    I'm not sure how the real gl*** guys do it but If I had the original gl*** I'd lay it on something stiff enough to make a pattern out of, trace it out, cut it out and then cut it in two straight across and overlap the pieces in the opening to get my gl*** size. I figure to do that on the windshields and side gl*** on my 48 and then cut out 1/4 inch masonite to the size and do the fitting with it before loading the truck up and hauling it to the gl*** shop. I'm just not hard core or cheap enough to want to install my gl*** myself again.
    bschwoeble likes this.
  7. fullhouse296
    fullhouse296
    from Australia
    Try masking with silicone and rubber tyre strips then sand blast at 45 angle . keep pressure as low as possible and just keep at it . worked for me on 59 Rambleher
  8. It's like a torque spec, or boring a block, creep up on the final size with the belt sander. You've gotta sand the edges anyway to rid it of stress risers.
    VANDENPLAS, reagen, vtx1800 and 3 others like this.
  9. What car? Flat gl*** or curved? Flat is easy. If it is curved and you are just now trying to fit it to the opening you are already b*** ackwards. Fit should have been considered first before cutting metal.
  10. fastcar1953
    fastcar1953
    My car is a 54 chevy. Curved gl***.
    I brought this up because others have asked about windshield installs. Weather stripping etc.
    Just wanted to help some out on chopped top windshield installs.
    I had a friends crack after about 2 months of driving.
    I don't want that to happen to me or anyone else.
  11. Yeah Jerry, if it's under stress anywhere in the gasket, you can bet that it will crack! Gl*** doesn't bend very well lol. But after you cut it to your desired size, if it needs some adjustment, 80 grit aluminum oxide sanding belt and a spray bottle of water will move a lot of gl***. Buy you a whole pack of belts lol. And you can finish the edge with 120 or 150 seeing how it's not exposed, like the top of a door gl***. I have a $75 craftsman belt sander, and it works just fine.
  12. fastcar1953
    fastcar1953
    Thanks Lloyd. I will be trying it again next spring.
    I have to finish the wife's Nova first.
    I'm going to order a new windshield soon. I hope to get back to working on it soon.
    Work is really busy right now so not much time for cars.
  13. flamedabone
    flamedabone
    And, don't forget your safety gear. Sanding gl*** is dicey in a handful of different ways.
    -Abone.
  14. wetskier2000
    wetskier2000
    from NH
    I would like to reshape a curved rear back gl*** from essentially a rectangle to an isosceles trapazoid like this: The curved sides would remain but the top total gl*** width would be closer than it is right now. The lower total gl*** width would remain the same. Make any sense?
    I picture 4 cuts which would remove 2 pie shaped pieces. Is this even possible with tempered 1959 gl***? If so, what kind of shop should I be looking for? (please excuse my complete lack of knowledge on gl***). thanks
  15. alchemy
    alchemy
    If it is tempered, it can't be cut til its untempered. Otherwise it will just shatter. Untempering is even harder than tempering, I've read.
    twenty8 likes this.
  16. wetskier2000
    wetskier2000
    from NH
    thanks... anyone had a custom curved gl*** made?
  17. BJR
    BJR
    Unless you are chopping a car with flat gl***, you should cut the gl*** first, and fit the metal to the gl***. Unfortunately that won't work now. Through the years I have seen lots of chopped cars sold without gl*** for cheap prices cuz no one could make the gl*** fit the opening.
    twenty8, Tman, bschwoeble and 2 others like this.
  18. wetskier2000
    wetskier2000
    from NH
    I think this is a wise idea... I just mocked up the back window with a 6" chop and I really like the look. (and putting it back together is within my neophyte skill set)... I think the process will be get the opening where I like it. Maybe a form that I can flip side-to-side so I know they are the same, then create a full size template. Not sure how I might do this... cardboard then fibergl***? Look for a custom gl*** place like this one https://www.procurvegl***.com/ or just use lexan... any thoughts?
    here's the victim...
  19. junkman8888
    junkman8888
    wetskier, a side picture would help, from the one you've posted the only option I can think of is 1970 Camaro back gl***
  20. rdscotty
    rdscotty
    from red deer
  21. tom brown
    tom brown
    off subject-I have a friend who works at making special gaskets-rare cars to space rockets. He has access to a hydo water cutter they can use after work. It will cut thru the gl***- steel- rubber all at once- not taken apart-perfect cut. good for reducing roadster wind shields and curved gl***. ask in your area- they are around. Not recommended to purchase- several hundred grand !
  22. RICH B
    RICH B
    Could always see if you can find a windshield with similar contours to cut.
  23. wetskier2000
    wetskier2000
    from NH
    I had seen the references to sinking the gl*** into the trunk but I also leaned the c pillars in at the top so that method won't work for me. On donors, the closest I could find would give pretty large sail panels with smaller gl***. It would really change the looks... I did, however, have some very nice junkyard tours of older iron while looking.
    Does that water hydro cutter work on tempered gl*** without shattering it?
  24. alchemy
    alchemy
    No. Once you remove a bit of tempered gl***, whether it’s a small chip or grain from the edge or the middle, it will shatter. I’ve seen it explained as if the piece of gl*** is a balloon, yet a very flat balloon. Once you take a nick out of the surface of the balloon the whole thing explodes.
    twenty8 and RICH B like this.
  25. wetskier2000
    wetskier2000
    from NH
    Coincidentally, I saw a motorhead show last night where they cut a new, curved windshield for a 1955 Ford pickup to fit a chop. The windshield was laminated and the process was relatively straightforward. It doesn't help me at all but it was cool to see. The rest of the truck's gl*** was all flat that they cut to size from new stock.
    It's amazing to me that the little gl*** cutter tool works at all. It seems to essentially just score the gl***. The pro doing the work said he had about a 90% success rate on curved gl***.
  26. bschwoeble
    bschwoeble
    I was told decades ago to do just that. Cut the gl*** first, and chop the top to the gl***.
    Kaleb42, twenty8 and Tman like this.
  27. ive always thought all cars from our era were safety gl***? every pane on my '57 ford is laminated.
  28. BJR
    BJR
    Most rear gl*** was tempered in the late 40's and 50's on up.
