Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. It occurs to me that you, @john mullen , are feeling the need, the need, for speed.
  2. john mullen
    john mullen
    It's what I am addicted to
    My worst and best love of the machine.
  3. john mullen
    john mullen
    A big shout out to Dave Redman for stopping by yesterday and helping sort out a cam timing problem.
    Got it all working today and it degreed in dead on the cam card numbers.
    Also want to thank Jimmy at Jimmy's Engine Service
    For his trusted wisdom.
    He had me check out the head that was on the blown up engine because he thought because the piston did hit the head he has seen where the head will distort. And guess what.
    It was, thank you Jimmy.
    See photo.. i had to mill the head .012 to straighten it out. 20221110_104646.jpg
  4. john mullen
    john mullen
    Accessories going on,
    Cam cover, balancer, crank trigger, upper valvetrain oil system, side cover and valve cover. 20221114_125901.jpg 20221114_142742.jpg 20221114_144503.jpg
  5. john mullen
    john mullen
    INVISIBLEKID, Jet96, D-Russ and 2 others like this.
  6. I'm ***uming that's because the cam would be 'backwards' with the chain drive.
  7. john mullen
    john mullen
    Yuup
    The Magic Ratchet likes this.
  8. john mullen
    john mullen
  9. Jethro
    Jethro
    Nice and tidy! Good work!
  10. john mullen
    john mullen
    Not much going on now that the engine I'd done but I will post again as it goes back in the truck and we fire it up.
    In the meantime we wish everyone happy Hollidays and please remember the reason for the season.
    May God bless us all
  11. 33 cdan man
    33 cdan man
    Do you not dyno your engines?
  12. The Magic Ratchet
    The Magic Ratchet
    Happy Holidays everyone!
  13. john mullen
    john mullen
    We will do a rear wheel dyno test once the engine gets done with the break in.
  14. john mullen
    john mullen
    A little something new for the future of the 640 project. I'll let Dave Russell fill in the details. IMG_8757.jpg IMG_8758.jpg IMG_8759.jpg IMG_8761.jpg IMG_8762.jpg IMG_8763.jpg IMG_8764.jpg
  15. john mullen
    john mullen
    We will be installing the fresh 262 for the runs at Arkansas and possable Bonneville 2023
  16. pprather
    pprather
    @D-Russ , so what's the story on the block, shield and trans case pictured in post #1754 above?
  17. D-Russ
    D-Russ
    Just another XO motor. It will be a little different from the 262.
  18. jimmy six
    jimmy six
    Dave under no cir***stances remove the crank gear oiler on the front plate no matter what gear set you use. Make sure the gasket you use has the cut slot. Also tap the holes in the front main for the cover. 3/8’s course will be fine even tho the threads are not 100%. I like header bolts for those 2 lower attaching cap screws with the 3/8” head.
    As a suggestion make sure your transmission is prepared to have the lowest amount of resistance as possible. An overdrive has never worked for me unless we were running on fuel and it was gear specific. We will be returning to Bonneville this year with our roadster as my grandson wants to drive it; first time since 2012.
    rod1, Jet96, TrailerTrashToo and 8 others like this.
  19. john mullen
    john mullen
    Wishing you luck jimmy six at Bonneville this year with your grandson..
  20. For those about to rock, we salute you.
    saltflats likes this.
  21. john mullen
    john mullen
    Yesterday the team installed the new Ford 270 Cu. In. Engine that we have been working on since we blew up our OG engine in 20230128_121653.jpg 20230128_104149.jpg Arkansas last year.
    It's been an expensive endeavor but it's coming together.
    This rag tag team is the best, love you guys
  22. jimmy six
    jimmy six
    Is the water pump a Meziere? If it is how much pressure is in the system? Thanks. The one I use is rated at 55 gpm.
  23. john mullen
    john mullen
    Yes and is 55 gpm
    chryslerfan55 and jimmy six like this.
  24. Jethro
    Jethro
    chryslerfan55 and D-Russ like this.
  25. AmishMike
    AmishMike
    ^^^. Ya what is that head? 6 even ports on this side, wonder what other side looks like? What cl*** does that put truck in & what the record there? Always fun & ton of work to run multiple cl***es
  26. D-Russ
    D-Russ
    That's a Tom Skinner 12 port cross flow head for a GMC 302 once owned and raced by Joe Fontana. Under the valve cover is a custom rocker ***embly from Don Furgeson. And I want to publicly thank JD Tone @jimmy six for all his advice and help on this new engine. It will put us in XO/MP and **O/MP. You can see the intake ports on the Skinner head in the middle photo below. Still looking for a factory 302 head if anyone has any leads. 302 small.png
    chryslerfan55, oj and saltflats like this.
  27. john mullen
    john mullen
    20230103_113054.jpg Cats outa da bag...
    Thanks Buffalo
    jimmy six, D-Russ and saltflats like this.
  28. jimmy six
    jimmy six
    Been using one for years and have an extra in my stash.
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Going to the dance with the redhead.
    Leaving with the blond.
    The Magic Ratchet and D-Russ like this.
