Technical ***November 2022 Banger Meet Thread -Hoping for Some Rain ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 1, 2022.
  1. The37Kid
    The37Kid
    Nice DO Fronty, note the adaptor for the Model A transmission.
    skip65 likes this.
  2. callcoy
    callcoy
    Fish Carburetor
    I have picked up a early Fish carburetor and am requesting information on this unit from anyone that can help me. I realize that many of you may have never heard of this carburetor, but I am sure a few of our more seasoned individuals are aware of it its existence. I have little printed data on it and am looking for more or leads to someone who may be familiar with this unit. Appreciate any help you may be able to supply!
    Steve
  3. Jet96
    Jet96
    from WY
    @callcoy -I've seen a thread or two on the hamb, it's been a while...
    winduptoy and callcoy like this.
  4. Outback
    Outback
    from NE Vic, Oz
    This is my current project at work, circa 1925.
    It's from a French Salmson Cyclecar. It is a gear driven dohc 1100cc (67CI) with bucket shims. 2 bearing crank. It is a beautiful little engine, but it is not very stable & very finicky to get right.
    Sorry about the dodgy photo's
    20221116_115612.jpg 20221116_115650.jpg 20221118_133156.jpg 20221118_133202.jpg 20221118_133210.jpg
  5. The37Kid
    The37Kid
    ^^^ Great project, I follow the Cyclecar thread, some really nice cars show up there. Bob
    fur biscuit and Outback like this.
  6. Steves46
    Steves46
    from Florida
    My 30 Coupe has been running really good over the past year until last weekend while driving on the way home. After flawless operation for 10 miles, no sooner than shifting 1st to 2nd gear after a stop sign, out of nowhere the Engine became louder like a tractor and had trouble going 25 to 30 mph. I also noticed whitish gray smoke coming from the tail pipes from acceleration. I am running a Snyders 5:5 high compression head, Ansen single down draft intake manifold with an English Stromberg 97, and tube headers with straight pipes to the back. The distributor is stock and is a 12V system. Fortunately this happened less than a mile from my house so I limped home. Upon removing the spark plugs, 1 & 2 cylinders looked good however 3 & 4 had oil on the electrodes. I have not taken a compression test but wondering what could have let go to cause the poor performance and smoke. Although I am running straight pipes, whatever this problem is, the exhaust sounds much louder. The oil looked good and not milky so I am ruling out blown head gasket. I am wondering if the piston rings gave out or possibly the one or 2 of the valves? Appreciate any other suggested areas to troubleshoot. The whole ordeal is odd for there was no warning or any indications of a problem.
  7. brokenspoke
    brokenspoke
    White smoke is a blown head gasket or corroded
    head
  8. Lättähattu
    Lättähattu
    from Finland
    Lil'Alb and Outback like this.
  9. Outback
    Outback
    from NE Vic, Oz
    You can blow a head gasket between cyls between 3&4 without touching the water jacket. I have done this & it sounded like I had done a big end....
    Steves46 likes this.
  10. Steves46
    Steves46
    from Florida
    Good to know. Will remove the head and see what’s going on.
  11. callcoy
    callcoy
    Jet96:
    Appreciate your lead, I don't know why "Steve Dummy" didn't think to to go to the HAMB first, I am not on the computer too often really never there. There is a wealth of Fish info on there from Canada, England, US and Germany, thanks again!
    Steve
    Jet96 likes this.
  12. Crazydaddyo
    Crazydaddyo
    Got the block painted. Slow progress.
  13. winduptoy, Old Dawg, ottoman and 4 others like this.
  14. raaf
    raaf
    @Crazydaddyo - Do you mind sharing how you got that so smooth? Just a lot of hours with the die grinder?
    Outback likes this.
  15. Crazydaddyo
    Crazydaddyo
    Yes, hours of cleaning cast iron out of my hair too.
    20220206_154529.jpg 20220206_154517.jpg 20220206_193002.jpg 20220313_173013.jpg 20220313_173029.jpg 20220313_173114.jpg 20220313_173136.jpg
    winduptoy, Jet96, tomkelly88 and 12 others like this.
  16. Stovebolt
    Stovebolt
    Stop it with the banger **** @Crazydaddyo
    We'll all go blind
    Jiminy and Crazydaddyo like this.
  17. denis4x4
    denis4x4
    from Colorado
  18. The37Kid
    The37Kid
    Outback likes this.
  19. raaf
    raaf
    Thanks @Crazydaddyo - thanks for confirming. Bonus points for sharing that beautiful block. Nice work. Looking forward to seeing what you're doing next.
    BeaverMatt and Crazydaddyo like this.
  20. Working on the other end of the coop
    Old Dawg, Jet96, Crazydaddyo and 2 others like this.
  21. Steves46
    Steves46
    from Florida
    Update. Got the Head off this evening and sure enough a small portion of the gasket blew between 3 & 4.
    winduptoy, Jet96 and Outback like this.
  22. Outback
    Outback
    from NE Vic, Oz
    Not a big fix. Good to hear you found the problem
  23. Outback
    Outback
    from NE Vic, Oz
    Here's another English banger from the early 20's, this one is a side valve & one that I'm hoping to build with some American hot rodding influence. I think that you will agree that the inclined valves
    porting/ relieved block is quite interesting along with a Ricardo designed head.
    G Baese, Jeff34, fur biscuit and 3 others like this.
  24. How does the cam act on the valves? Are there rocker arms or is the whole cam bank offset to accommodate the angle? Very cool!!
    Outback likes this.
  25. Outback
    Outback
    from NE Vic, Oz
    Yes the whole Cam/lifter Bank is angled in line with the valves. The block is separate to the crank case & has a full pressurised bottom end. It has 3 main bearings & is 140 CI
  26. Must be a design similar to that of Ernest Henri who brought forth the Ballot and the Peugeot engines in the early 1900's. These in turn were the basis of Harry Millers ideas that Leo Goossen put down on paper. All of which resulted in engines built by Offenhauser and Art Sparks.
    Outback likes this.
  27. Outback
    Outback
    from NE Vic, Oz
    I'm not sure of the History of this engine design. It is a Vauxhall the little brother to the big car's - 30/98's - this is their 'cooking model' but includes some nice features. By 1924 (ish) they gained 8 ports & a 4 spd.
    I don't know how much benefit the extra ports would be, would be interesting to flow bench test them.
    Jet96 and Old Dawg like this.
  28. If that's a Vauxhaul of that particular vintage, I'd guess and say Laurence Pomeroy.
    Attached is his write up from his presentation to the 1918 sitting of English Society of Automotive Engineers on cam design and spec'ing basis engine bore and valve sizing. Wonder how close he got to those numbers. Interesting book if you can find a copy. Not entirely certain, but maybe the first recorded use of I/E overlap in cam design.
    Outback, Jet96 and Old Dawg like this.
  29. V4F
    V4F
    from middle ca.
    **** ego
    Outback likes this.
  30. The37Kid
    The37Kid
    Whatever happened after this photo was posted? Just hope everything is ok. Bob
    Jiminy and Outback like this.
