Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. topher5150
    topher5150
    had another crazy dream....the roof of my portable garage got ripped off and a big branch fell on the hot rod and flattened it, but when I got up the car was still intact but crushed the top of the donor car.....I jumped out of bed and looked out the window and everything's good.
    alanp561 likes this.
  2. swade41
    swade41
    from Buffalo,NY
    Different kind of breathers came in today, I've always wanted a set of dual breather M/T for my blown big block, I've had one set of breathers and the valve covers for a couple yrs now but never wanted to coin up for another pair of breathers.
    Last week I took the plunge because I thought I was buying something else but it didn't materialize, so now I just have to strip the black paint and polish.
    20221121_142220.jpg 20221121_142309.jpg Screenshot_20221121-164736_Gallery.jpg
  3. lake_harley
    lake_harley
    A couple unexpected OT fabrication projects later.....I'm finally getting back to the dragster. I don't really know where I left off last post but I finally got the ch***is far enough along to get it off the frame table today. I have some final finish welding on the cage and misc. brackets that I couldn't reach with it up so high. I think it looks much further along on the jackstands than it did on the table. :)
    Lynn
    !cid_311b2b6c-4d64-4f4b-9a5f-a7c2df5fa7f2.jpg !cid_562a4cdc-500d-48e8-8f27-575afdc81861.jpg !cid_7175511f-924e-45cc-ac06-6a7286da6ccc.jpg !cid_fc1cf5ed-5fd1-4d2b-9c16-6178dfa5472d.jpg
  4. JD69
    JD69
    from Hockinson
  5. SDS
    SDS
    ***embled a front drum brake...Stared at the rest of the parts, still waiting on my painter to bring the ch***is back.
  6. TA DAD
    TA DAD
    from NC
    The truck is ready for the track ! I picked up 29 gallons of Cam 2 $319.99, one new SFI jacket $ 80.00 and a new Snell 2020 helmet $ 95.00 ( a ebay deal ) No wonder I gave this up years ago. I haven't had a car in the bleach box for 35 years but that is about to change ! IMG_0770.JPG IMG_0778.JPG
  7. JD69
    JD69
    from Hockinson
    Today after work I sat in the garage and thought of some things that will make driving more enjoyable. Foremost, brighter headlights came to mind.
    guthriesmith and dehartcarl like this.
  8. mad mikey
    mad mikey
    Go for it! Have fun.
    TA DAD likes this.
  9. mad mikey
    mad mikey
    Spent 2 afternoon's tuning the 2x4 set up on the coupe and 50$ of high test gas. Today was nice out so I took her out and romped on her. I am very close on the tune. Throttle response is fantastic, Just a little more tweaking yet. WIN_20221105_16_19_02_Pro.jpg WIN_20221105_16_20_24_Pro.jpg
  10. Started building the exhaust, tailpipes are out of the box flowmasters, working from back to front. 20221123_135726.jpg
    Bandit Billy, LAROKE, 2Blue2 and 8 others like this.
  11. vtwhead
    vtwhead
    Pulled the engine/****** out. Lots do get done now!
  12. TA DAD
    TA DAD
    from NC
    I am looking forward to it, and as you know that starting line separates the wheel hoping , coughing , hesitating POS from a real machine LOL I don't want to end up like Don Renfro !
    swade41, 26 T Ford RPU and mad mikey like this.
  13. j hansen
    j hansen
  14. TA DAD
    TA DAD
    from NC
    I know right, that has to be one of the greatest ever. The first time I saw it years ago I was wondering where did that guy standing there come from ? oh he was driving lol
    mad mikey, swade41 and j hansen like this.
  15. Put an OT water pump pulley on my 351W (I swapped out the standard driver's side pump for a '68 sbf p***enger's side pump to gain a little room in front). The pulley is a high-volume (smaller diameter) for a Ford FE, which puts the crank, alternator and water pump pulleys in alignment. I'd rather have a stock version but haven't found one yet.
    Also, installed the crossmembers and the fuel tank that I moved to the rear of the '29 AA. Just another two steps forward. Next up, carburetor and transmission rebuilds. The first I know I can handle. The second likely gets farmed out to someone competent.
  16. jimmy six
    jimmy six
    After a 3-4 month absence I took mine to Main Street Garden Grove this afternoon and evening. A little cooler now in So Cal about 60 cars.. gets dark before 5:00 now.
  17. mad mikey
    mad mikey
    going to work on a old dragster scoop I have to put on the 2x4 set up on the blower. Will post some pictures later. The scoop is fibergl*** and needs work.
    osage orange and j hansen like this.
  18. mad mikey
    mad mikey
    So, I cut the front off this old scoop because I did not like the mouthy look. This is just a mock up, still have shaping and t******* work . So far I am digging it. Looks kind of like Mike Smith's scoop he has on his bad blown Model A. Still in progress, will be body worked and painted the color of the coupe. WIN_20221126_15_23_47_Pro.jpg WIN_20221126_15_25_12_Pro.jpg WIN_20221126_15_25_55_Pro.jpg WIN_20221126_15_25_12_Pro.jpg WIN_20221126_15_23_47_Pro.jpg WIN_20221126_15_25_12_Pro.jpg WIN_20221126_15_25_55_Pro.jpg WIN_20221126_15_25_12_Pro.jpg
    Chavezk21, das858, swade41 and 10 others like this.
  19. warbird1
    warbird1
    Brookville, We've had a problem here...
    Trunklid's a mite too short to reach; this'll slow me down for awhile. roadster trunklid gap.JPG roadster trunklid gap2.JPG
    TA DAD, 2Blue2 and 26 T Ford RPU like this.
  20. j hansen
    j hansen
  21. The37Kid
    The37Kid
    That bottom panel that Henry made is 9 1/4 tall on my 1930 Roadster body. DSCF4901.JPG
    TA DAD likes this.
  22. Mike Miller
    Mike Miller
    Lopped off the front suspension in preparation for a straight axle. DSCF5588.JPG DSCF5589.JPG DSCF5590.JPG DSCF5591.JPG
    swade41, TA DAD, 2Blue2 and 3 others like this.
  23. warbird1
    warbird1
    The new bottom panel is the same size as the original one was... already checked that
    The37Kid likes this.
  24. ken bogren
    ken bogren
    Pushed the Falcon into its winter home, the corner of my unheated garage.
  25. topher5150
    topher5150
    I feel ya. Do you have any winter projects?
    mad mikey likes this.
  26. Almostdone
    Almostdone
    Dinking around with the fuel pressure regulator. Took a short drive for a warm-up prior to changing the oil before winter storage. It’s a 348 Chevy tri-power in a ‘31 Model A . Ran like ****, real rich, pushing 6 psi at the metering block. I backed out the screw on the regulator two more turns (worked great prior) and still 6 psi and flooded the Rochester 2G carbs. Changed the oil, fired it up again the next day, 3 psi…. perfect. Probably get a regulator rebuild kit next spring.
    Still a good day!
    John
  27. uncle buck
    uncle buck
    Trying to get my 32 frame all squared up
    mad mikey, warbird1, RICH B and 3 others like this.
  28. davidvillajr
    davidvillajr
    All my big plans didn’t come to fruition, so, I aired up the tires, gave it a pat on the fender, and then peeked out the window at it a few times. Ugh, I gotta invent the “next big thing” so I’ll be rolling in dough - hahaha!
    Papas32 likes this.
  29. Pontmerc
    Pontmerc
    from Finland
    Just Shakin hands for trade my off topic c10 rust bucket for 64 cadillac rust bucket....
    Didnt yet figure out laughing or crying....
    Attleast its hamb firiendly, sort of if i decide to tell what im gonna do about it.
    WTF really likes this.
  30. TA DAD
    TA DAD
    from NC
    The day has come for the moment of truth. Six am me and the wife leave the house for the swapmeet and test and tune. It rained all night and continued off and on until one pm. There was still a really good crowd of spectators and a lot of vendors considering the rain.
    My hats off to the crew at Farmington , they got the track dry and had cars running by about 2:30. So I have drove this truck for 10 months without a skip, now here I am sitting in staging letting it warm up and it starts acting like it is flooding. I shut it off and take a look no sign of flooding . Crank it up and it sounds good , I get in the bleach box and it falls apart again, stumbling , back firing out the exhaust.
    This is unbelievable! I get back to the truck and we stick a fresh set of points in and set the dwell (I had a meter with me, but no condenser )
    Fire it off with the new points and the problem is still there. So I load it up and we are homeward bound.
    But what a great day, we sold a few things and I plan on upgrading to a tach drive distributor and I bought two sweet old school tachs today. Plus I love the interaction my truck brings. There were guys more disappointed than me that I couldn't make a p***.
    I changed the condenser this morning and she is right back to her all business nature. I had a new Mallory magneto condenser ( at least that is what DSCN2682.JPG DSCN2681.JPG IMG_0791.JPG IMG_0786.JPG DSCN2677.JPG DSCN2678.JPG I came up with ) and mounted it on the firewall in a much easier to service location. The love of the machine can be rough !
