Features 289 Ford heads Engine Masters Challenge Style!
Discussion in 'Traditional Hot Rods' started by Mummert, Nov 22, 2022.
  1. Mummert
    Mummert
    Thought you guys could appreciate a little Iron Head magic.
    Deuces and loudbang like this.
  2. 57JoeFoMoPar
    57JoeFoMoPar
    That's awesome stuff there.
    Deuces, Mummert and Moedog07 like this.
  3. Deuces
    Deuces
    I have a pair of GT-40 iron heads that probably flow just as good.... Intake valve size is 1.84" and exhausts are 1.54"... The chambers check in at around 65cc...
    Mummert, Budget36 and rod1 like this.
  4. tommyd
    tommyd
    from South Indy
    Those look like 271hp heads with spring pockets.
  5. Budget36
    Budget36
    I’ve heard they were good heads, used on some/all? Explorers? Have casting numbers to look for? Thanks.
    Deuces likes this.
  6. topher5150
    topher5150
    My instagram figured out that I like head-resurfacing videos, so that's all I've been watching lately
    Beanscoot, Deuces and Mummert like this.
  7. Budget36
    Budget36
    And all you were looking for was a barber;)
    ekimneirbo, Deuces, Mummert and 2 others like this.
  8. Moedog07
    Moedog07
    Subscribed! One of my dad's cars growing up was a '64 Galaxy with a high winding 289. It had been a big block 4 speed car but a high strung 289 was swapped in when the big block got tired.
    I still have the engine and top-loader from that car.
    I'm following these videos and thread.
    Deuces, ffr1222k and Mummert like this.
  9. Mummert
    Mummert
    Maybe 195cfm, With your 65 cc chambers on a 289 I'll bet you make 8.75:1 compression, you'd be on track to 350hp.
    38Chevy454 and Deuces like this.
  10. Mummert
    Mummert
    Just remember with the Gt-40p explorer heads that the revised spark plug angle can have header clearance issues on older Mustangs Falcons etc.
    38Chevy454, Budget36 and Deuces like this.
  11. Deuces
    Deuces
    Don't know the casting numbers but they do have "GT" casted on them....
    Budget36 likes this.
  12. FORD FAN
    FORD FAN
    If they have GT cast into them they are GT40 irons. I have them on a '96 Explorer motor. After that they went to the GT40P heads, which have smaller valves but flow about the same.
  13. 38Chevy454
    38Chevy454
    Nice work, I have always heard the old SBF heads were bad on exhaust flow. But your video shows a nice clean smooth port that should flow quite well. Combined with the valve pocket work and chamber cleanup they look very nice.
