Technical Lowering the rear of a F100
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 20, 2022.
  1. Taboo56Chevy
    Taboo56Chevy
    you could almost say that its traditional to put a clip under one those trucks, lol. You dont see it much it at all anymore unless it was something built a long time ago. The old axles are good if you have tight spindles and kingpins, but used to get a lot of bang for the buck with a clip. Now most want a fancy ch***is that costs more than most projects.
  2. gimpyshotrods
    gimpyshotrods
    Yeah, but we are not allowed to talk about that here, and clips are getting thin on the ground!
    Roothawg likes this.
  3. Roothawg
    Roothawg
    Mine has an OT sports car front end that rhymes with More Bet.
    Tman and Sancho like this.
  4. gimpyshotrods
    gimpyshotrods
    Hornet?
    Wasn't that a unibody AMC?
    That's hardly a sports car, sir.
    David Gersic and alchemy like this.
  5. Roothawg
    Roothawg
    Come on Gimpy.....You work for Detroit......
    Budget36, Tman and gimpyshotrods like this.
  6. gimpyshotrods
    gimpyshotrods
    When the Hornet was made, AMC headquarters was still on Plymouth Road, in Detroit.
    indyjps and anthony myrick like this.
  7. Roothawg
    Roothawg
    Ugh.........C4. And that doesn't rhyme I know....
    rod1 likes this.
  8. junkman8888
    junkman8888
    What I'd use to lower the rear of your truck is a set of later-model Ranger pickup springs and hangers, you could mount the springs either above the axle or below then mount the hangers on the frame as needed for the proper ride height. Later model springs use an "overload leaf" so the pickup has a softer ride when not carrying a load.
    brEad, bchctybob and Tman like this.
  9. gimpyshotrods
    gimpyshotrods
    Now you are over in Dearborn!
    Best small automatic made!
  10. gimpyshotrods
    gimpyshotrods
    Mine has a geometric replica, width altered, C6.
  11. BamaMav
    BamaMav
    from Berry, AL
    Ain't that Dyno-Mite?:rolleyes::eek::D:D:D
  12. Nailhead Jason
    Nailhead Jason
    @D-Russ I looked for a thread on you F100 to link to this one to show the slick way you lowered your 54 but couldn't find one. Its one of the best ways I've seen, got any pics or is there a thread out there that covers it?
  13. D-Russ
    D-Russ
    Sorry @Nailhead Jason , I didn't do a thread on my Effie on the HAMB.
  14. Nailhead Jason
    Nailhead Jason
    My brain has too much unneeded info in it, I couldn't remember if you had one, or if you sent me pics of it or i saw it on IG. Either way it worked out super slick.
    D-Russ, Sancho and Roothawg like this.
  15. I scoped these out many times since I drove a Ranger for 14 years. Using the same springs on my GMC, they are fairly flat and ride well.
  16. HOTRODPRIMER
    HOTRODPRIMER
    The 9" rear axle looks like the one in my '65 F-100. HRP
  17. @Solospeedshop used just the Posies springs front and rear and went from this:
    To this. I know you don't' need the fronts but you can easily go lower in back with the adjustable spring hangers from Mid Fifties, getting it right where you want it....No flipping or notching..... 231534658_983390438868850_2804940916442546132_n.jpg
    MO_JUNK, bchctybob, LTM75110 and 4 others like this.
  18. To me, this sits perfect.....
    Landmule, rod1, bchctybob and 6 others like this.
  19. Roothawg
    Roothawg
    Don’t worry about the unnecessary axle flipping etc. its gonna hafta have the saddles cut off anyway. It has some home welding done and there is no way I would trust them.
    Im just trying to plot this out in my head, so I have a game plan once I get done with home renovation project #3,127 for 2022.
    bchctybob, Irish Mike and Sancho like this.
  20. 60 Special
    60 Special
    from Omaha Ne.
    Everything about that truck is perfect, down to the right hubcaps!
  21. Budget36
    Budget36
    Before;)
  22. D-Russ
    D-Russ
    Since @Nailhead Jason asked, I thought I'd add the unique things that I did to lower the back end of my 54 F100 without putting the axle on top of the springs. I swapped the Dana 44 for a 9 inch, reversed the main leaf eyes, removed 2 or 3 short leaves from the spring pack, added extended rear shackles, flipped the front hangers and modified and moved the rear hangers up two inches. I can still move the front hanger up to the top of the frame, which I intend to do. This is how the truck currently sits without the engine, trans, interior, etc. – it's basically a shell.
    Reversed the spring eyes on the main leafs:
    I widened the stock lower spring clamps to retain the factory lower shock mounts and to open up width for the larger 3 inch tube diameter of the 9 inch rear by cutting and welding two together.
    I raised the rear hanger 2 inches by cutting it apart and adding material:
    I boxed and c-notched the frame:
    And here's a pic showing everything but the c-notch:
    2Blue2, MO_JUNK, Sancho and 8 others like this.
  23. rusty1
    rusty1
    D-russ, do those rear shackles clear the bed floor?
    I think yer truck sits just rite in tha photo above., I like em with a bit of a forwad rake, mite sit diffrent when all weight is added.
    Roothawg, guthriesmith and D-Russ like this.
  24. D-Russ
    D-Russ
    Good question – with the 2 inch mod to the rear hanger, the stock shackle still cleared the bed floor, but with the three inch longer shackles, the top of the shackle/spring pokes through the bed floor an inch or so. My plan is to make a simple flanged box from sheet metal to cover each side.
    About a week ago I dropped the engine and trans in but I haven't rolled it outside to check the stance. But according to my measurements, the front end dropped another 1-1/4 inches. Currently the tires are the same size front and rear at about 27 inches tall, but I intend to run a 29 inch tire in the rear.
    Currently the front suspension has a 3 inch drop axle, reversed eye main leafs, 2 or 3 shorter leaves removed, and the rear hanger has been sectioned 2 inches. I'm considering raising the front shackle hanger the same 2 inches with a small Z in the frame, and I can swap in a 4 inch drop axle if needed.
  25. Roothawg
    Roothawg
    So, just out of curiosity, why is everyone avoiding flipping the axle? I do that on all my cars. Just wondering….
    Sancho, brEad and anthony myrick like this.
  26. guthriesmith
    guthriesmith
    Pretty sure it is to avoid having to notch the frame typically. But, if you are going that low, it is actually easier to flip it.
    Sancho, brEad, Roothawg and 1 other person like this.
  27. Eggsactily! Most axle flips result in minimal axle to frame clearance.
  28. D-Russ
    D-Russ
    I didn't flip my axle because I thought I could get it low enough without. Also, if I recall correctly, my measurements suggested that the pumpkin would hit the bottom of the bed. In hindsight, I've done so many little mods that I probably would have been better off starting with the axle flip.
  29. Roothawg
    Roothawg
    Makes sense.
    Sancho likes this.
  30. indyjps
    indyjps
    Very creative solution. What does your pinion angle measure after moving spring mounting points?
