Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Good info! Thank you
    Like I mentioned previously, that one is 100% on me. I'm an overly trusting person, which sometimes has its drawbacks. This was a prime example.
    Fair enough. I did mine in a high-riding style to emulate that era!
    That's what we concluded too.
    Glad you caught those. I've worn them as my shoe of choice since my Richmond days in 2014. I've worn through numerous of the black-on-black pairs, and I recently picked up a white pair to match Version 2.0 a little better. Don't worry, they've both already been covered in dirt, dust, grease and grime.
    A random picture from shooting @tdog's "Omaha Coupe" for DicE's Slot Mag.
    I have a strong feeling that it will all work out in the end. Matt has been a big savior on this project for sure!
    I saw that. I have a strong lead on a 59AB in SoCal. I'm going to check it out when I head down south for TROG. Thank you for the heads up!
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's Sunday night and things are winding down after a very relaxing/fun/eventful long weekend. Let's dive right in.
    Yesterday morning, I pulled up to the shop with a clear goal: take on a task where I knew we would succeed. We weren't thinking about the engine—we were thinking about the big picture. With that, we shifted our focus to the pedals.
    It felt good to revisit the pieces that I had been working on a month ago. The 10 gauge frame plate, the sandblasted pedal bracket with threaded holes, everything. With David's help, we worked it into position and tacked it in place.
    I welded as much as I could. I'll finish the final pieces once the engine and trans are out.
    Looking solid!
    We then bent the clutch arm to align with the pedals. This will be fine-tuned when we rebuild the transmission.
    As the sun set over Petaluma, I felt good about the day's progress. The pedals are in place, and we're one step closer to getting this car on the road.
    Before I left the shop, I asked David if he had any sage advice for my Version 1.5 dis***embly, which was planned for Sunday. "Just remember to take breaks," he said.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Today was my day to get stuff done. It was quiet on the cul-de-sac, and it felt good walking down the front steps into the warm late fall sunlight. After reviewing Les Andrew's Model A book, I started removing cotter pins, organizing hardware and pulling the car apart. Sonny and the Sunset's album "Longtime Companion" played in the background.
    Soon thereafter, I slid the rearend out from under the car. Success! With the complete ***embly removed, I cleaned the clamshell and submerged all the necessary hardware in the ChemDip bucket.
    Even though I've taken Version 2.0 apart dozens upon dozens of times, this was the first time I've taken the rear out of this one. I'd chalk today up as a victory.
    On Tuesday, you're going to see two Model A roadster build threads cross paths. @Jeff34 was kind enough to let me run the rear from his "Flathead Flathead" project, which is in the middle of its V8 conversion. I'll be picking it up in a couple days and installing it at the end of the week.
    Talk about fun with old cars!
  4. Tim
    Tim
    from KCMO
    Fantastic man :)
    winduptoy, J.Ukrop and Outback like this.
  5. Outback
    Outback
    from NE Vic
    Great work! Keep pushing on!
    J.Ukrop and Six Ball like this.
  6. 51504bat
    51504bat
  7. Cubby47
    Cubby47
    I bought one of Vern's off a g**** defroster from Fresno, damn fine 59ab that needed nothing except aluminum heads and a high rise with two 94s and a set of Reds headers. Of course a good cleaning and some new earl.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks guys!
    I saw that. It could definitely be an option.
    I've heard rumors of those engines and, as a matter of fact, was texting with Keith Tardel earlier today.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Back in the early days of this thread, I used to post a lot of stuff like this.
    Tonight, I took a long walk through the Inner Richmond and Haight picking up odds and ends for the rearend swap (and dinner). I trimmed and installed the freshly oiled cork clamshell gasket and pulled the hardware from the ChemDip bucket. Other highlights include new gaskets, new lock washers and new cotter pins.
    During my dis***embly, I realized that my car has a seven-leaf rear spring. That means it was either a roadster spring, or someone removed some leaves in the past 92 years. The spring attached to the rearend I'm picking up tomorrow has 10 leaves, so I am going to use the old all-thread and C-clamp technique to get the right ride height.
    Question: what type of grease do you recommend for the U-joint? I heard that cornhead grease is good, but it's unavailable in San Francisco. On that same note, does anyone have a recommended grease or oil for the inner torque tube clamshell? Any guidance would be greatly appreciated.
  10. Hitchhiker
    Hitchhiker
    I usually have to order corn head grease. Do you guys have a John Deere dealership? I usually get it from them. Its kinda hard to find.... but I guess there isnt a lot of corn in California. I usually get a few tubes when I order it. anything thicker will cavitate around the u joint and not keep it greased correctly. I suppose some light grease mixed with oil would work in a pinch.
    winduptoy, J.Ukrop, warbird1 and 2 others like this.
  11. Budget36
    Budget36
    I bought some corn head grease a few years back at the JD dealer in Modesto, I think there’s one in Stockton too. If memory serves its like an 0 wt grease. Not something you see at your local AP store. I’d bet the FordBarn has a few alternatives.
    winduptoy, J.Ukrop and 41 GMC K-18 like this.
  12. Tim
    Tim
    from KCMO
    I believe Amazon has it if you really had to go that way.
    lots of back and forth conversations in threads about what to put in that clam shell over the years might yield an alternative but by the time you figure it out you could have ordered the John deer product and had it in hand.
    J.Ukrop, Six Ball and bob b. like this.
  13. 51504bat
    51504bat
    J.Ukrop, warbird1, Six Ball and 2 others like this.
  14. Jeff34
    Jeff34
    Amazon has it, but no overnight Prime shipping for it, and @51504bat it is expensive.
    I think I have a spare tube that I can loan you and you can replace it if you think that would help. You could pick it up with the banjo later today.
    Jrs50, J.Ukrop and Budget36 like this.
  15. Speedy Canuck
    Speedy Canuck
    Perspective can be a funny thing. Definitely thought this was like a 4' wrench, until I saw the giant of a hand holding it.
    Jrs50, J.Ukrop and Six Ball like this.
  16. Speedy Canuck
    Speedy Canuck
    Trust, but verify.
  17. Six Ball
    Six Ball
    from Nevada
    Red Line or Lucas probably has something that will work.
  18. Tim
    Tim
    from KCMO
    What did you have in it previously?
    Also I don’t think model A’s have a zerk so there isn’t a seperate u joint and clam shell grease it’s only the clam shell grease if I’m not mistaken. Didn’t notice that little bit in your post til just now.
    Out of curiosity what’s the go to for Di Falco?
    Six Ball likes this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 34: Jeff to the Rescue
    Yesterday, I made the trip to Petaluma to meet up with @Jeff34 and pick up the replacement rearend. As I backed into his driveway, I saw his '34 pickup, which has been in his family for years. (When I have some more time, I'll see if I can dig up the RJ Times coverage of it from one of the Northern California Reliability Runs). The truck sports a warmed-over flathead, complete with dual carbs and Edelbrock heads. It sounds healthy and runs even better. IMG_9878.jpg
    After checking out his in-progress "Flathead Flathead" roadster, we rolled the rear out of the garage. IMG_9881.jpg
    Using some strategic maneuvering, we managed to load it in the back of my truck. Even with two of us, it was still pretty heavy.
    With that, I thanked Jeff for his generosity and I was on my way. Friends helping friends—this is what hot rodding is all about.
    You never know what you'll find on the streets of Petaluma!
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    With the rear still in the bed of the truck, I dis***embled the leaf spring pack using heavy-duty C-clamps and all-thread. I'll be off camping tonight, but I plan to start re-***embly tomorrow after work. Oh, and Jeff also lent me the fabled cornhead grease, so the clamshell will be a-okay. I'm looking forward to putting the pieces back into position.
    So then we can get back to more of this. Photo by Erik Jutras.
  21. Tim
    Tim
    from KCMO
    Good stuff :)
    winduptoy and J.Ukrop like this.
  22. Jeff34
    Jeff34
    The Hudson belongs to Rich, a neighbor of mine. He owns that as well as a Ford T-Bird. I think he spends more time working on old airplanes out at the airport hangar than cars, though.
    Stogy, tr_rodder, Hamtown Al and 9 others like this.
  23. trevorsworth
    trevorsworth
    I would just about kill to get my hands on a Hudson like that.
  24. Outback
    Outback
    from NE Vic
    @Jeff34 good on you for helping Joey out!
  25. A Boner
    A Boner
    Where can you get those tires? Looks like the could be made to look like dirt track tires real easy.
  26. Jeff34
    Jeff34
    Glad to help him out. I just hope the banjo works for him at TROG!
    I bought them directly from Blockley:
    https://www.blockleytyre.com/
    Unfortunately, in the Crossply range, they only go as large as 6.50X16. That's the tire you see in the picture.
    Stogy, Budget36, J.Ukrop and 3 others like this.
  27. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Same here. Interestingly enough, my neighbor at my old house had a yellow one. Every time I look at it, I swear it's chopped. Such a killer body style.
    winduptoy, 41 GMC K-18 and Tim like this.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's been a super busy week, but I have lots of thread updates happening soon. IMG_9978.jpg
    Feat. Yama!
  29. There are more than one of them for sale up here.
    Six Ball and 41 GMC K-18 like this.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sidebar 947: Making the Cut
    I’m sitting in a barber shop in Riverside, California, waiting to get a haircut. There are two gentlemen ahead of me, so I figured now would be the perfect time to get this thread up to speed.
    Things have been busy with work, but I was able to dig into the rearend project on Friday night.
    Using the technique I learned at David’s, I tore down the old spring. Next, I greased the leaves with Lubriplate and transferred the seven-leaf pack onto the new rear.
    Sometimes I forget that not everyone works on projects like this on Friday nights here in the city. As I was moving axles, a stranger walked out of the house next door. “What are you doing?” he said with a sense of wonder. “Working on my 1930 Model A to get ready for a race in SoCal next weekend.” He couldn’t believe it. “Can I look at the car?”
    As he walked into the garage, the whole scene didn’t seem to register. An old hot rod, seemingly levitating on jack stands, tools, and vintage motorcycles in a neon glow. “Thanks for letting me look,” he said. “I’m going to the liquor store—can I get you anything?” Realizing how much I still had to do, I declined, but thanked him for his generosity.
    When he returned, he handed me an ice cold Corona. I thanked him and popped it open. “Cheers my friend!”
    By the time I went in for the night, the new rearend was ready for the swap.
