Technical Paint Booth Alternative
Discussion in 'The Hokey Ass Message Board' started by TheSteamDoc, Dec 1, 2022.
  1. overspray
    overspray
  2. saltflats
    saltflats
    from Missouri
    I put up a 10x20 canopy then closed it in the best I could. Install some exhaust fans and some filters on each side for incoming air. Worked pretty good for the paint job I had to do. It then worked good for extra work space to keep me out of the sun or rain and with the lights it worked good for night time work also.
    I have just taken this down after being up for around 10 years.
  3. Good alternative to a paint booth and about the cheapest- 2x4s or PVC pipe frame covered with visqueen. Consider adequate ventilation. When to paint will be determined by ambient temperature and humidity per the paint specs.
    What I did
    Hamtown Al likes this.
  4. Bandit Billy
    Bandit Billy
    Bouncy house, works better if the sun isn't out, talk about a green house! But it does keep the debris out of the paint and it contains the overspray. I live in a carefully controlled subdivision, the nice thing about the booth is it goes up in seconds and down a bit slower but you can set it up, paint, tear it down before your neighbors get home from work.
    If the OP didn't live 8 million miles away I'd rent it to him. HAMB traveling paint booth. Kind of a cool idea. If any local blokes want to use it, let me know. Bouncy house balls not included.
    MOTOV8N, NoSurf, williebill and 7 others like this.
  5. How much coin did you drop on it Billy? I've seen others that have bought them, but nobody ever talks about how much they spent.
    guthriesmith and Bandit Billy like this.
  6. Bandit Billy
    Bandit Billy
    It was somewhere around $800 delivered. It came with 2 blowers, one to inflate and one to ventilate. I added a third (explosion proof) to draw air out the back which I am glad I did.
  7. jjjmm56
    jjjmm56
    from FL.
    Go to a local body shop they will sometimes rent their booth out for a day or two.
  8. My neighbors don't care what I do
    MOTOV8N, NoSurf, williebill and 3 others like this.
  9. Fortunateson
    Fortunateson
    I use urethane SS and I find it fairly straightforward though I have had to ask advice on the forum a couple of times. I’d say lighting is key if you are spraying a dark colour especially.
    My first paint job was done with a 3hp portable compressor in a way too cramped garage. Single stage gun metal metallic. I knew enough on how to avoid “tiger stripes” and only had one small run. I sanded them out and was surprised you couldn’t tell. My nephew who was in the trade was impressed and asked where I got my car painted...I was quite proud to say I did it. Man I miss Centari!
    Just Gary likes this.
  10. millersgarage
    millersgarage
    my back yard is my favorite paint booth
    I know many guys that just hang plastic in their garages and get a great paint job.
    guthriesmith likes this.
  11. Neither do mine. At least not for a few hundred acres. Just can't run your mouth, because your enemies just gotta make a phone call, and you're somewhere in the $25,000 range in the hole to the feds.
  12. But when you're painting 1 car every 5 years, nothing much will be said. When you paint 2-3 times a week on average, yeah, they get serious about your waste and overspray.
  13. 57 Fargo
    57 Fargo
    79686416-7A18-403E-A325-D12392339548.jpeg E28A0398-5E52-4B27-BB07-6A242E9F952C.jpeg
    My latest paint shanty…
    MOTOV8N, NoSurf, williebill and 6 others like this.
  14. theHIGHLANDER
    theHIGHLANDER
    Good place to say it again, VENTILATION IS CRITICAL TO YOUR HEALTH!
    Those fumes will get thru your eyes, your skin, it isn't just the fog. **** the dirt in the paint thinking, get the fumes out. 30 min after the last coat that exhaust is best still running. Any old *****s (like me) that chime in with "...for years and I didn't worry about blee blah hoo hah..." well you likely didn't work with this toxic plastic **** either so keep it to yourself. YOU need the ventilation. That it cleans the air too is a welcome side effect but especially at home, GET THE ****IN PURGED FUMES OUTTA THERE!
    Ok, y'all can go out n play now:cool:
  15. 65pacecar
    65pacecar
    from KY, AZ
    Anyone use the turbine painters for a car, supposed to be low overspray? Looking at the bouncy house option too. I have a nice shop out back but really don’t want the overspray in there.
  16. 65pacecar
    65pacecar
    from KY, AZ
    do you have a link to that one? Considering the portable route.
  17. Bandit Billy
    Bandit Billy
  18. Slopok
    Slopok
    That reminds me, I have to get a patch kit to repair the holes in my inflatable! :rolleyes:
    Oh...never mind, you're talkin' bout a different type of inflatable! :eek:
    40FORDPU, Just Gary and Bandit Billy like this.
  19. millersgarage
    millersgarage
    @65pacecar I use a TP Tools turbine. I like it. Very little overspray, but it really throws the paint out, took a while to get used to it.
    65pacecar likes this.
  20. big john d
    big john d
    from ma
    amazon wedding tent 1 0 x 30 for a little over 100 maybe if get to use it a few times
